This Black-Web battery power supply for tablets and phones with a twist
    • Jul 2011
    • 6070
    I have bought quite a few these from Walmart brand Black-Web battery pack quite a few times before (with the four LED light that indicates charge level runs on 4.2 volts ) but this one is a little different ( this one has the percentage of change which runs on 8.4 volts ) in 95% of them run off of 4.2 volts but this one runs off of 8.4 volts
    One note I have two of them and I would not recommend taking them apart until you run the battery pack down to 0%
    This is going to make a project that I want to do is going to be a lot easier with this power supply board
    One note the battery packs that run off of 4.2 volts has a plastic housing
    ( easy to take apart )
    The battery pack that runs off of 8.4 volts has a aluminum ( housing this battery pack is very hard to come out because of the glue that they use to keep the battery in place )
    You have to cut the front of aluminum case a long each side in the middle of the rounded sides ( not to deep into the case just enough to cut the metal ) about a 1/4
    ( this is with two 18650 in series as a guide from the end that does not have the display )
    of way down on each side and pry on top of plastic circuit board case until you can see that the glue has released from the case on top and bottom of the batteries
    ( the end that has the display board )
    to release the glue so batteries can come out you MUST take your time doing this step and not be in a hurry or you will have an accident if you are not careful the one nice thing about the way they put this circuit board it is in a plastic case this the only reason I try to get it apart
    • Jul 2011
    • 6070
    Re: This Black-Web battery power supply for tablets and phones with a twist
    I took the second battery pack apart and this one was a lot faster to come apart because I learned from the first one how to take it apart
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8706
      Sigh.
      I might have to get another one of these things. I had one but accidentally fed in 19V into the charging port that requires 5V... Not sure what got damaged but it's totally toast now, though there's no visible damage to the components.
      If I get another, I'm not sure if I'd care if it's 4V (1S) or 8V (2S) pack. I don't mind the linear LED fuel gauge, the 7-seg doesn't do much for me.
        • Jul 2011
        • 6070
        I am going to check the accuracy of it when I get some heat sink tubing that fit these 26650 batteries but it will not be until the end of week before I get to the battery place that I buy this stuff from
        Unless I decide to use some pouch type batteries that I have if I can find a case for them
        There is a difference between the 1s verse the 2s version and it is the amount of current it put to the USB output connector to your tablet at least for the IPad the IPhone it does not make any real difference
        One thing you might be interested in is that the batteries say that 3350 milliamperes well not exactly but close I tested two of them and got 3029 and 3085 which very good for non brand batteries
        This was the pack that I took a picture of that I posted above
        One note
        You do not have to cut the aluminum case in the center along the side but you do have to use a couple plastic knife and put it in between the battery and case and pry up on the knife to the top and bottom of the case with a small screwdriver carefully and then you can push the batteries out it does take some time to do this so do not be in a hurry
        You can see if the glue has released from the case if you shine a light inside the case
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8706
          Well, the 1S configuration, discharge needs to boost to 5V and (optionally) buck to charge from 5V.
          For the 2S configuration, one needs to buck to 5V for discharge, and boost from 5V to 8.4V to charge (if they use 5V charging).
          So the 1S should be cheaper if they used an LDO regulator to charge, but not sure if it's that much worse. However as usual, more volts is usually more efficient, so perhaps you get a bit more life out of a 2S configuration for the battery capacity?
            • Jul 2011
            • 6070
            Update
            Build a 13 amp hour battery pack with the Black Web battery pack module in a Ryobi 40 volt battery pack housing which had to be modified to fit the battery pack module
            I also bought a ZKE USB + tester that use the same software as my bigger battery tester
            I ran a test on this battery pack and it has ran over 13 hours at 1 amp load
            I tested the battery pack and the battery tester and both test went very well
            One note the specifications that the original battery pack says was way off
            The battery pack had 3 cells per bank / 2 banks total that were a little bit fatter than a 18650 battery each cell was a little bit more than 3 amp for each cell for a total of about 9 .5 amp hours I do not know where they get 20 amp hours
            I used 18650 batteries 5 cells for each bank each battery tested at a little bit over 2.75 millimeters hours each
            I will post pictures later
            I built this battery pack to charge my phone and tablet from a remote location when working on machines at work
            Hopefully I will find a job soon but it has given me time to work on some projects that I did not have time to work on
              • Jul 2011
              • 6070
              Update
              Well the load test is completely done and the results are in the picture
              One note I got a little bit tried of waiting for it to shutoff so I went to 2 amps at the very end
                • Jul 2011
                • 6070
                Here is a couple of pictures of the battery pack and the tester
                This is taken while the tester is in the charge mode
                Here's is picture of the data so far as the charge statue is with the battery pack being at 15% charged
                The blips that you see at right hand side of the screen is when I move the charger back and forth
                  • Jul 2011
                  • 6070
                  Well the testing is done and the results are what I was expecting to get with brand name batteries that were used
                  So this project is completely and finished
                  I am happy with the results
                  The testing of the batteries took the longest part ( time wise ) of this project ( 2 batteries at a time )
                  Welding of the batteries took some time as well
                  Testing of the battery pack also took some real time to complete
                  So from start to the finish it about a week and half to complete
                  • brispuss
                    Ryobi 36V (aka 40V) 6Ah Faulty Battery Pack
                    by brispuss
                    Purchased a Ryobi 36V 6Ah battery pack maybe just over a year ago.
                    Battery pack had been used on about 3 or 4 occasions for powering a cordless lawnmower. I was wanting to use this battery pack again recently, but on checking the battery charge state via the battery pack test button, there was no LED indication at all of charge state which suggested the pack was fully discharged.
                    I found this to be odd as I usually fully recharge battery packs shortly after use. So either the pack developed some sort of fault which completely discharged the pack cells (after recharging),...
                    12-28-2022, 02:58 AM
                  • razenxd
                    How can I charge that battery pack?
                    by razenxd
                    it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                    At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                    Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                    Now, I have noticed a few things.
                    The "dead" battery, while connected to charger and NOT Charging will...
                    12-05-2024, 06:11 AM
                    NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                    by sam_sam_sam
                    I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                    I bought this from an eBay seller but unfortunately they only had one
                    I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                    I bought three of from them to also make battery packs with this output power limit in mind
                    I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                    04-23-2025, 05:50 AM
                    Cyber Power ST625U Battery backup battery when bad so I going A123 type battery pack
                    by sam_sam_sam
                    I have had this battery backup for at 2 to 4 years now and the battery when bad and this is weird battery size it is the same length as a 12 volt @ 7 amp hour battery however the depth of is not the same as a 12 volt @ 5.5 amp hour battery
                    I have several battery packs that are A123 batteries cell so I bought a lipo4 BMS balancing protection board for these batteries and I have a configuration that is 4S 3P these battery packs were 3S 2P so I reconfigured them but left the tabbing on one side of the battery row of battery cells and re-tabbed the other side to the configuration that...
                    06-18-2023, 05:48 PM
                    Brother “P-Touch” PT-2040SC modified with metal hydrate AAA 700 milliampere hour battery pack originally for cell phone
                    by sam_sam_sam
                    I have gotten so tired of battery cells leaking and it happen to this device and it is not very old I had bought these battery packs from The Electronic Goldmine for $1.00 a pack when they had a sale and I am putting 3 packs to good use so I do have to deal with leaking battery cells I am over it
                    I bought the label maker at Sam Club a while back for $29.99 it come with 4 cartridges and they had them on sale again for $29.99 again so I bought another one because I was not sure if I was going to able to get it to work on the battery cells that I had planned on using for this particular...
                    05-26-2024, 10:44 AM
