Car Ammeter
  • barry wilkins
    • Aug 2009
    • 172
    Car Ammeter
    After a number of expreiments I gave up the torroid idea.
    Could not over come the zero problems ,it has to be the B/H curve the flux in the ferrite does not return to the same point ,so after the first current you get an offset which must remanence .
    I did think of a flux gate like you can have a compass ,a coil wound all the way around the coil and is energised, this might degauss the core but I dont know
    I had a request for help from abroad out of the blue ,so I had to dig out some info on elemental anlysis , I found my origonal notes from years ago I did on My Honda car measuring the voltage drop from battery to the earth point .My tests made the resistance to be 15 milliohms.
    Interstingly on My Citreon C3 there is awire connected to the negative post on the battery, there is a economy mode on the car wich switches off the power after a while when the engine is not running.
    I might look into this a bit later on and find out what it is.
    Barry
  • redwire
    • Dec 2010
    • 3910
    Re: Car Ammeter
    That's too bad a Hall-effect current sensor did not work out. It's what the DC clamp-on ammeters use, some even go to mA level. I have had those get magnetized jaws and then the readings get "sticky" so it reads OK in one direction but the other direction reads way low because the ferrite is magentized in the opposite flux polarity. After I demagnetized them they work better. You could also try using more turns?
    15mV/A means 150mV for 10A with a gain of 10 should be good to use.
      • Jul 2011
      • 6046
      Re: Car Ammeter
      Barry
      You might be interested in this product
      https://www.allegromicro.com/en/prod...sor-ics/acs772
      I have used this product in the past and the results are decent
      You do have to use a micro controller with this device to get best results
      You can use it with out the use of a micro controller but you would have to do the math
      100 amp version / 5 volt scale = 20 amp per volt output
      This is what I found when I used this device in a application that I was doing
      One note if your output voltage value reaches 4.5 volts and higher the accuracy is not quite as good the lower the output voltages the more accurate it is
      Also at voltage output less than 0.50 the accuracy is also less accurate
      But overall the accuracy of the device is decent for the price of the device
      This was at the time that I did this project
      • chth96
        Is it good to use chemistronic flux off es835b for flux remover?
        by chth96
        I want to purchase any good flux remover But "chemistronic flux off es835b" is the most common flux remover in my nation..
        Or I have to purchase "3m novec flux remover" which is quite expensive in my nation?
        11-17-2023, 07:25 AM
      • caspian
        Can Ammeter damage Power Supply?
        by caspian
        Dear Members,
        My DC linear Lab Power Supply does not display the current and voltage correctly. Thus, I am going to connect an Ammeter/Voltmeter Module to the DC output of the power supply. Then, a load will be connected the takes about 1-5volts with 0.1-1.5Amps.
        But I heard If I connect an Ammeter to the output of the power supply, then the Ammeter module is not isolated from the power supply so that the Ammeter can damage the power supply.
        Is this true?
        I have attached the photo of a sample Ammeter module that I am going to buy....
        06-05-2022, 01:42 AM
        Multifix 425-01 and 450-01 Rework Flux Datasheet
        REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
        - No Clean Formulations
        - Low residue
        - Range of activity to deal with different component solderability
        - Halide free
        - Suitable for dispensing
        - Compatible with solder coatings and/or No Clean flux cored solder wire product range
        Both products are supplied in syringes or cartridges for application by dispensing....
        10-07-2024, 06:02 AM
      • evilkitty
        Flux causing high resistance short?
        by evilkitty
        Now that my de-soldering gun is working i was able to remove this panel i made about a week before i noticed a issue the F segment of digits 2 and 3 would go out, digit 2 would go before digit 3, but would come back after the humidity got down from running the ac (note the weather outside is 30.5 / 74%; panel data is from a BME280)
        Temp is on the left humidity is on the right
        i noticed when the humidity got up one or 2 of the center digits on the right panel would loose a segment
        The pin out looking down from the top is (note this is common cathode)...
        07-17-2024, 09:38 AM
      • chth96
        How can I remove flux with the smallest rubbing?
        by chth96
        I have tried to bridging tiny broken trace which is shown in the below link,and I found that it is impossible to remove any flux after soldering task.
        Is it possible bridging tiny broken trace - Badcaps - Capacitor Search Engine​​
        Because the 0.02 mm copper wire is very very fragile,So It broke itself very easily whenever I tried to rub excess flux with cotton bud.
        Is there any way to remove flux with the smallest rubbing or without any rubbing?
        Any reply would be appreciated.
        11-24-2023, 05:22 PM
