Why there no capacitor here?
  • nanobyte
    • Apr 2010
    • 11
    Ok, after I started to work on my video card capacitors... i noticed there was one capacitor mark in the board but, theres was no capacitor there... why? also in my motherboard? it was marked but not placed?
    like this one, see the 3 left capacitors marks? o_o ... mine has 1
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Why there no capacitor here?
    they often use the same PCB for different models. that is why you see motherboards missing components.
    in the video card, what happened was they went to lower esr caps and did not need as many. perhaps my first statement might be the case as well.
    sigpic
    (Insert witty quote here)
    • nanobyte
      • Apr 2010
      • 11
      hmmm k thanks, and what would happen if i add a capacitor in one of those slots? :P malfunction? boom? or just nothing..
      • 370forlife
        Large Marge
        • Aug 2008
        • 3112
        Graphics cards will hardly use the same pcb, but different versions (and therefore different cost) will have different components. Chances are this one is just a simple rebranded reference card that had some corners cut to reduce cost, therefore some of the caps were able to be left out.
        If you want to, very carefully check the voltage at the spots for open caps and you can install some more there. They can help provide more stable power.
        • PlainBill
          • Feb 2009
          • 7034
          Probably nothing. Look to the left of the two 'missing' capacitors. Looks to me like something else is missing - actually two something elses.
          I'd say this pc board was used for at least two similar models with slightly different features. While I haven't been involved in electronics manufacturing for two decades, this sort of thing was very common back then. I recall one PC board that was used in a couple of dozen different models.
          PlainBill
          • nanobyte
            • Apr 2010
            • 11
            i see :0 that makes sense now :P many thanks for all replies !
            • Prolog
              RTX 3080 FE Identifying capacitor
              by Prolog
              Hi people, I hope this is the correct spot to post this, I'm new to the forum.
              I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
              I hope these photos make it clear which component I am referring to:
              (yes, the soldering is a bit botched from removing the blown one, I know)
              I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
              12-01-2024, 08:27 PM
            • chth96
              If I replace with inferior capacitor, Is it No harm to other IC components at all?
              by chth96
              I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
              Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
              It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
              So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
              I know that these capacitor will not last as long as nichicon capacitor...
              12-22-2023, 04:34 AM
            • chth96
              How can I test non-polarized capacitor?
              by chth96
              I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
              I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
              And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
              I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
              06-02-2024, 07:31 PM
            • AllElectronicsRepairs
              Unrecognized component marked on the board as capacitor
              by AllElectronicsRepairs
              Hi All,
              I have 2 unknown (to me) components on the board - one designated as C1 the other as C160, suggesting that they are capacitors. See pictures. I have never seen capacitors like that. Both of them are shorted, none of them has any markings. The board comes from a commercial (heavy road planning equipment) GPS unit. If they are capacitors, they shouldn't be shorted, suggesting that they are faulty. Have no idea about their value. They both have something that appears as 2 blue bands. Any help will be enormously appreciated.
              07-30-2024, 08:34 PM
            • chth96
              Is it no harm to replace with capacitor without ripple current rating?
              by chth96
              When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
              Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
              But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
              Rubycon YK DataSheet (b...
              04-19-2024, 05:19 AM
