Values of ppm/°C of 2 resistors in parallel
  • Cap_search
    • 29
    • Earth
    First of all Happier New Year to all,
    Dear all, I hope I'm posting this in the right forum.
    Ok, I'd like to know the final ppm/°C of 2 identical resistors in parallel.
    Given two same resistors in parallel of, say, 1Ω (1W), both rated 300ppm/°C,
    I know their resistance will be 0.5Ω (2W), but will their combined tempco
    value also be halved to 150ppm/°C ?
    Or their tempco will be increased to 600ppm/°C ??
    Thank you, any hint would be greatly appreciated!
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8707
    Re: Values of ppm/°C of 2 resistors in parallel
    On the first order, it would be unchanged.
    On the second order, it depends on how you're using them, as resistors generate heat.
    • Cap_search
      • 29
      • Earth
      Hmm, so the tempco remains unchanged. Ok, thanks eccerr0r!
      These are for emitter sensing resistors in a power amplifier (output stage).
      I'm asking because the value required is about 0.5Ω, but I have only 1Ω ones.
      And I thought because they were sharing same duty in parallel, then they could
      be/perform more stable through most loads or powers.
      Probably tempco is not critical in this application area.
      Thanks again! Much appreciated!
