BLUETOOTH Question
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    BLUETOOTH Question
    I am interested in buying a pair of Bluetooth ear buds for my daughter and I see on e-bay they have Bluetooth V4.1 and Bluetooth V4.2 buds. What is the difference and will they work with the Android Samsung J7 Prime phone?
    • 31283
    Re: BLUETOOTH Question
    i never understand why people want a transmitter that close to their brain!!
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      ^ I never understood why people are scared of half a watt of power....
      Follow the white rabbit.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        I read both posts. I must be missing something, as my question seems unanswered, yet.
          • 31283
          because short of stabbing yourself with it, you couldnt reduce the distance much more.
          and that .5w is going into a very small area - so it's going to have a greater effect than several watts in the general area.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8706
            It's hard to tell without actually trying, bluetooth has been very picky for me though recent devices have tended to work fine. You want A2DP support which should be standard nowadays.
            However, while I prefer to keep things wired as much as possible to keep all the waves contained to reduce interference and interception,
            - radio waves are not ionizing.
            - headphones don't transmit very much.
            - half watt with inverse square law dissipates very fast.
            - half watt with half of the emissions pointing in the other direction.
              • 31283
              .25w into a few square mm of soft tissue for hours on end every day - that's asking for trouble.
              there are lots of cases appearing now in the u.s. of breast cancer caused by women shoving the phone down their top while out in the sun.
              same place all day, every day - several years later - tumor in *exactly* the same place.
              the phone company's are getting worried now, incase it goes like it did with the tobbaco industry.
              what i mean by that, is they are afraid of lawsuits not for the physical damage but for lying about the safety.
              i use phones, but i'm not stupid enough to keep it pressed against me all day and then sleep with it on the pillow at night.
              unfortunatly a lot of people are doing that thanks to fucking assholes claiming it's safe!
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8706
                Strawman and misleading (headphones transmit duty cycle is much less than 100% !!!)
                And even when talking about a phone, when it is not in active use, the transmit duty cycle is likewise much lower than 100%, it does not transmit nearly as much during the night when not in active use.
                Where's the finger and hand cancer?
                  • 31283
                  modern phones transmit on 3-5 different bands simultaniously unless you lock them down.
                  the fact that you have a 3-4AH battery helps mask that.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    https://www.quora.com/What-makes-Blu...-Bluetooth-4-0
                    • redwire
                      • Dec 2010
                      • 3912
                      "Bluetooth 4.2 introduces several new features that improve speed and privacy over Bluetooth 4.1 but the main advantage is allowing chips to use Bluetooth over Internet Protocol version 6 (IPv6) for direct Internet access. With this, the possibilities expand beyond those of current designs and markets to include any type of Bluetooth device requiring speed and security in the IoT."
                      Why use Bluetooth for IP? It seems silly, haven't they heard of WiFi?
                        • 31283
                        they want to merge it all for their dream of a total (survailence) grid.
                        it's not like they have not been talking about it for years.
                        • Curious.George
                          • Nov 2011
                          • 2305
                          • Unknown
                          Originally posted by redwire
                          "With this, the possibilities expand beyond those of current designs and markets to include any type of Bluetooth device requiring speed and security in the IoT."
                          Because the ether is quickly becoming unable to support all of the competing uses for its bandwidth. Imagine all of your IT devices using wifi -- home phone, "stereo", TVs, computers, security cameras, etc.
                          Imagine each of your neighbors also doing the same. Imagine them each living in the apartments/condos immediately above, below and to either side of you.
                          I see the AP's of neighbors 100+ ft away. So, they're using bandwidth far beyond the confines of their own properties...
                          BT (and BLE) are inherently shorter range technologies. It won't be long before we see 100+ network nodes in MOST homes.
                          (Imagine NOT needing a special "bridge" to talk to your garage door opener from your cell phone...)
                          • redwire
                            • Dec 2010
                            • 3912
                            I totally agree, they are already doing it.
                            My city has Bluetooth ID monitoring units, supposedly to monitor traffic flow. They can track a Bluetooth or Wifi ID moving through the city, to get travel times and other analytics.
                            https://www.sensysnetworks.com/products/flexid
                            Does it really (((re-identify))) your BT ID or MAC address?
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8706
                              What's annoying is...whether BT ID can be reassigned...
                              I have a USB BT dongle's ID that comes up as 11:11:11:11:11:11 ... I don't know if that's secure or anonymous... and can't change it.
                                • 31283
                                yes, and the IMEI/IMSI of your phone too,
                                the fucking bolshevic local council here has the tech in the streetlamps along the main shopping street!!
                                • Andrew F. Ali
                                  • Jan 2014
                                  • 2450
                                  • Trinidad & Tobago
                                  Thanks, Guys (and Ladies). I got my answer.
                                  • Curious.George
                                    • Nov 2011
                                    • 2305
                                    • Unknown
                                    Ever wonder why stores offer free wifi? Heaven forbid if you turn your phone OFF and they have to rely solely on the face/motion tracking cameras to identify you (by working backwards from the identification -- credit card -- you provide at checkout) and your shopping habits as you *had* walked through their aisles...
                                    Or, why google's cars log the SSIDs of APs as they cruise neighborhoods.
                                    [Cars are easier to track than to rely on radio beacons -- license plate trackers are becoming ubiquitous law enforcement tools.]
                                    If you don't want to be tracked, avoid public spaces, eschew wireless devices and cover up your face (but, not in too unique of a way that makes you an individual, again!)
                                    Oh, and stop posting in public places! :<
                                    • Andrew F. Ali
                                      • Jan 2014
                                      • 2450
                                      • Trinidad & Tobago
                                      I'm glad I asked this question. I've learn't quite a lot more than I expected from the discussions here.
                                        • Jul 2011
                                        • 6070
                                        I only one thing to say about this
                                        This is very wrong you should be given a choice not shoved down your mouth or what ever
                                        I very seldom take my phone when I go shopping anyway so I do not have much worry about
                                        But shopping online is a hole different story I know that just about every site is tracking you what you look at and buy and what ever else
                                        It is convenient in one respect but in other ways can be a big problem
                                        EBay is one of the worst when it comes to this yes it convenient and real pain in the a** at the same time
                                        Google is also very bad about this here is a example
                                        I bought some capacitors at Digi-Key’s website and guess what when I went on EBay I see offer to buy from Digi-Key and also on EBay
                                        This is getting bad but what can you do about it
                                        “Oh, and stop posting in public places! :<”
                                        If only you could do this—> you would not learn anything and become a real dumb a** no thanks
                                        but real temping thought
                                          HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:30 PM
                                          HP ProBook 450 G7 + LG SJ2 Bluetooth Sound Bar Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 450 G7 + LG SJ2 Bluetooth Sound Bar Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G7 + LG SJ2 Bluetooth Sound Bar boardview and 450 G7 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          09-06-2024, 07:50 PM
                                          HP EliteBook 830 G6 + Bluetooth Speaker 400 Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 830 G6 + Bluetooth Speaker 400 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 830 G6 + Bluetooth Speaker 400 boardview and 830 G6 + Bluetooth Speaker 400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-06-2024, 06:00 PM
                                          HP EliteBook 840 G6 + Bluetooth Speaker 400 Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 840 G6 + Bluetooth Speaker 400 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + Bluetooth Speaker 400 boardview and 840 G6 + Bluetooth Speaker 400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          HP EliteBook 840 G6 + LG SJ2 Bluetooth Sound Bar Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook 840 G6 + LG SJ2 Bluetooth Sound Bar Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G6 + LG SJ2 Bluetooth Sound Bar boardview and 840 G6 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
