I've been looking online for a 20amp variac and I see Amazon has them for about $100 and Ebay has them for about $70. They all look the same but I'm wondering if there is any real difference between them? They all list brand names that are odd like vevor and others. Any advice would be appreciated. Thanks.
Variac 20 amp advice?
Re: Variac 20 amp advice?
No there is no real difference in the ones that have a red outer case
The voltage meters are crap but you can do a modification to it and have a very good setup the meter that fit it also needs a modification for it be very useful
If you buy one and you want to do a modification to meter just let me know and will find the post where I did the modification to it and what type of meter that will fit
When I have some money to spend I going to this same setup on a 5 amp version of to be able to power LED strips to figure out what voltage the strips are ( wish list )Attached Filesif you find these attachements useful please consider making a small donation to the site
Here is the post where I talk about how I figured out how and where you have to the modifications
https://www.badcaps.net/forum/showth...to+transformer
Here is where you can get this meter at
https://www.ebay.com/itm/Digital-AC1...gAAOxygo9Q5Xoj
If you decide to get this meter and have in front of you I show you which diode that you have to remove and add a 1N4007 diode and add a piece of wire and some hot glue to hold it in placeLast edited by sam_sam_sam; 06-16-2019, 07:01 PM.Comment
I just bought the 5 amp version of it now because it getting harder to find this version when I look 6 months ago I found more Seller selling them now I see only handful of them selling them
So I will wait until until you have all the parts and we can do it at same timeComment
I fitted mine with a self-powered digital AC voltmeter which starts to display at 60V and above - any AC product would typically not work at such a low voltage.My first choice in quality Japanese electrolytics is Nippon Chemi-Con, which has been in business since 1931... the quality of electronics is dependent on the quality of the electrolytics.Comment
When you do the modification that I am talking about you can read the voltage down 1.0 volts
The reason they can not read voltage down that low has do with the voltage divider to read voltage
You also have voltage reducer for the meter controller
In order for you to read voltage down that low you need to separate the meter power supply from the meter reading voltage divider circuit when you do this then the meter can read voltages that low
The meter that I have a link to can easily done you just have to —>
( remove one diode )
or
( cut the trace where this diode connects to the voltage input terminal block *** you have remove the top board of the meter controller in order to cut the trace you can also recap the board while you have it separated ***)
—> reroute the meter voltage divider circuit and hook it up to the outlet on the Variac
The meter power supply is hook to ON / OFF switch which now the meter is not powered by output of the Variac supply
One note
You do need to have a meter that can read its own power supply in order for this to work
Line / Netural you breaking the line side of the meter power supply / meter voltage divider circuitLast edited by sam_sam_sam; 06-20-2019, 08:49 PM.Comment
Here is where I got the meter for the 5 amp version that I bought the one that I used in the 20 amp version would not fit in the same space
POWER GRID volt & amp monitoring GAUGE - Digital ampmeter / voltmeter combo 2in1
https://www.ebay.com/itm/POWER-GRID-...53.m2749.l2649
I will in next few days I show how I modified this meter module this was so easy to do
The modification to this board —> it shows where the 5 volt section for powering the meter so it can read down to ( [0] volts )
The modification is not finished and that is why I not showing it yetLast edited by sam_sam_sam; 07-01-2019, 06:58 PM.Comment
$17 is fucking robbery.
i get them here:
https://www.aliexpress.com/item/32905549312.htmlComment
I did not want to wait a month to get it
I want to have this device working for a project that I want start working on
I am going to buy some of these meters that you gave me the link to next month
I have four orders from AliExpress that I am waiting for over three weeks for and still have not gotten here yetComment
For my variac project, I took apart that mini voltmeter and brought out the Vsense wire, so it's three wires now. It's powered off the input mains but measures the variac output, so I can dial down to a few volts AC. No <60VAC dropout of the voltmeter.Comment
Here is the modification on this meter module that I was talking about
In the photo I show where I cut the trace so it can measure down to ( 0 ) volts
I replaced the only capacitor that is in this unit
It had a 330uf@16 volt capacitor but the same valve capacitor was to fat to fit in there that I had on hand so I use a 220uf@16 volt capacitor instead and seems to work okay with itAttached Filesif you find these attachements useful please consider making a small donation to the site
One note about this modification is that you have to cut the trace on both sides of board in the same position which I forgot to mentionComment
You are probably right about this however there is not really a lot of trace to work with if you are putting wires to the board
I did cut a deep slot in board on both sidesComment
by Petr0xHi, I would like to share with you small modification to your Bosch tool 12V and 18V chargers.
You can use it for almost all Bosch chargers what I have seen, for example part numbers GAL 18V-20, GAL 18V-40, GAL 1880, GAL 18V-160, AL 1820, AL1115CV, AL1130CV.
Bosch (today also other brands using the same system like Wurth, Fein) does not care if you destroy your batteries, because they can sell you new ones. So the marketing is telling you only about speed of the charging, so you will not wait for your batteries to charge too long. Me as a customer want the tools and batteries...05-24-2024, 01:00 PM -
by Teban1306[REQUEST] ThinkPad T14 Gen 1 (20S1) - Custom Boot Logo Modification
Hello everyone!
I hope this is the right section for this request. I'm looking for help to modify the boot logo on my ThinkPad T14 Gen 1.
System Information:- Model: Lenovo ThinkPad T14 Gen 1
- Machine Type: 20S1S4E600 (Intel i7 variant)
- Current BIOS: N2XET42W (1.33) - Latest version
- BIOS File: n2xuj25w.exe (12.98 MB) - Downloaded from Lenovo support
Replace the default "LENOVO" boot logo with a custom image during POST.
🔧 What I've tried:- [
Channel: BIOS Requests ONLY!
by Ady2017Hi all. I need to replace an SMD fuse on my camcorder and this is the first time I have had to do any SMD soldering so your advice would be appreciated. Below is a picture of the board that I am working on and I have highlighted the fuse that needs to be replaced. I managed to zoom in to take this picture but the fuse is really tiny and is sandwiched between other components so this is going to be a new milestone for me. I appreciate that I am going to have to buy a new soldering iron if you could advice on what I need please. I was thinking about putting a big soldering iron across the whole...1 Photo
by chazzoI’d appreciate some very basic advice on CH341x programmers. I know this topic comes up from time to time, but stuff changes, so I hope a refresh is in order. In particular, I see some unexpected things happening with jumper positions.
[My plan is to learn to read and write 24CO2 EEPROMs via I2C. The first target is the one in my Uni-T clamp meter, but before tackling that I have some brand-new EEPROMs to practice on.]
I have two basic Chinese programmers. One is the blue board with a CH341A and two rows of pin headers. To my untrained eye it looks like all the others.... -
by JidisHi all,
I made a big-ass mess here of my father's beloved P602, and I'm trying to figure out if I should order a batch of overpriced ribbons or if I'd just be throwing more good money at the bad.
He woke up recently to a bunch of white bars going down the right side of the screen. From what I'd seen in these places, I figured the T-con board has gone out or has a bad connection. I took the back off and gently poked at the socketed ribbons and sure enough, got the image back. It was mainly the far left ribbon, and it would snap back to stripes if I let off the pressure.... - Loading...
