question about tv main board processor temperatures
  • bohaboha
    • Nov 2012
    • 973
    • sweden
    Hi,is it normal that the large processor on the TV mainboard has different temperatures ? it is a square the lower part 48c, left side 53c, right side 80c, and top 62c seen from below
  • diif
    • Feb 2014
    • 6978
    • England
    Re: question about tv main board
    How are you measuring the temperatures? Its unlikely something would be 80c next to 42c due to conduction.
    • bohaboha
      • Nov 2012
      • 973
      • sweden
      Hi i an using an infrared thermometer 5 cm to the object
      • diif
        • Feb 2014
        • 6978
        • England
        As you've found out they aren't so accurate if shone onto a reflective surface. Put a piece of matt tape on the area you want to measure and move the 111gun away slighlty as per the instructions.
        • bohaboha
          • Nov 2012
          • 973
          • sweden
          thank you for the answer diif but is it normal with different values on the same chip,I try to find the short on that TV and I happen to put a finger on the mainboard cooling protection in the middle and felt that it was a little warmer I pulled it off and found that value. I will try with your instruction but what is the purpose of putting the tape on the area you want to measure? do that not decrease the value?
          • diif
            • Feb 2014
            • 6978
            • England
            Re: question about tv main board processor temperatures
            As I have already written it is highly unlikely to have a difference of 30c on a processor or anything small. It's measuring inaccurately due to the reflective surface and also its far too close.
            • bohaboha
              • Nov 2012
              • 973
              • sweden
              Aha ok I have misunderstood your explanation, can you say how far from the chip is the right distance? I will measure with TM-902c to see the difference even if the feeling of the fingers is not so bad
              • Dani_2024
                by Dani_2024
                10-28-2024, 05:06 PM
              • jb_Bak
                by jb_Bak
                CN6401
                Pin 01 NC
                Pin 02 NC
                Pin 03 "BL_ON": 0V
                Pin 04 "N/C"
                Pin 05 "STBY 3.3V": 3.5V
                Pin 06 "GND": N/C
                Pin 07 "AC_OFF"...
                09-27-2021, 04:52 PM
              • JDC
                by JDC
                ONN 100012588
                Long answer:
                07-15-2022, 07:39 AM
              • cheeky2
                by cheeky2
                05-25-2024, 03:27 AM
              • advant
                by advant
                02-03-2020, 12:25 AM
