Philips 19pfl3403d/27 Power On Issue
+ More Options
Posts
  • cpu77
    I have 7 Philips 19pfl3403d/27 Lcd's all with the same problem. They work fine until they sit over night. In the morning they will not turn on. Once I unplug them for a hour or so they work fine. Very annoying! I have one good unit and first swapped power supplies. That did not fix it. I then swap video boards that did fix it. Could this be bad caps? I have replaced swallen caps before but none of these "appear" bad, I am thinking of buying the service manual but I have limited electronics experience. BTW if you unplug them at night they work in the morning.
    Ralph
  • ovrax
    Philips 55PUS6804/12 turn on & off (probably backlight issue)
    by ovrax
    First of all, please excuse me as I'm quite new to this field.
    I have a Philips 55PUS6804/12 TV. It turns on and off instantly (backlight flash). I personally think it's a backlight issue (faulty LEDs). Could you help me confirm my diagnosis?
    I've checked and the T-CON seems to be fine. I disconnected one ribbon cable at a time at the bottom, but the problem persists.
    The Ambilight works perfectly and stays on.
    No sounds.
    Thanks in advance.
    08-25-2024, 04:33 AM
  • charlesdutcher
    No picture issue in Philips Chassis FTL2.1
    by charlesdutcher
    My Plasma Philips 37inch chassis FTL2.1 does not show picture. It automatically goes into protection mode after 30 seconds (red led blinks at 3Hz)
    Is there someone having any symptom like this? How to fix it?
    Thanks in advance!​
    08-06-2024, 09:55 PM
  • celiabrown
    Issue with Plasma Philips 37inch chassis FTL2.1
    by celiabrown
    Hello guys,
    My Plasma Philips 37inch chassis FTL2.1 does no picture ,and goes into protection mode after 30 seconds (red led blinks at 3Hz).
    Can someone has any symptom like this ?
    Thanks​
    05-09-2024, 10:56 PM
  • DoOm86
    philips 55pft5500/12 Backlight issue. What am I doing wrong?
    by DoOm86
    TV philips 55'' no backlight (image ok).
    I tested the backlight with my led tester from the unplugged connector cable and it lights up. I had voltages at the motherboard connector, but anyway I order a new psu. Same problem, same voltages. Disassembled the TV and checked every strip with my led tester, they all light up, same voltage for every pair of strip (they go two by two).
    What am I missing?
    And something else I don't understand. I checked and I have 3v Leds, 10 per strips. Why every pair of strip (so 20 Led) take about 32v when powered up with my led tester πŸ€”
    04-16-2024, 03:47 PM
  • Nicktronic
    Philips 75PFL5704/F7 A Video Issue
    by Nicktronic
    Hey everybody, got a strange one here.
    The TV will display the Home Screen, Menus, Netflix Home Screen, YouTube home screen with preview tiles, etc, without issue. As soon as I try to play video (streaming or from any of the HDMI inputs), all I get is audio and and blank screen. It's like the video is not being processed. So I ordered a replacement main board. I can now play video from streaming sources but the video from HDMI sources is all green (kinda like photo negatives but all green) and the audio does not work. Is it possible the main board I ordered is also failing?? I can't...
    10-31-2023, 05:43 AM
