SOCs with an on-die DC-DC converter
  • japlytic
    • Oct 2005
    • 2086
    You may know this, but all Intel Core CPUs from the fourth generation (Haswell) onwards have an on-die DC-DC converter, and a System on Chip (SOC) which has such is the Broadcom BCM2835 (and certain other SOCs used in the Raspberry Pi) - the only external components for the DC-DC converter are inductor(s) and filter capacitor(s) and in some cases, feedback voltage resistor divider(s).
    Do you know of any other SOCs which have an on-die DC-DC converter?
    • 31170
    Re: SOCs with an on-die DC-DC converter
    great, more shit to fail.
    i'm sick of intel assholes putting shit on-die that is known to fail
    usb interfaces, sata resistors, dvi/hdmi drivers, and now this.
    i know people with desk-high stacks of i5 laptop boards that cant be fixed because the cpu's are all fucked.
    breaking your usb or monitor connector shouldnt trash the cpu - unless it's designed in israel it seems!
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      integration for size reduction and price costs, who asked for smaller cheaper computers?
      • Dan81
        SNES-powered
        • Oct 2013
        • 1866
        I wonder if this isn't the cause that 1155, 1150 and newer ASUS mainboards won't turn on with a CPU?
        Main rig:
        Gigabyte B75M-D3H
        Core i5-3470 3.60GHz
        16GB DDR3-1600
        Samsung SH-224AB DVD-RW
        Delux MG760 case
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          I think we're getting a bit confused in this thread...
          Technically speaking putting on-die DC-DC converters does not increase the amount of shit to fail because the amount of electronics is still the same, just that the converter is now on die. So, it does make bigger FRUs so repairing things is more expensive when they do fail, so basically it's killing people who want to repair items - so only complainers should be those who want to make money off of repairs or those who want to save the environment from e-waste.
          And I'm not sure above the above comment: motherboards won't boot anyway without a CPU, and if you insert a CPU and cause a motherboard to no longer turn on, that motherboard is probably bad...
            • 31170
            intelligent designers put parts that fail because of external means in the design as seperate items.
            scumbags put them into the most expensive and hard to replace part to make you throw the item away.
            simple.
            do you think it's wise to put a $200 component at risk of being destroyed by a bad connector or ceramic cap,?
            i think it's pure evil and intentional by people who should be flogged in public!
            • Dan81
              SNES-powered
              • Oct 2013
              • 1866
              nvm, found my answer on Tom's Hardware with someone who had a bad 1150 CPU. ASUS' mainboards of the Sandy/Ivy/Haswell era will simply not turn on without a CPU.
              Guess it's just a matter of finding a retention bracket for 115x, as I got the board for around $2 with no bracket whatsoever, as well as a bunch of bent LGA pins.
              I'm confident the pins shouldn't short anymore (not my first rodeo with 115x bent pins - I have had a Gigabyte H55M-USB3 w/ bent pins that worked just fine once I got them as straightened out as possible) but I really had no idea the newer 1155/1150 (and possibly 1151 and 1200?) ASUS mobos will NOT turn on at all without a CPU.
              TL;DR Mobo just twitches but VRMs check out fine and no shorts on 12v. ASUS just put some sort of protection that won't let you turn on the mobo without a CPU. I remember reading about this long ago but forgot it until now.
              AMD boards surprisingly don't have this thing - they power on without a CPU, but do nothing else (obviously.)
              Main rig:
              Gigabyte B75M-D3H
              16GB DDR3-1600
              Delux MG760 case
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                simple.
                again, someone wanted a smaller, cheaper computer.
                  • 31170
                  let them buy a fucking tablet and install sailfish then.
                  • piernov
                    • Jan 2016
                    • 4437
                    • France
                    4th, 5th, 10th and 11th gen do have what they call an FIVR. For other generations the power delivery isn't as integrated into the CPU.
                    It's still possible that there are some auxiliary power rails created on-die with LDOs for example that we do not know of.
                    Btw this is a very common technique on low-power microcontrollers, either with LDO or buck converter. Of course it's better integration but this can also be done for power efficiency reasons.
                    If the power rail is created specifically for one part of the integrated circuit and not used outside of it, it makes sense to handle it on-die.
                    As a side note, modern Intel CPU already die almost all the time when something bad happens on one of the external power rail, so it's not like having them on-die makes a difference in terms of reliability and repairability…
                      MPS NB670 NB670GQ Switch Mode Converter for Laptop Computers Datasheet
                      The NB670 NB670GQ is a fully integrated high frequency synchronous rectified step-down switch mode converter with 3.3V fixed output voltage. It offers very compact solution to achieve 6A continuous output current and 9A peak output current over a wide input supply range with excellent load and line regulation. The NB670 operates at high efficiency over a wide output current load range. Constant-On-Time (COT) control mode provides fast transient response and eases loop stabilization.
                      Under voltage lockout is internally set as 4.65V. An open drain power good signal indicates the output...
                      10-23-2024, 03:23 AM
                    • gizmo1990
                      What is this PSW1 part on a circuit board? Trying to fix a Canopus ADVC-300 DV/VHS Converter
                      by gizmo1990
                      I'm trying to fix this Canopus converter so that I can convert lots of old VHS cassettes. The problem is that it turns on for a split (and I mean split!) second, the fan jerks and then.. nothing. I've checked the power brick works. I've opened up the converter itself and been testing for shorts.
                      The image attached shows the on/off switch (which I've checked works) to the left of the yellow socket. Below the yellow socket is a green block marked 26 with a strange symbol at the front. Putting my probes either end of this block, on the silver parts, gives an open short...
                      10-21-2024, 08:02 AM
                    • ugamazing
                      Procedural question about BGA rework and removal of CPUs
                      by ugamazing
                      I have been working to develop a consistent and reliable method/workflow for removing, re-balling, and replacing CPUs on various MacBook Pro models (2015-2020).
                      I have done OK so far, but there's one detail I need to sort out. I'm hoping someone much more experienced than myself may be able to shed some light:
                      I am noticing the pulled CPUs (to be re-balled) come off fine, and they "look" fine as well, immediately when I pull them. However, within a few minutes, after cooling, the CPU chips develop a very, very slight curve/bend. It's SO SLIGHT, maybe a 1-2%...
                      07-12-2022, 03:11 PM
                    • Nebukadnerzar_V
                      Dell Optiplex 760 USFF BIOS Mod Request for QuadCore CPUs
                      by Nebukadnerzar_V
                      Hi guys!
                      I have a Dell Optiplex 760 USFF (Ultra-Small Form-Factor).
                      It currently only supports Dual-Core CPUs and will halt with an error message, when a QuadCore is installed.
                      I have seen people running QuadCores in these machines, but the BIOS needs to be modded.
                      Since I have not found the modded BIOS to download anywhere, I am asking you guys for help:
                      Could you please add support for QuadCore CPUs (in my case the Core2Quad Q9550) to the BIOS?
                      I have attached the Dump of my machine.
                      S/N: SRW2K4J
                      Reg Model: DCTR...
                      09-27-2024, 02:43 AM
                    • wolf1976
                      i look for equivalent dc to dc converter
                      by wolf1976
                      hi
                      in an inverter of aircondition i have dc to dc converter mes1515mh
                      i have attachment the pdf file
                      can i take a dual converter with two dc outputs instead this ? because i cannot found the same or is not possible ?
                      the problem is instead 15 volt dc output i have only 6,45 volt
                      thanks on advancxe...
                      08-01-2024, 04:52 PM
