Unknown Surface Mount Component
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    Re: Unknown Surface Mount Component
    Originally posted by stj
    wont work, it has to be electrically conductive to carry the negative rail.
    it also has to support the spring pressure against the battery.
    i also doubt it's a good idea to use anything that softens if it gets hot!!
    a machined aluminium ring may work, i was just going to mount the 17mm board against the 20mm one.
    They make conductive PLA, and it only softens around 190C
    sigpic
      • 31090
      still probably not strong enough to have an 18650 rammed into it for years.
      i think the simple answer is to strip all the parts off the 20mm board and fit the 17mm one against it.
      i'll try it when i get a couple.
      • EasyGoing1
        Shock Therapist
        • Sep 2016
        • 977
        And the beauty of 3D printing is you can just print another one if something goes awry ... or print 10 and throw em in a drawer...
        I'm not sure how strong the conductive PLA is, since it is doped with metallic particles, I would assume it's stronger than standard PLA ... ABS is stronger yet, but I don't print with ABS cause its a pain in the ass. :-)
        sigpic
          • 31090
          if something goes awry you risk the 18650 turning the light into a pipebomb - no thanks.
          conductivity would need to be pretty miraculous too - your pushing 1-3A through it and dont want any volt-drop.
          • EasyGoing1
            Shock Therapist
            • Sep 2016
            • 977
            Yeah I couldn't imagine doped PLA at that amperage NOT producing a voltage drop... but I've not messed with it yet...
            sigpic
            • EasyGoing1
              Shock Therapist
              • Sep 2016
              • 977
              They finally showed up today ... I have tried 6 of the 10 and NONE of them have worked ... kinda pisses me off.
              sigpic
                • 31090
                show your circuit.
                  • Jul 2011
                  • 6046
                  Here is the data sheet for this device AMC7135PKFT
                  https://cdn.badcaps-static.com/pdfs/...f2c52ececb.pdf
                  Does take a little time to load the page
                  I am going to give these a try and see if I make a big Big LED light with them
                    • 31090
                    i posted that datasheet on the first page.
                    • EasyGoing1
                      Shock Therapist
                      • Sep 2016
                      • 977
                      show your circuit.
                      Here it is
                      sigpic
                        • 31090
                        your led is backwards, the chip regulates the negative rail.
                        • R_J
                          • 9558
                          here is the pdf
                          • EasyGoing1
                            Shock Therapist
                            • Sep 2016
                            • 977
                            I JUST NOW took a closer look at the schematic on the datasheet and saw my error... they work just fine.
                            sigpic
                              • 31090
                              lol
                              so how many will you use?
                              given we dont really know much(anything) about the led?
                              • EasyGoing1
                                Shock Therapist
                                • Sep 2016
                                • 977
                                lol
                                So I did use a CC power supply and set it for 4.2 volts at .5 amps, and it powered the LED just fine (and it damn bright which was wonderful) ... When I connect the LED using the AMC7135 and a 18650 battery, it draws about 360ma ... I'm not sure how quickly it will drain the battery at that amperage, but I'm thinking it would be pretty fast, so adding another 7135 would definitely make the light brighter, but it would also drain the battery faster ... now I'm not necessarily opposed to this because the battery is easily recharged and I certainly have enough of them laying around ...
                                What would you do?
                                sigpic
                                • EasyGoing1
                                  Shock Therapist
                                  • Sep 2016
                                  • 977
                                  lol
                                  I just re-assembled the flashlight with the new LED and just one 7135 and with a newly charged 18650, its EXTREMELY bright ... much brighter than it was before. The only weird thing about it is when I turn it on, it starts out extremely dim then SLOWLY gets brighter ... is there something connected to the push button that is causing this?
                                  sigpic
                                  • EasyGoing1
                                    Shock Therapist
                                    • Sep 2016
                                    • 977
                                    Originally posted by budm
                                    Why not? Do you not know the Voltage source, the load current, etc.?
                                    Budm, you never did tell me if my calcs were accurate ...
                                    sigpic
                                      • 31090
                                      interesting, if it is your switch then it could be getting warm.
                                      i find with the really cheap chinese lights with a clicky tailswitch you sometimes have to give them a blast of contact-cleaner.
                                      or poor battery contacts?
                                        • 31090
                                        battery capacity divided by 360.
                                        id your battery here:
                                        https://secondlifestorage.com/celldatabase.php
                                          • Jul 2011
                                          • 6046
                                          Thank you for the battery information post this will help me a lot
                                            Surface Mount Fuses Fundamentals Datasheet
                                            TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
                                            TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
                                            10-07-2024, 06:07 AM
                                            Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock 2 boardview and Surface Book 3 + Surface Dock 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                            09-06-2024, 08:10 PM
                                            Microsoft Surface Book Surface Book 3 + Surface Dock Hybrid (2-in-1) 3 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock boardview and Surface Book 3 + Surface Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
