What is this "processor"
  • eduaqa
    • Jun 2022
    • 16
    • US
    I have a M&S SYSTEMS, and not working well. The display keep showing Realz ... meaning release, like if a had push the 2 talk button simultaneously, I already disconnect the processor board and still show the same. I put a 10K resistor on the connection that comes from the board, because otherwise it would be expected that behavior, but even with that still the same, it's like something on the board is not able to compare voltage as reference.
    Seems to be a exclusive chip made to this, but I believe should be based in some other.
    If was able to find some data sheet would at list to know which pin are used for compare
    On the top of the cihip says M&S SYSTEMS 830100A 404328A20S
    The chip has 64 PINs ... I tried to attache the picture, but not finding how. Maybe somebody on the forum can tell how to add pictures.
  • eduaqa
    • Jun 2022
    • 16
    • US
    Re: What is this "processor"
    Let see if the pictures goes
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Hello, please see this FAQ for how to insert photos in your posts:
      https://www.badcaps.net/forum/showthread.php?t=1868
      Have you checked the four discrete transistors Q1 > Q4 on the board to make sure they are ok?
      And also that super capacitor C1 on the board, does it still hold a charge with the unit unpowered?
      If not maybe it lost some important parameters like how the intercom wires are configured if that is possible to change?
      It is also possible that the TC4093BP schmitt trigger has one or more failed gates.
      It is probably used to get a clean trigger from the external wiring for the intercom system.
      • eduaqa
        • Jun 2022
        • 16
        • US
        The super capacitor I replaced and it can hold the charge (clock)
        Q1 > Q4 at least without unsoldering seems OK
        but the trigger has a strange behavior ... if I touch the pin 1,2 with the finger, of course after discharging static it reset the clock (turn off, and comes back as 12:00)
        about wiring I'm testing the board isolated from the rest, I'm powering it with 5.1V from a regulated power supply and it's disconnected from the rest
        I put a 10k resistor on the PINs that comes from the main board where the talk buttons are connect otherwise it will understand that I pushed both buttons (in this case release function) that why a put the resistor to not simulate release but still happening ... connected to the other board or not.
        • eduaqa
          • Jun 2022
          • 16
          • US
          Some adicional information for the main IC on the board
          PIN 4 goes to the main power line
          PIN 8,9 goes to the main ground line
          PIN 11,12 has a 4mhz xtal
          PIN 16 goes to the main ground line
          • eduaqa
            • Jun 2022
            • 16
            • US
            I draw the schematic for the Q1 to Q4 which are MPS2907A, but I don't understand
            the collector goes to the PINS 5,7 of the main CI and has about +4.5v
            The pin 6 of the CI comes from the board and has around 5v when no button pressed, 3.8v when talk external pressed, and 1.6 when talk to the room pressed, and 0.5v when both button pressed what means release
            But for now stay in release independent of the voltage on the pin 6
            So seems or other factor is making the main CI understand the release is been requested or is not able to do voltage compare
            now the part that I don't understand ... MPS2907A is PNP, but according to the diagram I did from the board the emitter is connect to the 5v using a 511ohms resistor. I'm considering that it EBC 1 2 3 pins
            and 2 of the MPS2907A has nothing connect to the collector
            • eduaqa
              • Jun 2022
              • 16
              • US
              Found the processor, it's a Hitach HD404328, still didn't help a lot, but checking the pins and where connected to the main unit board to try to track what is causing the processor understand the RELS (door release) is been requested
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
                HP Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC E6300 Specification for Upgrade or Repair
                This specification for the HP Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC boardview and Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will...
                09-12-2024, 03:36 PM
                FUJITSU ESPRIMO Q957 ESPRIMO Q i3-7100T Specification for Upgrade or Repair
                This specification for the FUJITSU ESPRIMO Q957 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ESPRIMO Q957 boardview and ESPRIMO Q957 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for FUJITSU...
                09-12-2024, 03:44 PM
                FUJITSU CELSIUS W550 CELSIUS i5-6600 Specification for Upgrade or Repair
                This specification for the FUJITSU CELSIUS W550 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the CELSIUS W550 boardview and CELSIUS W550 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for FUJITSU...
