Re: Is there a way to modify a IMAX b6 battery tester version 2 to only monitor volta
using the one DPST relay per cell method, if you turn on more than one relay =
Technically safer to do the DPDT tree (and may save ONE relay if any) but it's a bit more complex wiring. The DPDT tree is inherently safer.
Both require the measurement meter to be completely isolated from the battery pack.
Both of these solutions is still ... sort of my relay based BMS...
