Surface pro 7 Bios Modification
  • long678
    • Jul 2025
    • 7
    • Cambodia
    Hey Admins,
    I’m requesting a modification of my BIOS region dump to unlock every possible hidden setting, advanced configuration, and all performance-related options—basically everything locked down or restricted by default, including power management, CPU and GPU tuning, thermal controls, overclocking features, and any other performance tweaks.
    Please disable all power management features like Intel DTT, TDP, DTFP, and everything similar to those. Also disable thermal throttling, but keep thermal protection enabled to prevent hardware damage.
    Also, is there a method to bypass Flash Descriptor locks, BIOS write protection, and Intel BootGuard?
    Device details:
    • Surface Pro 7
    • UEFI 23.101.140
    • Intel ME 13.0.2436.2
    • Ice Lake
    • Serial Number: 017511610853
    Thanks a ton!
  • shiyab
    • Sep 2023
    • 1540
    • india
    Originally posted by long678
    Hey Admins,
    Device details:
    • Surface Pro 7
    • UEFI 23.101.140
    • Ice Lake
    Thanks a ton!
    hi try
    • long678
      • Jul 2025
      • 7
      • Cambodia
      Originally posted by shiyab
      hi try
      are you sure its not gonna brick please double check because i got no recovery option i mean i can use the CH341A but im not experienced
      can you guide step by step?
      • FalconPunch
        Surface Pro X 1876 Bios corrupted
        by FalconPunch
        Hello everyone, I happen to have a Microsoft Surface Pro X 1876 in my hands. It was brought to me by a friends which happen to have taken off the bios chip to test another motherboard. Upon putting back the bios chip on the original motherboard, The PC is stucked on Windows logo and won t boot to bios or anything. I suspect that the changes of bios chip somehow corrupted the firmware inside. Is the hypothesis correct?
        Also i extracted the bios inside the chip which was on Winbond 25R128JWPQ you can find the file attached if you can fix it (if possible, I would like some insight on...
        08-09-2025, 03:56 AM
      • Dw198
        Surface laptop DFCI management in BIOS
        by Dw198
        I'm looking to buy a Surface Laptop 4 second hand, but the seller showed me something in the BIOS. Does this mean the laptop is still remotely managed? Should it be removed and what are the potential downsides if it isn't?
        Seller said he wasn't able to do an opt-out in the bios when connected with ethernet and adapter
        Besides that all options in bios are available and laptop allows fresh install of win11 pro without any troubles in oobe
        03-07-2025, 01:42 PM
      • macabook
        by macabook
        🧩 Initial Issue
        07-24-2025, 02:17 PM
      • muhuruu
        Surface pro 4 bios request
        by muhuruu
        Hey. Sometime ago i bought broken surface pro 4 supposedly it was dead. But turns out it was just a faulty charger. Although when it powered on and after all updates, touchscreen didn't work it also doesn't work in UEFI. On my original bios in device menager it shows yellow triangles on Surface ME and Surface Touch, hid-compliant touchscreen was missing. I already replaced touchscreen and touchscreen board, i've broken the orginal screen when trying to open surface. I already tried diffrent bios files from internet. With the latest one i was able to install the drivers for Surface ME and Surface...
        01-22-2024, 05:38 AM
        by Vesko356
        08-11-2023, 03:27 AM
