glass diode?
  • smittykoi
    • Jan 2010
    • 5
    glass diode?
    Hi can some one tell me what replacment I need for this glass diode plz > http://img412.*************/img412/4665/diode.jpg
    • 31277
    Re: glass diode?
    i *think* it's a 6.7v zener diode.
    • Radio Fox
      • Jan 2010
      • 281
      Re: glass diode?
      Colour code looks like red/purple/green in a SOD-80 (MELF or mini MELF) package.
      That would be an RLZ24B (24V) zener.
      http://www.marsport.org.uk/smd/sod80.htm (scroll to bottom of page).
      ________________________________________________
      Invisible airwaves crackle with life
      Bright antennae bristle with the energy
      • unimatrix93
        TV backlight zener diode
        by unimatrix93
        Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
        So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
        Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
        The led strips has 9 6V leds.
        02-10-2025, 12:13 PM
        NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
        I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
        I bought this from an eBay seller but unfortunately they only had one
        I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
        I bought three of from them to also make battery packs with this output power limit in mind
        I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
        04-23-2025, 05:50 AM
      • nev1001
        What zener diode might fix the sound on Maestro Mayhem gaming chair?
        by nev1001
        Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
        The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
        It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
        I think an issue could be a zener diode (or capacitor) which has shorted out.
        The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
        04-17-2025, 05:09 PM
      • Vincenzo2
        Element 32 inches tv (ELEFW328B) Unknown component: Diode or zener?
        by Vincenzo2
        My Element 32 inches tv (ELEFW328B) lost it's backlight (confirmed with a flashlight test) and the connector on the PCB (it has one board that has a processor chip, switch mode power supply, and backlight circuit) that has the two wires that go to the backlight LED strips has a very low voltage (28-29 volts) when turned ON, in my opinion.
        Started testing components and found an SMD diode or zener that is shorted (even zero fusing resistors read a few tens of milliohms, while this thing reads zero).
        I put some pictures here to show that it is labeled "M7"....
        09-07-2023, 07:43 PM
      • hobostove
        Corsair RM1000e - Help identify 5VSB Zener diode
        by hobostove
        Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
        Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
        There's a 22ohm resistor that's melted and open, but it still has the bands.
        The other part is a zener diode and it's top went to jesus, so I can't read the marking.
        It looks like the diode connects the source and drain of a TNY284...
        03-27-2025, 02:25 PM
