BTC 0197 - Datasheet
  • Iceking007
    • Oct 2022
    • 10
    I'm looking for a datasheet for a display controller. Any searches I make for BTC just result in Bitcoin results, In not sure who the manufacturer is to search their full name. Please see the image of the IC.
    Thank you for your time.
    • 21409
    Re: BTC 0197 - Datasheet
    Is it in a Brymen multimeter
    https://www.eevblog.com/forum/testge...ch=31973;image
    https://www.eevblog.com/forum/testge...down-pictures/
    • redwire
      • 3912
      It is a custom IC for Brymen. 8-bit MCU, LCD controller... likely just like a Hycon HY17P68 but with some modified features. I'd expect a few pins or die flip/rotate to get the pinout to match.
      I think the DMM section is not used and instead the second big IC BTC AD-85-4 is the DMM A/D portion.
      • Iceking007
        • Oct 2022
        • 10
        It's actually in a Greenlee multimeter, I'm not sure who 'copied'who, or if it's just mass branded, but nothing in this meter is labeled Bryman, everything is labeled "Greenlee" or similar.
        Thank you for the help, I'll look into that and see if that information proves fruitful.
        I'm looking to extend the led backlight timing, I'll try on my own, if I'm not successful you might see me back looking for assistance in that one as well.
        Cheers!
          • 31131
          brymen make meters for other brands.
            • 21409
            Cheers!
            From another thread over at eevblog - https://www.eevblog.com/forum/testge...-duration-mod/
            • electomech-fixer
              First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
              by electomech-fixer
              I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
              I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
              Yesterday, 01:42 AM
            • SoulFreeze
              Help finding datasheet for component marked G34662
              by SoulFreeze
              Hi, pulled this component, (I'm assuming it's a MosFET) from an LED COB video light. Im trying to find the datasheet so I can find an equivalent replacement but no luck. Any assistance with the datasheet would be appreciated.
              Failing that, a way to pick a suitable replacement component? If it's indeed a switching fet, I'm assuming I might need to measure the switching clock frequency and find a component that meets the power capacity?
              Its a pair of them driving a 130w Light. Takes in 19volts. I can borrow a scope to measure the switching freq....
              05-01-2025, 03:56 AM
            • Rainbow_Chameleon
              Searching Datasheet for AM113 IC by O2MICRO
              by Rainbow_Chameleon
              I got a dead HD6950 on Ebay to try my luck and repair it. There were a few broken off capacitors that I already replaced.
              Measuring the PCI-E lanes I got somewhat weird measurements, the gpu might or might not be dead.
              If I plug the GPU in, the core heats up and I also get VCore but on two inductors that measure 16 and 60 Ohms respectively (Memory and PEX I guess) there is no voltage.
              On one of the two buck-controllers (APW7165) the enable pin is pulled to GND and the other controller I just cannot find a datasheet for.
              So if anyone has a datasheet or at least...
              01-23-2025, 12:03 PM
              Surface Mount Fuses Fundamentals Datasheet
              TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
              TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
              10-07-2024, 06:07 AM
            • evgental
              HP prodesk 400/600 G6 mini schematic/datasheet
              by evgental
              Hey everyone,
              I'm looking for a schematic or datasheet for this mini PC. I want to see if I can add another NVMe slot, since my motherboard only has one. If anyone has it, please share. And if you have a motherboard with two NVMe slots, can you send some high-quality pics so I can figure out how to reverse-engineer it and give it a try?
              Thanks a lot!
              08-04-2025, 04:58 PM
