Ota locals converter box suggestion.
  • ivtec
    • Dec 2008
    • 1967
    Hi folks i want to buy a Ota off the air Tv box to replace Apex Dt 250a cheap box but i want to get a simple no recording just better tuner , of these which you suggest/ thanks.
    https://www.amazon.com/Best-Sellers-...nics/979935011
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: Ota locals converter box suggestion.
    Perhaps it would be helpful to explain what type of antenna you are using and what is happening with the present cheap box that is wanting you to have a better one.? Also, it would help to know what connection you are using on the TV. Do you have a av cable connection or just a F connector?
    • ivtec
      • Dec 2008
      • 1967
      Thanks Keeney ;i have an antenna 30 feet high with amp and i get about 70 ota channels on my Samsung tv,i'm good there, i have the outdoor antenna connected to my Samsung tv and to my old ota apex 250a converter box same on 2 way splitter and some channels like create wont show on the apex converter box tuner and show on the Samsung tv tuner ,I use the Digital Apex Converter box with coaxial cable out to other tvs in the house.
        • Jul 2011
        • 6037
        Are you looking for something like this
        https://www.ebay.com/itm/27531104677...sAAOSwgnZifuXN
        Back in the day when they went digital tv the converter boxes were treble and if you live more than 15 miles from the tv tower your reception was poor at best with out an amplifier so this might be one issue
        • ivtec
          • Dec 2008
          • 1967
          Thanks mate did you read my post above? ,i have an Apex 250A, i got it many years ago ,i think it is getting old and it's not performing very good.
          i think i found one box that seems to have good reviews ,i think i'm going to try it.
          https://www.walmart.com/ip/Mediasoni...Used/854865392
          • keeney123
            Lauren
            • Sep 2014
            • 2536
            If you are using a uhf antenna and you are trying to get PBS and they are broadcast vhf you would not receive the station. Then there is omni-directional and directional antennas. The omni-directional could have problems picking up a VHF signal. To find out if its your antenna, and the PBS is a local station, you could try a set of rabbit ears and see if you get the change then through you convertor box. Also, check if you convertor box will process VHF signal?
            • ivtec
              • Dec 2008
              • 1967
              Thanks mate;i get most of these stations and Create Channel is a sub of PBS 3 Channels and all are UHF,i only get UHF cause my antenna is UHF, all channels in in VHF are also in UHF= https://www.rabbitears.info/market.p...market&mktid=8
              • ivtec
                • Dec 2008
                • 1967
                [QUOTE=ivtec;1133205]Thanks mate;i get most of these stations and Create Channel is a sub of PBS 3 Channels and all are UHF 42 miles from my location ,i only get UHF cause my antenna is UHF, all channels in VHF are also in UHF,
                • keeney123
                  Lauren
                  • Sep 2014
                  • 2536
                  [QUOTE=ivtec;1133206]
                  Here is a better understanding of UHF and VHF stations. Just look at the signal column. The frequency is different and require the length of a VHF antenna. A UHF antenna will not pick it up because the length of the antenna is shorter.
                  https://nocable.org/availability-rep...121-boston-ma/
                  • ivtec
                    • Dec 2008
                    • 1967
                    Hi mate.I'm getting all these and much more now; on all tvs in the other rooms And my problem before was solved by changing the way i had the set up,and the set up was
                    ,the cable from the antenna was connected to a 2 way splitter 1 output would go to converter box short cable and the other short cable to a 4 way splitter and 1 output to 20 feet cable to a 2 way splitter to feed 2 tv ,another 15 feet cable to feed 3 way splitter to 3 tvs,
                    My change was i connected outdoor antenna with amp to just 3 way splitter and from there i
                    fed the other 20 feet cable and 15 feet cable to all other splitters and tvs ,also bought a new digital converter, now i have all the channels,at first when i searched for channels and they all showed on the line up but a lot had weak signal,but on my samsung with short cable i had all the channels. https://www.walmart.com/ip/Mediasoni...2?athbdg=L1100
                    • keeney123
                      Lauren
                      • Sep 2014
                      • 2536
                      Good to hear you got it going.
                        MPS NB670 NB670GQ Switch Mode Converter for Laptop Computers Datasheet
                        The NB670 NB670GQ is a fully integrated high frequency synchronous rectified step-down switch mode converter with 3.3V fixed output voltage. It offers very compact solution to achieve 6A continuous output current and 9A peak output current over a wide input supply range with excellent load and line regulation. The NB670 operates at high efficiency over a wide output current load range. Constant-On-Time (COT) control mode provides fast transient response and eases loop stabilization.
                        Under voltage lockout is internally set as 4.65V. An open drain power good signal indicates the output...
                        10-23-2024, 03:23 AM
                      • gizmo1990
                        What is this PSW1 part on a circuit board? Trying to fix a Canopus ADVC-300 DV/VHS Converter
                        by gizmo1990
                        I'm trying to fix this Canopus converter so that I can convert lots of old VHS cassettes. The problem is that it turns on for a split (and I mean split!) second, the fan jerks and then.. nothing. I've checked the power brick works. I've opened up the converter itself and been testing for shorts.
                        The image attached shows the on/off switch (which I've checked works) to the left of the yellow socket. Below the yellow socket is a green block marked 26 with a strange symbol at the front. Putting my probes either end of this block, on the silver parts, gives an open short...
                        10-21-2024, 08:02 AM
                      • wolf1976
                        i look for equivalent dc to dc converter
                        by wolf1976
                        hi
                        in an inverter of aircondition i have dc to dc converter mes1515mh
                        i have attachment the pdf file
                        can i take a dual converter with two dc outputs instead this ? because i cannot found the same or is not possible ?
                        the problem is instead 15 volt dc output i have only 6,45 volt
                        thanks on advancxe...
                        08-01-2024, 04:52 PM
                      • md500
                        [Question] Ch341a and 5v to 3.3v with logic converter
                        by md500
                        zz0.8tpitu4y0i8zzI bought a ch341a (I'm waiting for it to arrive) and I noticed that the programmer has a bug that the data pins go to 5v when the VCC pin is at 3.3v (which is the voltage I'm looking for).
                        Instead of doing the 3.3v mod, I'm thinking of converting the 5v to 3.3v with an 8 channel TXS0108E through the ZIF socket but I don't know if that would work, because it has to circulate voltage and also information.
                        What I am looking for is something that will convert from 5v to 3.3v but without modifying the ch341a.
                        I can't buy the ch341a 1.6v that has...
                        05-24-2024, 06:51 PM
                      • japlytic
                        SOCs with an on-die DC-DC converter
                        by japlytic
                        You may know this, but all Intel Core CPUs from the fourth generation (Haswell) onwards have an on-die DC-DC converter, and a System on Chip (SOC) which has such is the Broadcom BCM2835 (and certain other SOCs used in the Raspberry Pi) - the only external components for the DC-DC converter are inductor(s) and filter capacitor(s) and in some cases, feedback voltage resistor divider(s).
                        Do you know of any other SOCs which have an on-die DC-DC converter?
                        01-29-2023, 07:06 PM
