Car code scanner OBD1 adapter enquiry
  • belalmondeo
    • Dec 2018
    • 33
    • مصر
    Hello everyone there
    If You do remember me then I am Belal who posted an issue of his J2534 pass-thru Multi-Diag 2015 OBD II device a while ago and aside from my thanks that show my gratitude to all of those who have given me help with my issue I just wanted to go straight into my question which is whether using the OBD II to OBD I adapter to diagnose an older model vehicle like a GM 12 adapter safe enough and not gonna cause any catastrophic failure to my device and if it still can perform scanning with no issues?
    there's a link for the adapter: https://ebay.to/2UCWDDx
    it worths mentioning that I was using this device to run scans on a wide variety of vehicle makes including (Skoda - Chevrolet - VW - Renault - Peugeot - Chery (general OBD) - Nissan (general OBD) - Toyota) and much more, but it's actually works like charm with VAG vehicles and has the capability of coding/adapting functions despite being a clone, but I used to face issues with a few number of cars that I've tried to perform scan to with the protocol ISO 15765-4 CAN (11 bit ID,500 Kbaud), these vehicles were ( 2011-2016 Renault Fluence - 2000-2006 Mitsubishi Lancer - Chery QQ6)
    and I just wanted to get a way around it, since this device is actually J2534 Pass-thru based then it has the capability of performing perogrammming to a number of makes with each manufacturer specific software Like (Toyota techstream - GM TIS200 - JLR - Honda HDS) but it's a little restricted and might be compatible with specific versions of these pieces of software I mentioned above, it also can be reworked to be much stable and fast during the work !
    please check for the software in the link above if You're interested !
    the software (MDO I-2017 sP1-sP2-sP3) : https://wishes2.com/AuRjt
    2011 VCI : https://ebay.to/2NoCf2Z
    Pickit 2-3 with ZIF adapter (debugging tool) for performing a hex file dump to the chip (clone) : https://ebay.to/2E7IEeH
    Genuine Pickit 3 : https://ebay.to/2BQeHzD
    Genuine Pickit 2 : https://ebay.to/2tBIA1R
    Soic 8 clip : https://ebay.to/2H0Yw5Y
    Video for using the Pickit 2 software for the hex file dump : https://www.youtube.com/watch?v=7jcJGwNoXCE
    Video for using the Pickit 3 (IMPLAB) software (using a universal adapter from Ebay) : https://www.youtube.com/watch?v=hSkmPyhopRk
    IMPLAB (Pickit 3 software) : https://wishes2.com/xmfpq
    Pickit 2 V.2.61 (Pickit 2 software) : https://wishes2.com/T3aY
    HEX file : https://wishes2.com/CJzh
    Keyupdate : https://wishes2.com/2eBjB
    Drivers : https://wishes2.com/FEn73
    Best Regards !
  • waigy
    What are these components that detect paper in a fax scanner
    by waigy
    PROBLEM SOLVED
    I DIDN'T REALISE MY SMALLEST SOLDERING TIP COULD JUST FIT BETWEEN THESE COMPONENTS.
    I MANAGED TO REMOVE THEM WITH NO DAMAGE TO THE BOARD AND I HAVE MY INTENDED END RESULT.
    On a Possio PM70 portable fax machine which has a scanner that detects when you push a piece of paper into the scanner slot.
    It is these two small (3mm long) components that detect the paper and start the scanner feed motor which pulls the paper into the scanner.
    (These are on the circuit board for the keypad and not the main board)
    I want to disable these as...
    05-21-2023, 12:50 AM
  • CapLeaker
    Bearcat 300 scanner no display, has audio and squelch repair
    by CapLeaker
    I found an old Bearcat 300 scanner that had no display, but the audio and squelch worked, over at my workplace. This unit has a lot of hours on it. It had some capacitor replacements and other mods done to it too before I found it. To troubleshoot this problem, the usual is to check the +25v and -30V and replace C98 on the main board. That should fix it. There is also a case of a shorted button board (just unplug that ribbon cable and the display should work again). Spoiler alert! Was not the case on this one.
    My display didn't work, because I had a missing -10V on the display...
    09-09-2024, 10:24 AM
  • belalmondeo
    J2534 Pass-Thru OBD scanner issue
    by belalmondeo
    I just need Your help with my 2017 multidi@g clone interface shown in the attachments, I used this particular piece of hardware with a number of european makes and it works just fine yet sometimes I used to run diagnosis on korean/japanese or even european makes like renault (Fluence) and it won't connect to the vehicle for some OBD II Protocol issue like incompatible protocol or something like such.
    Will a Rework done on the VCI solve such issue ? or I'll have to get an another software like (Scanmaster_Passthru)?
    Elighten me !...
    10-25-2019, 06:01 AM
  • SoporteHR
    DesignJet T1200 MFP scanner (CQ653A). It restarts after minutes of having turned on.
    by SoporteHR
    Good morning to all the presents.
    Receive a warm greeting.
    I commented and consulted the following (Electronic Technical Level), since doing a search for the team model (CQ653) I did not find anything that references the problem I have.
    Equipment: HP DesignJet T1200 MFP. CQ653A. Scanner Module.
    History of the device:
    The user of the equipment had problems with the lamp, due to this, he proceeded to replace it, but he said that the bulb was damaged, he replaced it and when he turned on the equipment, there was a short circuit...
    12-04-2018, 08:25 AM
  • fricosu007
    OBD Scanner Autel AL539 burnt rezistors
    by fricosu007
    Could someone help me identify the two rezistors burnt inside this AL539 device from Autel, i cannot find any dissembly pictures and there are a lot of these devices, i hope some of you have it 🙌
    https://imgur.com/a/b9fGGGk...
    09-22-2025, 10:58 PM
