Suggest alternate to LM317?
+ More Options
Posts
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    The only adjustable voltage regulator that I've messed with is the LM317.
    I'm looking for input from people who have any experience with any other adjustable voltage regulators along with any comments as to why you think it might be a better alternative.
    Thank you,
    sigpic
    • 30978
    Re: Suggest alternate to LM317?
    for what?
    the lm317 has a pretty high maximum input.
    whats your input?
    what current do you need?
    • EasyGoing1
      Shock Therapist
      • Sep 2016
      • 977
      Originally posted by stj
      for what?
      whats your input?
      I didn't want to get into the specifics, I was merely looking for alternatives to the LM317 and whether or not anyone had any experience with different adjustable voltage regulators.
      sigpic
        • 30978
        there are lots,
        that's why i asked.
        these days i prefer to play with chinese buck modules - just to avoid heatsinks.
        • PeteS in CA
          • Aug 2005
          • 3579
          • USA, Unsure of Planet
          The LM317 (and the LM337, for negative voltages) is one of those parts that works too well to be obsoleted. Easily adjusted for a fixed voltage or with a pot for adjustable voltages. You can even put a cap across the adjustment resistor that connects to ground if you want to control the output voltage rise.
          PeteS in CA
          • EasyGoing1
            Shock Therapist
            • Sep 2016
            • 977
            there are lots,
            that's why i asked.
            I do too ... but you can't vary the voltage with a microcontroller with one of those. With an adjustable regulator, you can use a digital pot and vary the voltage as needed.
            sigpic
              • 30978
              i'm not so sure about that claim.
              • EasyGoing1
                Shock Therapist
                • Sep 2016
                • 977
                I've done it.
                sigpic
                  • 30978
                  i meant not being able to tie an mcu to a buck module
                  • yuii
                    ThinkPad W530 - faulty CPU regulators?
                    by yuii
                    Hello
                    I've got two W530 boards, one with K1000M and one with K2000M graphics card. The first one had an issue of turning off under heavy CPU load after about 30 minutes or in idle. GPU load wasn't causing it to shut down. Trying to turn it back on would only make the power LED to come up for about 2 seconds without fan spin or thinklight flash, and that's it. It also wasn't charging the battery after it died.
                    Gently pressing the laptop in left upper corner would fix this problem for a couple of days.
                    The latter is completely dead and has the same 2-second power blink, nevermind...
                    11-01-2023, 02:59 AM
                  • seweryn
                    Dell 2007FPb with 4 buck step-down regulators
                    by seweryn
                    I have monitor Dell 2007FPb. It was working good. Some day it was shut off and stay dead.
                    I checked some voltages on the boards. I read this thread:
                    https://www.badcaps.net/forum/showthread.php?p=335335
                    and very usefull budm posts ( thanks buddy, it was great work ... ).
                    My damage was typical: 3A fuse burned and ZD701 diode was shorten.
                    So my board is in few points different than other described in citing thread. On my board are 4 buck converter regulators. Apart regulators 3.3V (Q6), 5V (Q14), 12V (Q9), is ther fourth, build on MOSFET Q2. Two TL1451 has together...
                    04-08-2022, 11:43 AM
                    Adjustable Boost Power Supply DC-DC Constant Voltage Current Charging Module
                    I want to know if I could hook up a solar panels to this boost converter would I have any issues doing and I would have issues what would they be
                    https://www.ebay.com/itm/116497313155?var=416785404161
                    Here are some of the description from the eBay seller
                    The main parameters:
                    1. Product name: High-power non-isolated DC boost module power supply.
                    2. Product model: 100A2000W.
                    3. Input voltage: DC12V-60V.
                    4. Input current: 100A (maximum)....
                    05-18-2025, 09:45 AM
                    Texas Instruments TPS51427ARHBT TPS51427ARHBR Dual D-CAP Synchronous Step-Down Controller for Laptop Computers
                    The TPS51427A TPS51427ARHBT TPS51427ARHBR are dual synchronous step-down controllers designed for laptop and mobile communications applications. This device is part of a low-cost suite of notebook power bus regulators that enables system designs with low external component counts.
                    The TPS51427A includes two pulse-width-modulation (PWM) controllers, SMPS1 and SMPS2. The output of SMPS1 can be adjusted from 0.7V to 5.9V, while the output of SMPS2 can be adjusted from 0.5V to 2.5V. This device also features a low-dropout (LDO) regulator that provides a 5-V/3.3-V output, or adjustable...
                    10-23-2024, 02:37 AM
                  • EasyGoing1
                    Issue with LM317 and current draw
                    by EasyGoing1
                    I'm supplying a LM317 that's configured for 5.0V output with a source voltage of 7 volts. The LM317 is supplying power to a 5 volt sensor. The sensor is drawing 110ma of current, but the LM317 gets really hot and when i check the current draw from the 7V supply to the LM317, the LM317 is drawing a little over 400ma ...
                    This means that the LM317 is consuming almost 3 times the energy that it's supplying.
                    Is this normal for a LM317?
                    03-28-2019, 01:03 PM
