LED modifications that have a warning...why?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Well it goes without saying but you shouldn't modify electronics at the risk of causing unintended consequences. However I saw an explicit warning to purchasers of an LED bulb saying this:
    "Caution: Changes or modification not expressly approved by the party responsible for compliance could void the user's authority to operate the equipment"
    Then it goes on to say that it meets FCC part 15 rules, class B, which it should.
    Now the question that the warning leads to... What modification are they talking about? What magical modification would make the LED better? Were people making LEDs into broadband noise makers or something, but why now and not with CFL bulbs? Why isn't this warning on other consumer equipment, heck, radio transmitters, CB, FRS, etc., which are more obvious?
    • Jul 2011
    • 6057
    Re: LED modifications that have a warning...why?
    What product was this on I would like to know
      • 31139
      in some country's the communists are getting touchy now about Power Factor.
      maybe that's it
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        This was on an individual LED light bulb 60W equivalent (8W used), an A19 replacement with E26(?) medium base.
        The Power Factor clause is a good guess, but how would it benefit the end user?
        Strange eh?
          • 31139
          nothing ever benifits the end user - they dont give a fuck about us.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            Then why put the warning that would discourage purchasers?
              • 31139
              because poor power factor costs the power company.
              in short, we are being blamed and penalised for the fact that their infrastructure is not designed to handle non-unity power consumpion.
              and yet *they* are the fuckers that told us to use switching psu's and "energy saving" lamps!
              they need to switch to DC high voltage distribution with substation inverters supplying AC over the last mile or less to the user.
              the tech exists and is comercial - it's also cheaper if starting from scratch - but they arent starting from scratch.
              • redwire
                • Dec 2010
                • 3912
                The warning is a mandatory (user manual) requirement by the FCC. It appears on everything, from wireless headphones, radios, led light bulbs...
                It seems to be saying if you change cabling on your product, it could upset the product's (passed testing) "unintentional radiator" and cause (new) interference that is your problem.
                For an LED light bulb, you don't know how long the wiring to it is. If FCC testing is 1m/3ft and in your house it's 5.1m/17ft or something that is a wavelength of some radio station, your LED light bulb can end up transmitting RF hash now - yet it passed testing.
                Grid power factor is usually lagging, so they need to add capacitor banks to help correct it. It's a bit of a substitute for ever increasing loads on old infrastructure. I worked on projects adding cap banks to substations, the caps and breakers are very expensive.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  but what can you do to the LED that would ruin its power factor and make it work better for the end user? I don't see a mod that would make the LED work "better" while sacrificing PF?
                  Yes, this is what I would expect. Why I don't see this warning on everything is what bothers me - this is the first time I saw something like this, and on a silly LED bulb no less!
                  I would have to think that anything that needs some sort of FCC approval, whether it's part 15 or part 95, must have this warning. Perhaps it was a recent rule that was added and I should expect to see this more often?
                    • 31139
                    if you have a switching psu with a single diode and you swap it for a bridge rectifier you increase efficiency but alter the Pf
                    changing the cap value in a dropper to effect brightness can also change the Pf from the original spec.
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8701
                      That would increase PF
                      I don't know how much of one you'll get in todays ultra-optimized designs, and may even need to consider lifetime, some LEDs are cutting corners to get maximum brightness as it is.
                      I was wondering about two dollar store LEDs that are at 100W equiv (14W) and a 60W equiv (8W). The rated lifetimes of each are 15000h and 25000h respectively. I wonder how much of that 100W equiv bulb was due to overdriving the LEDs to get higher brightness considering the lifetime is lower?
                        • 31139
                        i wouldnt use led lamps over 6w unless they are the filament-style.
                        the traditional smd led ones generate too much heat.
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8701
                          not sure it matters, conduction into the metal plate and then radiation, vs direct radiation into air/freespace... tough to call which is better as both would need to dissipate the same amount of heat. Personally, if I can feel the heat on the outside of the bulb, it's heat that's not stuck inside the bulb.
                          I think the filament style seems more for the nostalgia, people like seeing the filaments, reminds them of old fashioned bulbs that didn't wind the tungsten into a small spiral because the technology wasn't available. Me, I don't stare at light bulbs, same reason why I don't stare at the sun...
                            • 31139
                            no, the filament style generate less heat because they use dozens of series leds and almost reach line voltage so they need hardly electronics.
                            i'v run several filament lights and then unpugged them and felt the base to compare against the other type.
                            the filament ones just ran warm - the others got the base too hot to hold.,
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              It would depend on what kind of chips they have, but I'd imagine to keep the price down they would have to use run of the mill chips and for the same amount of light they'd have to dump the same amount of heat.
                              • Petr0x
                                Bosch 12V and 18V chargers modification
                                by Petr0x
                                Hi, I would like to share with you small modification to your Bosch tool 12V and 18V chargers.
                                You can use it for almost all Bosch chargers what I have seen, for example part numbers GAL 18V-20, GAL 18V-40, GAL 1880, GAL 18V-160, AL 1820, AL1115CV, AL1130CV.
                                Bosch (today also other brands using the same system like Wurth, Fein) does not care if you destroy your batteries, because they can sell you new ones. So the marketing is telling you only about speed of the charging, so you will not wait for your batteries to charge too long. Me as a customer want the tools and batteries...
                                05-24-2024, 01:00 PM
                              • Teban1306
                                [REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
                                by Teban1306
                                Hello everyone!
                                I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
                                System Information:
                                • Model: Lenovo ThinkPad T14 Gen 1
                                • Machine Type: 20S1S4E600 (Intel i7 variant)
                                • Current BIOS: N2XET42W (1.33) - Latest version
                                • BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
                                What I'm trying to achieve:
                                Replace the default "LENOVO" boot logo with a custom image during POST.
                                🔧 What I've tried:
                                09-14-2025, 11:49 AM
                              • BOSCHNJAK
                                by BOSCHNJAK
                                ABOUT ME INTRODUCTION FILE
                                2
                                024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
                                2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
                                2022 BEV, PROJECT ?
                                2021 BEV, PROJECT ?
                                2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
                                2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
                                12-28-2023, 02:09 PM
                              • long678
                                Surface pro 7 Bios Modification
                                by long678
                                Hey Admins,
                                I’m requesting a modification of my BIOS region dump to unlock every possible hidden setting, advanced configuration, and all performance-related options—basically everything locked down or restricted by default, including power management, CPU and GPU tuning, thermal controls, overclocking features, and any other performance tweaks.
                                Please disable all power management features like Intel DTT, TDP, DTFP, and everything similar to those. Also disable thermal throttling, but keep thermal protection enabled to prevent hardware damage.
                                Also, is...
                                07-31-2025, 06:09 AM
                              • Califauna
                                Help with boom box modification
                                by Califauna
                                Hi, this is more of a project help request than a troubleshooting question. I hope I can post it here.
                                I have a W-King D8 Bluetooth boom box which I'd like to modify with some external speaker output jacks and some buttons to switch the internal speakers on and off.
                                From factory the specs of the boom box are:
                                -Power Input: DC 5V
                                -Speaker Output Power: 2 x 25W ( confirmed by Youtube channel Hartdegen review as 12.5W RMS per channel)
                                -Drivers:
                                -2 x Woofer, 70mm, 10Ω, 70mm,15W
                                -2 X Tweeter, 8Ω, 30mm,10W x 2
                                -Frequency...
                                12-04-2021, 01:53 PM
