Queen coffee CQ MN-2 Heating element
  • redwire
    • Dec 2010
    • 3912
    Re: Queen coffee CQ MN-2 Heating element
    I would replace the float only if it has water inside it. But they only sell the entire tank assembly 1204015.
    It is more likely to have mineral deposits - lime, calcium, sand that is jamming it. Or someone dropped something inside, like coffee grinds, paper etc.
    Flip it upside down! Try cleaning it with descaler (avkalkningsmedel).
    • R_J
      • Jun 2012
      • 9607
      I was too slow posting, like rewire said...
      It may be sticking do to calcium buildup, or something is warped due to heat. Also check the force it takes to press the micro switch just in case it's actuator is sticking, not likely but worth checking.
      • redwire
        • Dec 2010
        • 3912
        These kind of restaurant big coffee brewers used to be mainstream at Tim Hortons (BUNN), in the morning drive-through rush it must be 10kW+ of electricity used by them all. New coffee machines are now computer controlled and make yucky tasting coffee. You should see the programming menu.
        So this one of OP's is nicely not super complicated.
        • bohaboha
          • Nov 2012
          • 1017
          • sweden
          It's true what you said that someone poured something in the water tank my neighbor asked me to look at it because someone in his job accidentally poured some kind of farin then the machine died first when I tested it worked but then it just died. now thanks to all your help the machine is back up and running and i know the problem in case it dies one more time. but one last question : why is there no fuse on this machine ?
          • petehall347
            • Jan 2015
            • 4440
            that's like 42 amps .must have its own circuit .
            • redwire
              • Dec 2010
              • 3912
              The machine needs no fuse of its own - the branch circuit breaker 13A or 10A is expected to trip if there is a fault. The safety standard requires all the wires (power cord, plug, inside wires) to handle enough fault current to trip the circuit breaker, and not be capable of starting a fire inside.
              The Coffee Queen of Sweden manual says nothing about safety approvals, even CE.
              Here people grab a coffee on their morning commute, perhaps it's tea in the UK.
              The 10kW is the 5-7 machines brewing non-stop at the drive-through for the morning rush. I realized that is a ton of electricity used heating water fast. Then there are the ovens toasting bagels and stuff.
                Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                12-16-2023, 08:39 PM
              • EasyGoing1
                The best way to drive a heating element?
                by EasyGoing1
                I've got this circuit that I've been playing with on a breadboard. I'm not happy with it mainly because the MOSFET gets too hot and generally controlling the temp of the heating element with the Arduino has proven to be a little more cumbersome than I would like.
                What I would like to know, is what is the best way to set up a circuit like this? The heating element is just a PCB and its going to be mounted under a 3D-printed enclosure that a lizard will use to warm his belly.
                This is the general setup that I have now.
                This is what the...
                01-25-2023, 11:29 AM
              • sew333
                Apartment to buy with coal heating. Any sense to buy electrical heater and new pc?
                by sew333
                Hi guys. I have an question. Overall i am currently selling my house ( apartment with 1 room ) to buy some cheaper with 1 room too, and save cash for new pc in autumn 2024.
                So i choosed some cheaper apartment in smaller city,but there is coal heating. I dont wanna heat for coal.
                So i m thinking to buy electrical heater. And my question . Is this any sense to buy electrical heater when i will be using new pc with rtx 5090 and new intel ( when will be released ) ultra + Psu Seasonic 1600W?
                I expect that i will pay more for bills. But i wanna know this. Will using electrical...
                06-14-2024, 07:30 AM
              • edugimeno
                Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
                by edugimeno
                Hi!!
                Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
                I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
                At a certain point, moving stuff around, I put all wires back in place and...
                03-24-2024, 02:31 PM
              • madan1
                Diesel heater emergency power supply / poor man's UPS
                by madan1
                Hello everyone.
                Some background - I have one of those chinese diesel heaters, which I'm using to heat a garage. Probably most of you are familiar with that units, but here is some basic info - the main heater body is enclosed with the motherboard+sensors unit inside a plastic case. The heater has a glow plug, that works only when the unit is starting (start the fire in the burner) and stopping (make sure to completely burn the fuel inside the burner) and two fans on a single motor. One fan is used to push fresh air in the burner, the other is used to push cold air in the case and...
                12-18-2022, 08:05 PM
