Re: Reballing discussion and tips
Here's a far better quality video.
https://www.retronix.com/services/bga-reballing/
With everybody gone from the shop during lunch break, I sneaked around to where I know the dead machine lies to have a look at it and snap some pics for later useI shouldn't have to do this - I friggin' WORK here - it's like I'm thief around here
Unfortunately this might be a bit more of a hassle to restore than I expected - the head has a couple of other loose parts dangling around inside, so it's not as easy as bolting in the replacement element - these guys may be clueless half the time, to the point where I'm screaming internally, but even they are not SUCH blockheads to not have thought about replacing the heater. A new head assembly is too expensive for me to purchase on my own. From what I understand, they thought about replacing the whole head assy like that, but for some reason chose to replace the entire machine because they claim the price difference between the two was too small to warrant replacing the head: around 200$ vs. 400$....not that small a difference, but anyway....
A real reballing machine. https://www.youtube.com/watch?v=JH4HKQoSyps), but I never thought it existed until I eventually looked it up, further confirmed by your video now: a machine which replaces the shaky human hand by having a head which can carry all sorts of tools on it and uses them with pinpoint accuracy like that: soldering, wicking, fluxing, balls, you name it. After all, there's no reason why it CAN'T exist: it's just a slightly more advanced CNC in the long run....turns out it DOES exist (and I was certain it did, but only in highly professional environments). I'm sure our shop could afford something like that - it's a HUGE business - but it would take years to pay for itself due to the relatively low prices one can charge for a reball operation.
It is a heating element. If it gives off IR radiation it's an IR heater.
I doubt it's 1500W more like 300W. The IR rework station is 1200W for the bottom, 300W for the top.
If you can get one of these in the housing https://www.aliexpress.com/item/32522148095.html it would be even cheaper.
It's 450W not 300W so you might need to modify your machine.
A real reballing machine. https://www.youtube.com/watch?v=JH4HKQoSypsLast edited by diif; 07-25-2019, 02:06 AM.Leave a comment:
Hmmm....his doesn't seem to leave any gunk behind. Either that, or he simply doesn't clean it afterwards
EDIT: I learned a while back that we have a second T890 reballing machine around here that's dead. Apparently its "lamp" died. Not having looked into these things before and not actually seeing the device itself up close, I had no idea what this "lamp" truly is or what it looks like. I know it's the "head" that actually heats up the board from above, but had no idea what the active element inside it is, that is until I looked it up on Ali and found THIS....looks like a heating element. How is that an IR "lamp" exactly ? Could be a mistranslation after allNot only that, if that's the only thing wrong with that machine, for 20 odd dollars I could make myself a functional BGA machine...
Back on the topic of reballing: should you cover up the various plastic parts on the board like RAM slots and CPU sockets before hitting it with IR ? Like I said, G who handles reballing around here, covers up the area around the chip with aluminium tape, which I wouldn't personally do, but it does seem like a good idea to do this with plastic elements.
I only cover anything plastic if it's directly next to the IC I'm reflowing.Leave a comment:
Back on the topic of reballing: should you cover up the various plastic parts on the board like RAM slots and CPU sockets before hitting it with IR ? Like I said, G who handles reballing around here, covers up the area around the chip with aluminium tape, which I wouldn't personally do, but it does seem like a good idea to do this with plastic elements.Leave a comment:
Just thought of something, even though's not industry standard and would probably not work/last: what if instead of solder balls or paste, you just ran a blob of regular "reel" solder over the chip covered with flux with the hot iron like when tinning SOIC pads or something larger like that ? The solder would stick to the pads and there's your balls
Reason why is as diff mentioned - you're not going to get nice balls on the pads, but simply "bumps" of soldered. And even if you try your best, those solder bumps will not be the same... or even that similar, even if it looks like it to your eye. This means that while some of them will solder fine to the board pads, others might not reach it at all or would be under-soldered. Add the fact that the board will always flex when re-heating it to high temperatures, and you can be assured that more than likely not all pads will be soldered.
But I went a step further (without thinking): on the second try, I tinned (i.e. put solder "bumps") on both the board and the BGA chip itself... only to realize that there is no way to place the chip on the board, as the round solder bumps on both would make the chip slide off to one side. So in the end, it was impossible to position the chip properly this way.
So all in all... no, this likely won't work. I tried it many years ago at that repair shop I used to work at, where I had access to a decent IR station. I didn't work then, so I don't think it would work now either. But give it a try if you're really curious. Sometimes that's the best way to satisfy a curiosity and learn things.Leave a comment:
When was the last time you soldered a pad and instead of it being tinned there was a nice 0.5mm solder ball? Now repeat that 500+ times for all the other pads.Leave a comment:
Just thought of something, even though's not industry standard and would probably not work/last: what if instead of solder balls or paste, you just ran a blob of regular "reel" solder over the chip covered with flux with the hot iron like when tinning SOIC pads or something larger like that ? The solder would stick to the pads and there's your ballsLeave a comment:
True, I just realized that after writing.....and I have been soldering for some years now and often use that surface tension of the solder to get stuff to "snap" into place, so I don't know what I was talking about
Still, the plate should not be red hot I imagine...just enough to get the temp in the ballpark before attacking the top with the iron or hot air.Leave a comment:
Indeed, those certainly won't do, since they don't get near hot enough to melt solder...though now that I think about it, its purpose as a "heater plate" would be to just get the board hot but not to the point where it's starting to melt solder by ITSELF - that would be a disaster as it would cause SMDs to fall off, so in the long run it could actually work as a poor man's version of a heater plateAnd even non-glued components like small-to-medium sized BGA chips will not fall off. That's because solder is similar in this regard to water: it has adhesion properties - i.e. once it's stuck on "something it likes" (that is, metal that wicks to solder or other solder), it won't let go so easily (even in liquid state). Ever wonder how video cards and boards with RAM chips on both side of the board don't fall off?
