tx2-8fz relay substitute
  • petehall347
    • Jan 2015
    • 4448
    i am trying to find a relay to substitute tx2-8fz as a drop in replacement because i cant find it in the uk and its for a rush job . i have room for 2 separate relays but cant find with same specs . i don't know the capability of whatever drives the coils as most of the board is still buried in rubber stuff so want to keep close to original .
    data sheet here .. https://www.alldatasheet.com/datashe...1/TX2-8FZ.html
    • Jul 2011
    • 6070
    Re: tx2-8fz relay substitute
    You just need to find a single coil at roughly 200 ohms pull in voltage at roughly at 6 volts
    drop out voltage for there specifications are bogus 0.7 volts the lower the voltage the better but do not be to worried about this specific value to much
    I would just find a automotive type relay that is very similar in specifications and try it unless this relay is connected to a computer on this device then you have to have the specifications as close as possible to not have a conflict with the computer
    I found something but the specifications are not the same for the coil voltage pull in voltage and the resistance is not the same but it might work if it is not controlled by a computer or some type of micro controller if it has some type of current sensor device hooked to coil
    https://cdn.badcaps-static.com/pdfs/...b179a1869e.pdf
    Or
    https://cdn.badcaps-static.com/pdfs/...d9faf4d816.pdf
    Please post a picture of the board if you can or what is controlling
    The question I have is this a latching type relay or is it a bidirectional type of relay it does make a difference to use the right type of relay
    Do you know what the difference is between the two types of relays if you do not I can explain the difference between the two different types
    Because I have used both types of relays before
    You can use a normal type of relay for either type of relay mentioned earlier however the results of operation will be some what different for the latching relay type
    A seller on AliExpress has them in stock unfortunately I can not post the link to it
    A seller on EBay has used ones for sale however it is EBay USA website
    I hope this helps you
    • petehall347
      • Jan 2015
      • 4448
      its a dual relay .or rather 2 relays in the same box . looks like we will have to wait for the right one to come from china . i have cleaned the contacts for now so the customer can use the machine for now and bring it back in for new relay fitted .
      its basically same as this but this mower is diesel so has stop solenoid to relay . https://www.orangetractortalks.com/f...o-start.13761/
        • Jul 2011
        • 6070
        Okay thanks for letting me know what it is used for
        • CoinCoin88
          Garage door RX unit (Cardin S38C) does not short relay to send opening signal
          by CoinCoin88
          I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
          Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
          09-15-2025, 03:36 AM
        • edugimeno
          Find substitute for mosfet in servo board of versacamm sp-540v plotter
          by edugimeno
          Hi There!
          I am currently serviciing a plotter versacamm sp-540v
          I found a shorted mosfet labeled J553 which corresponds with SJ-553s (surface mount)
          Neither local stores nor other webpages that are able to provide it before 1 month (only aliexpress, with 1 month delivery) can provide this part
          I need to find a substitute for it. Can anyone give me a hint on a part that I can use to replace it?
          Also, given the schematic Im attaching (pg 36, transsitor Q1) , does it make sense that the whole machine won't turn on when I press the POWER button on the panel? This...
          10-27-2022, 10:46 AM
        • valvashon
          Repair Success! Middle Atlantic UPS2200R-IP
          by valvashon
          Yesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
          Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting...
          02-06-2024, 12:54 PM
          by Vesko356
          08-11-2023, 03:27 AM
          Mitsubishi CNC switching power supply board dead / relay board bad diode failure
          I was working on this CNC machine today found no keyboard functioning no control relay powering on
          The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
          Found shorted diodes on main controller relays there are 3 of them that...
          01-07-2023, 05:43 PM
