I want to know if this idea is feasible switch mode battery operated 110 volt power s
    • Jul 2011
    • 6070
    The reason I ask is I can buy a 111 volt battery pack
    Or an inverter that operates at 110 volt ideally pure
    sign wave
    • 31283
    Re: I want to know if this idea is feasible switch mode battery operated 110 volt pow
    it can obviously be done, 12v of lithiums and an invertor - BUT
    your talking about a 10:1 boost in voltage so even if your efficiency is 100% your also looking at 10:1 current.
    so a 1A load would pull 10A from the batteries.
      • Jul 2011
      • 6070
      What I am asking is if you start with a 110 volt battery pack so you are not up-ing the voltage the voltage is already there you just are using current from the battery battery pack
        • 31283
        well you can connect directly to anything that uses a rectifier to create dc - like a switching psu.
        if you need ac there are sine modules on ali, but i think you need higher input - probably 140 or more
          • Jul 2011
          • 6070
          Do you have any website link that I look at these modules
            • 31283
            no sorry,
            i know a friend had some from ali-express - they are used in comercial invertors.
            to get 240vac out you have to put something like 300v in.
            you select the frequency with a jumper
