So if I take a 2N2222A transistor and a G3MB-202P relay and 3.3v logic controller
What resistor value should I be using for the base? Normally i would just take a ~1k resistor and go, but i need to work every time and not fail
The problem I am trying to solve: my dad hates 3 way switches (he is not even the one wiring them) and insist on the only way to get through a room at night is to turn the light on, go to the other side of the room and turn that light on, go back and turn the 1st light off, then go back again and turn that light off, screw that I'll make a software light switch that uses door sensors (more reliable than a motion sensor working)
second question if i use the same logic wire can i make a double throw SSR switch by using 2 of these one on a 2N2222A and a P2N2222A or would i have issues with overlap there both are on/off at the same time (not sure if that is even a issue for my thermostat)