Anyways, here's also an interesting video on how PC boards are made:
https://www.youtube.com/watch?v=cZOe4VDHn8YLeave a comment:
When you say sandwich maker, I imagine those "sandwich presses" / waffle presses (that have heating surfaces on both sides and you close like a chest). If that's what you're talking about, then those probably won't work, because they generally have a heating element (either a "rod" or Nichrome wire) embedded into an aluminum frame or ceramic surface... which in itself isn't that bad. But these things are generally in the ~500W range or less, and so the surface area is too large to get hot enough for that power level.Leave a comment:
Although with the sandwich maker, heat is actually mostly transfered by radiation. Same goes for any station that uses IR heating.
With heat guns, hot air stations, and the natural gas / propane burner method I suggested above, heat is transfered pretty much entirely by convection. Again, it's not very efficient, but it produces more even heating.
A toaster is a bit of both, with the heating elements emitting both IR and producing hot air around them (that rises and heats the board). So you get a bit of both worlds in there.
But again, I myself prefer mostly some type of hot air convection method. IR tends to bounce and scatter from light and shiny objects and that can lead to different heating rates.
And conduction is what your soldering iron uses (i.e. heat conducts from the hot tip directly to the component's leads.)
It also depends a lot on the heating element type - i.e. exposed Nichrome wire (what hot air stations and toasters use, for example) vs. ceramic plate with embedded Nichrome (your typical IR machine) vs. heating "rods" (the type of heating elements you see in your kitchen's oven).
Now, if you're talking about one of those "mini ovens" (also sometimes called sandwich makers... go figure)... MAYBE you can make something that works. But again, it will depend on the heating element types used inside. If heating "rods", it probably will work OK for a "general" bottom heater (might not have enough power for larger boards and also might not produce very even heating.)
It's not about grunt but the different methods they use to cook. A sandwich maker cooks by conduction whereas a roaster oven used convection.Leave a comment:
I don't cook though, so I'm not sure about the second part
Electricity is expensive and nobody tends to use it, unless there's absolutely no other option.
So you're saying a sandwich maker or other devices with heating elements don't have enough grunt when assembled as originally intended by the factory and I'd need to get closer to the heat source. My idea was also came from this chap's reballing machine whose bottom plate perfectly resembles an oversized sandwich press plateNever actually tried sticking my hand in there to see how hot it truly gets
^ I don't know... that sounds like more work than it's worth. I've tried using one of those big flat stake grilles (same setup: heating element embedded in an aluminum case and coated in teflon for cooking food on top), and I wasn't impressed at all. It was slow and not easy to control the heat at all. So I don't think you're going to like the results.
Hot rising air from the bottom, such as that from a glowing exposed heating element or coil (i.e a toaster or curled heater) does a much better job at both heating quicker and more evenly - just my experience in trying various DIY setups. That said, personally I'd say just get one of those single portable gas/propane burners (like some folks in parts of the countryside use for cooking). If you try it once, you'll never want to use anything else. (Same goes for cooking food, for that matter - once you've used a natural gas or propane burner/stove, you'll find electric ones "annoying".)
If yes, I'm not sure those would work too well. Really, either a toaster or something with exposed heating elements would work a lot better. Even a hair dryer would make an acceptable bottom (or top, for that matter) heater if you remove the PTC and slow down the blower fan so that hotter air comes out.
All in all, if you do want to make your own machine... again, first build a prototype without any MCUs and get a feel of how everything works. Then tweak and test more. Once the "machine" works well in full manual mode, then use MCU to automate some of the controls.Leave a comment:
by SMDFleaCommon SPI bios chip programming Questions and Answers
Bad...-
Channel: BIOS Requests ONLY!
09-02-2021, 04:40 PM -
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... -
by ktmmotocrossBIG cores like 2080ti or 3080 cannot fit into any of my reballing holders. its for max 45mm chip and this chip have 50mm
what holders do u use for this big chip -
by JeroentjeHi
I try to repair a asus Asus X571GT (DA0XKTMB8C0) no power no lights.
I saw a burned (small hole in it) chip (JW10F) proberly a TPS22976DPUR, I removed it, now with power connected the laptop turns on and direct off again, power led and fn will light up.
I found on a donor lenovo board a G2898KD1U (wa9y), looks the same ..
Result is still the same, turns on and direct off again, first attempt is with backlight on all other direct attempts are only the power and fn led.
Could it be the chip is to diffrent to make the laptop work again ?
by TroystainHello, anyone here have updated ezp2023+ chip database in .dat file format.
I need to add w25q256jveq chip but I do not know what data should I type.
I'm using the ezp chip dabase editor posted from here https://www.badcaps.net/forum/troubl...ro-programmers
The currenty unit model that I am trying to detect is HP elitebook 640 g9 which is currently locked on admin bios....11-25-2024, 12:53 AM - Loading...
