Smallest 3-cell Li-ion battery protection circuit?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Curious if anyone has come across a small 3-cell li-ion battery protection circuit. It only needs to pass a maximum of 2A or so, but needs to be small...say, smaller than 1.5" x 2" x 0.3" or so, if there's something close it's worth entertaining!
    BTW: If it's the width of 3 18650's, that's too long in that dimension most likely... don't have much room for this application - it uses prismatic pouch cells.
    • Jul 2011
    • 6045
    Re: Smallest 3-cell Li-ion battery protection circuit?
    Could you please post the photo of the cells you are going to use thanks
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      As the box is made of plastic and has those plastic clasps I hesitate to open it more than needed. Anyway it's a small battery pack. I'm sort of retrofitting someone else's "hack" so it's a hack of a hack which isn't pretty - the pack originally was 7 pcs ½AA retrofitted with 3pcs pouch Li-ion cells. The inside dimensions of the box is approximately 55mm x 30mm x 33mm, of which most of it is occupied by the cells.
      I was worried before but perhaps the longer 55mm dimension might actually be long enough to accommodate an 18650x3 board as long as it's thin enough - I don't think I have more than 3 mm to spare in in the 30mm direction and 5mm in the 55mm dimension due to the rectangular pouch cells (the three cells bound together would be around 50mm x 27mm x 33mm).
      It would be a tight fit no matter what.
        • Jul 2011
        • 6045
        Is the voltage 4.2 or is it 12 volts you are using
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          Using the "12" volts. Note I "quoted" it because it's way too many volts, alas it does work... just won't charge it all the way to 12V to limit damage. Hopefully the cells will last more cycles since they won't be fully charged -- though the risk of overdischarging is a big problem.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            Speaking of overvoltage protection, can the voltage limits typically be easily reduced lower, to, say, 11.7 volts charge cut off (3.9V x 3) instead of 12.6V (4.2V x 3)? Maybe an even 4.0V would be fine. I suppose SMT rework would be inevitable but that's what it is...
              • Jul 2011
              • 6045
              This is about as close as you are going to get for what you are looking for
              https://www.ebay.com/itm/3A-4A-3S-12...4AAOSwHMJYDCrd
              Or
              https://www.ebay.com/itm/Battery-BMS....c100005.m1851
                • Jul 2011
                • 6045
                I have wondered what you have to change in order to change the voltage
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  Looking at possible reference designs for the protection circuits, I think it's not possible to change the voltages as it typically depends on internal references within the ICs.
                  Now the question is which ones are balancing and which one are simply protection. I think the simple protection is sufficient though balancing would be better.
                    • Jul 2011
                    • 6045
                    In two links that I posted the first one is only a protection board
                    The second one says that it is a BSM board but I do not see the specks for the balancing so I am not sure that it is a BSM board
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8701
                      Some balancing boards use i2c to program voltages, that may be good, though a lot of boards I can't read the balancing IC... If it were done by an external voltage divider...
                      ... it would consume so much power that the idle battery life would be severely impacted...
                      • Astonished
                        Fixing the Charge Circuit of the Batteries of the DC Motor
                        by Astonished
                        Hi friends of electronics
                        What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                        The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                        Please help me fix this circuit.
                        (the datasheet of the IC: https://pdf.datasheet.live/28...
                        01-28-2025, 06:24 AM
                      • Tarot Superstars
                        Short Circuit tester
                        by Tarot Superstars
                        Hello.
                        I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
                        The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
                        Link
                        The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
                        https://www.youtube.com/watch?v=0eixDdCpiO4
                        My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
                        09-25-2023, 09:11 AM
                      • Alimash
                        op amp circuit function?
                        by Alimash
                        I am repairing a ups which doesn't turn on ,it has the following ICs:
                        SG3525 used to drive inverter mosfets.
                        couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
                        A LM358 and TL074 for control mechanism and of course the uController.
                        The SG3525 is shutting down every time the ups is turned on.
                        I want your help to know the function of LM358 and TL074 in the system.
                        I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
                        07-31-2025, 07:45 AM
                      • M1NEBLANK SHOW
                        MSI B250 Gaming M3 Short circuit in CPU power supply circuit
                        by M1NEBLANK SHOW
                        Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
                        (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
                        Schematic and Boardview here
                        04-04-2025, 03:57 PM
                      • прямо
                        Viper22A 5VSB circuit
                        by прямо
                        So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
                        In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
                        01-13-2024, 07:05 PM
