How can I build a solar light??
  • brbpab94
    • Mar 2007
    • 22
    I would like to build a solar light that is brighter then the one's you buy.I plan on useing old garden light solar panels 5.volts each and I just bought 100 17,000 mah led's.I would like to know what transisters,capacitors,photocells,ect that I would need.Is there an easy formula that a newbee could use.
    Please help
    Brian
  • kikkoman
    • Jul 2007
    • 691
    Re: How can I build a solar light??
    ohm's law?
    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
    • brbpab94
      • Mar 2007
      • 22
      Is there a simple guide?
        • 31278
        panels go through a low-voltdrop diode and maybe a current-limit resistor into batteries or capacitors.
        they then connect to the led's through a current-regulated switching psu.
        and obviously it needs a switch - either physical or optical or a timer.
        that's how you do it right anyway.
        and just for acuracy, your led's arent likely to be 17,000ma - i suspect they are 17,000mcd.
        ma is a way of describing current, mcd is a way of describing brightness.
        • brbpab94
          • Mar 2007
          • 22
          17,000mcd is what I meant.What size capasitors would take the place of a AA battery?
            • 31278
            cap's are rated by voltage & uf.
            the voltage is just the safe limit, so for 5v anything higher.
            the uf - higher is gonna hold more power.
            you need to do some numbers,
            how much current & voltage do the led's use,
            how many leds do you want to run,
            how long do you want them to run.
            you need to know all this to calculate the minimum size of the battery or cap.
            • Krankshaft
              • Jan 2007
              • 2328
              Capacitors? A super cap?
              I can't think of any other cap resembling a battery.
              Also hours of sunlight contribute to the total runtime less sun in the winter means less runtime for example.
              • PlainBill
                • Feb 2009
                • 7034
                Go with a battery. The run time is MUCH longer per $ or unit volume. If you want something that will give a few minutes of light when you flip a switch, a cap might do it. For anything else, use a battery.
                The first step is figuring out what the voltage drop and current requirements are for the LEDs you just bought. Then you figure out how long you want them to be on. Next figure out how much current and voltage those old panels supply. Now do the math.
                PlainBill
                  LED Solar Flood Light Dusk to Dawn Security Wall Street Yard Outdoor Lamp modifications are in order
                  I bought one about a month ago from an eBay seller who now is out of stock however I found another eBay seller that has the same version of this device so I think about buying a few more of over a period of time
                  Awhile back I bought some A123 brand 18650 battery cells that are 3.2 volt battery cells that I am going to use in this device for more running time in a florescent bulb fixture that I gutting out the tube sockets and turn it into a solar powered LED lighting fixture instead
                  Pictures will come later when I have the lighting fixture gutted and have the battery...
                  08-11-2024, 11:10 AM
                  Lithonia Lighting versus Light of America Compact Fluorescent product quality
                  I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                  I also have back when Light of America had these light bulbs available for yard lights
                  The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                  While the Lithonia lighting fixture has all most certain bulb failure
                  So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                  I have only had this light fixture for not more than a year if it...
                  07-02-2023, 03:45 PM
                  LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                  This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  09-07-2024, 03:40 AM
                  LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                  This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  09-06-2024, 09:10 PM
                  09-06-2024, 08:40 PM
