Oscilloscope Advice....
  • SolomonMan
    • Apr 2019
    • 206
    Re: Oscilloscope Advice....
    All,
    Thanks for the advice...
    Can someone chime in where (due to my limited experience and this being my first Oscilloscope (to be used) where the 2 channel vs 4 channel are used mostly/will be adventageous commonly.
    Meaning I would assume that the 2 Channel vs the 4 Channel allows me to look at more electrical signals...but I watched a youtube video that mentions that some oscilloscopes the channel number limits the ability to examine the signal fully.
    Is that going to be a issue?
    Also the unlocking is that difficult?
    What is it exactly?
    Chris
      • 30985
      on the Z series unlocking is very easy,
      you get the serial number, put it into a bit of software i can link, and it gives you the unlock code to type in or send over ethernet to the scope.
      the advantage of more channels with digital signals should be obvious, and you can monitor serial memory chips and decode the data.
      the advantage with analog stuff is you can monitor a signal in mutiple places to see where it's failing.
      for example you can monitor the input, output and a few places in between on an audio circuit to find the source of noise.
      it's also handy if what you buy can network over ethernet.
      you may find these handy:
      https://lxi-tools.github.io/
      https://www.youtube.com/user/RigolTech/videos
      • SolomonMan
        • Apr 2019
        • 206
        All,
        Ended Up Purchasing a Rigol DS1054Z....Now to wait for it to travel the roughly 300 miles to my home.
        Chris
          • 30985
          once you get it, i can walk you through unlocking it to 100Mhz and enabling extra stuff - if it's not already on.
          dont follow information about doing it with the front panel - it's a pain.
          over ethernet is very easy.
          • SolomonMan
            • Apr 2019
            • 206
            STJ/Everyone,
            The Oscilloscope (Rigol DS1054Z) has arrived...There was some delay in shipping for delivery...so I picked it up from Fedex directly...Its next store to where I work.
            I have some reading to do...
            Chris
              • 30985
              well get it on your network.
              here's some stuff from my notes:
              To see the full info you need to press these buttons (fairly quickly or it doesn't work):
              Menu -> Menu -> Force -> Menu -> Utility -> System -> System Info
              Connect to your router by ethernet cable, then select
              Utility>IO Setting>LAN Conf.>Configure> select DHCP, then "Apply" and "Initialize"
              The scope should fetch an IP address from the router and put it in the box in the LXI window. Write down this IP address.
              The Rigol communication port is 5555. So: in a Terminal window command prompt, enter
              telnet IPaddress 5555
              (insert your own scope's local IP address that it fetched from your router)
              opens the telnet application and contacts the scope on port 5555.
              Then send
              *IDN?
              and the scope should reply with its identification.
              Then you can send any of the SCPI commands in the Programming Guide, control the scope's functions remotely, and install or uninstall the unlocking codes using the SCPI commands:
              :SYSTem:OPTion:UNINSTall
              :SYSTem:OPTion:INSTall and your 28character key without hyphens
              to close the telnet connection and exit the telnet program enter:
              ^] close
              (The "^]" means to hold down the Ctrl key while pressing the ] key, this is the "escape" character that puts telnet into command mode.)
                • 30985
                btw, latest firmware is: v00.04.04.04.03
                • SolomonMan
                  • Apr 2019
                  • 206
                  STJ,
                  So I updated the firmware....From Rigols Site.
                  Had some issue getting telnet to work...not sure if it was my network or not...I am a Adhoc Wireless setup...I have used telnet and ftp daily for almost 5 years in my college years to get code to the proper servers....but I had to tie directly into my router and I am wondering if its limited/secured.
                  Anyways, found a recent youtube video using Google Advance Search.
                  https://www.youtube.com/watch?list=P...le&app=desktop
                  Then used the site to get Key;
                  http://gotroot.ca/rigol/riglol/
                  I had a little issue originally as I left the "...." in the end of my Serial.
                  Used the DSER Option as it seemed suggested everywhere.
                  Then entered the Private Key and below is what I see now....I believe I am all set?
                  Thanks STJ and all for the help with this purchase etc.
                  Chris
                    • 30985
                    that's it - your all set now.
                    did you do a "self calibrate" after the update?
                    • SolomonMan
                      • Apr 2019
                      • 206
                      STJ,
                      Not as of yet...still trying to get into the Manual...Wife is sick (flu now) and her dads not doing well...so my plate is a little full...
                      I will try and read how tonight.
                      Chris
                      • SolomonMan
                        • Apr 2019
                        • 206
                        Originally posted by SolomonMan
                        STJ,
                        Chris
                        Did the Self Calibrate and everything is Successful (Calibrate takes a while)...Now to use this on something and learn how to use it....
                        Thanks everyone for the help,
                        Chris
                          • 30985
                          adjust your probes and your good to go.
                          best wishes to your family.
                          • Tarot Superstars
                            How not to Damage an Oscilloscope
                            by Tarot Superstars
                            Hello.
                            I have jut got my first analogue oscilloscope. An Isotech 620 20MHz.
                            I want to learn how not to damage it, and I found instructions on the internet obscure.
                            They talk about ground, earth, floating ground, this, that....
                            But they don't actually say anything anything useful so far.
                            I want to know:
                            Don't connect exactly this to exactly there or it blows up.
                            For example, I am tracing a signal from a function generator in an audio amp, or testing for voltages in different parts of a circuit.
                            I want to know what not to connect...
                            08-29-2023, 02:27 PM
                          • Evets
                            Dynamco analogue oscilloscope
                            by Evets
                            I have recently acquired a Dynamco D7100 analogue oscilloscope without a user manual. As this is the first time I have owned or used an oscilloscope I would like to try and find an instruction book. The manufacturers no longer hold any information and a Google search only found one site but when I downloaded a 'service manual' all I got was gobbledegook. Any help would be gratefully appreciated or even pointers to a generic manual where I could learn more.
                            08-30-2024, 06:54 AM
                          • Borse2008
                            by Borse2008
                            • There’s
                            07-15-2025, 04:55 AM
                          • Green Probe
                            Mosfet Advice
                            by Green Probe
                            Hi, Im looking to replace some EMP21N03 mosfets on an Alienware motherboard, but I'm having trouble finding a legit supplier. The ones that are available from China have pictures with the engraved logo looking very scratchy and sketchy. Nobody in the US sells them. I'm trying to find a compatible mosfet, but I'm not well versed enough to be confident im making the right choice. Does anyone have a suggestion or advice that could help me find the right mosfet? Thanks!
                            05-22-2025, 10:49 AM
                          • user234
                            Gigabyte Eagle 3060 Ti - Boardview / Advice request please
                            by user234
                            Recently installed a new motherboard but during the process I seemed to have damaged my Gigabyte Eagle 3060 Ti card.
                            My motherboard ROG STRIX B550-A is detecting an issue with the VGA (light ON)
                            I have attached 2 photo's of my GPU board, one above and the other is what I believe to be the 5V - as you can see, this has visual damage so looks suspicious to me.
                            If I replace this part what are the odds this will resolve the issue? - any additional information on where to source the parts would be much apricated too!
                            This is...
                            05-10-2025, 04:25 AM
