Ring Doorbell Solar Panel Battery Pack Modified
    • Jul 2011
    • 6070
    I bought a Ring Doorbell 2 during Black Friday sale for my drive way but there is no wall outlet near unless I drill a hole in wall
    So I did a google search and found they have a non vendor solar panel and a battery pack but the reviews all said the same thing about about the solar panel connector going to the battery pack that it is easily broken because it is made on plastic circuit board which is very thin the battery pack is a hole another story in it self
    The batteries are a non brand battery that I have never heard of but the battery case was done very nice in that the circuit board snapped into place and the battery connector also snapped into place the down fall was that this connector was also made with plastic circuit board
    So here is where the hack comes in play I remove the batteries from the battery case and ran the wires to the outside of the case and ran the solar panel wires in side the battery pack case
    I took the the plastic circuit board from the solar panel plastic circuit board which went to a very small regulator circuit board which has a diode which I put in the battery pack case as well
    Once I made sure that the solar panel worked the protection board and would change the batteries and the USB charging cable would charge the batteries and that the Ring Doorbell 2 unit worked I hot glued the battery pack case back together with plenty of hot glue and made it weight almost as much as it did before I took it apart
    Now I have to find a waterproof 18650 battery pack case
    Does anyone know where I can find a two cell case I can find a 4 or a 6 cell case but not a 2 cell one unless I want to use a 2 cell 26650 battery cell pack case which would rather not do unless I have too
    I will show a couple of pictures later on today unfortunately I did not take pictures of the inside of the battery pack case but I do have another battery pack that I going modified as well and when I do this one I will show pictures of it
    • 31278
    Re: Ring Doorbell Solar Panel Battery Pack Modified
    just set it up, press the button and ask the NSA to come round and fit it for you!!!
    normally when government wants to put a camera on your property they pay you btw - you dont buy it from them!!!
      • Jul 2011
      • 6070
      This is my project not the government mandate if that were the case I would have told take this request and shove it were the sun dose not shine
      Lately I have had people come down my driveway when not invited and I am not home and I can not see who it is until they get to the front door and trigger the alarm door bell camera and it alerts me
        I never setup Ring or Arlo before. Do you have to do any port forwarding?
          • Jul 2011
          • 6070
          No all you have to do is put the app on your phone or tablet and it take a few steps and you are ready go
          One note you do have to setup an account with Ring but this is pretty easy to do as well
          You might have to play with the setup of the WiFi a little bit on a Android phone because it gives a little trouble but even that was not to bad
          • redwire
            • Dec 2010
            • 3912
            Something is storing the video...
            Ring Ltd. shares package thieve/porch pirate video to law enforcement, so it is getting popular. They want to add AI for facial recognition.
            There's lots of "18650 waterproof case" used for bicycle lighting and camping, if if this will work.
              • Jul 2011
              • 6070
              I have looked but I can not find any 2s battery waterproof case
              I can find a 26650 2s battery waterproof battery case
              I would rather find a 2s battery waterproof case for 18650 but I might have to settle for a 26650 battery case
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8706
                "they" are storing the video, your equipment does not hold onto the video past a short while... No port forwarding needed, everything is out to their server "just to be convenient" ...
                • brispuss
                  Ryobi 36V (aka 40V) 6Ah Faulty Battery Pack
                  by brispuss
                  Purchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
                  Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
                  I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),...
                  12-28-2022, 02:58 AM
                  Brother “P-Touch” PT-2040SC modified with metal hydrate AAA 700 milliampere hour battery pack originally for cell phone
                  I have gotten so tired of battery cells leaking and it happen to this device and it is not very old I had bought these battery packs from The Electronic Goldmine for $1.00 a pack when they had a sale and I am putting 3 packs to good use so I do have to deal with leaking battery cells I am over it
                  I bought the label maker at Sam Club a while back for $29.99 it come with 4 cartridges and they had them on sale again for $29.99 again so I bought another one because I was not sure if I was going to able to get it to work on the battery cells that I had planned on using for this particular...
                  05-26-2024, 10:44 AM
                  Kobolt battery pack modified with a Boston battery pack case
                  I modified a battery pack module controller to work on much bigger battery pack
                  But things did not go very well at first because the temperature sensor wire are very thin and very hard to clean the soldering joint hole I had use another board and attempt to repair this board later if needed for another project
                  Because the temperature sensor wires are very short and had to be made longer
                  which the second attempt when a lot better
                  This is for my Ksger t12 soldering iron station
                  The Kobolt battery pack charger was modified to charge this...
                  12-30-2020, 06:23 PM
                  MSI Infinite A VR7RC-003DE + Gaming Pack Infinite i5-7400 Specification for Upgrade or Repair
                  This specification for the MSI Infinite A VR7RC-003DE + Gaming Pack can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Infinite A VR7RC-003DE + Gaming Pack boardview and Infinite A VR7RC-003DE + Gaming Pack schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                  09-12-2024, 03:28 PM
                  ACER Aspire AspireRevo R3600 + Gaming Pack Aspire 230 Specification for Upgrade or Repair
                  This specification for the ACER Aspire AspireRevo R3600 + Gaming Pack can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire AspireRevo R3600 + Gaming Pack boardview and Aspire AspireRevo R3600 + Gaming Pack schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
