Fluorescent light to LED conversion?
  • redwire
    • Dec 2010
    • 3912
    My garage ceiling fluorescent light fixtures are oddball F40T12 METRIC 1160mm/3.8ft tubes on a 120VAC magnetic ballast, 2-lamp.
    I can find F34T12 tubes but $12 each, a ballast costs $25 so that could be almost $50 if everything needs replacing. The fixtures seem not worth repairing.
    Converting to LED would be best, but getting long 4' LED tubes out of china is expensive; minimum 25-lot case of lamps on Aliexpress looks like an expensive venture and chinese LED quality is all over the place.
    Anyone know of some alternatives? I have around 6 fixtures to fix up.
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Fluorescent light to LED conversion?
    https://www.1000bulbs.com/category/t8-led-tube-lights/
    Just had the over-the-range lamp die on me. F20T12. Bulb and ballast. I ordered a new Floro bulb and trigger-start ballast just because im a stubborn old Ham, but i found that they do have some single LED tubes for sale on this site.
    Follow the white rabbit.
      • 31131
      before you buy any led replacements, compare the Lumen's
      nothing beats a real T12 tube still.
      even the "slim" tubes they push as energy saving replacements.
      for example the 36w 4ft to replace a 40w 4ft are all over-driven to get the brightness and only last a few years.
      fucking rubish pretending to be enviromental upgrades!!
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        I'm just sticking with regular fluorescent tubes, but my F40T12s are regular 4ft length so the cheap tubes fit just fine. If you have a weird length fixture you might as well throw it out and buy a new fixture with LEDs if that's the way you want to go. I'm surprised there is a 1160mm tube, regular 4 ft tubes are apparently nominally 1200mm (4*25.4*12=1219mm) so 1160mm is a huge distance off... interesting.
        I haven't had those linear fluorescent ballasts die on me... seems fairly robust.
        • petehall347
          • Jan 2015
          • 4429
          T5 can be 1160mm
          https://www.ledsales.co.za/products/...er-(1160mm)-HO
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            Incidentally I think that most of the LED direct fluorescent replacements are slightly dimmer than the equivalent linear fluorescent. However linear fluorescents like compact fluorescents have warm up time as well, though it seems much better than the swirls.
              • 31131
              "slightly dimmer" ??
              most are 50% dimmer.
              they probably think they can get away with it because the led's are directional and a real tube puts half the output upwards.
              that is of course bullshit because the fittings are designed to take that into account and reflect it back.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                I don't know about half, but they do advertise less power draw as well. This is completely different than incandescent where they target parity light generation -- but fluorescent tubes are NOT power wasters and generate just about as much light per watt, and in order to make a power consumption stand from the LED side, they deliberately reduce power -- and unfortunately they reduce brightness...
                Ridiculous, isn't it? Now go back to cheap fluorescent tubes that last "long enough," if you don't mind the warmup time.
                • petehall347
                  • Jan 2015
                  • 4429
                  cant beat incandescent lights . i do however like T5 led.s . or tube lights . once was told tube lights take 2 hours running time to switch on so leave them on more than incandescent .
                  • petehall347
                    • Jan 2015
                    • 4429
                    best running tube lights on dc they last longer . or just use old ones on dc to give them a new lease of life .. be careful with dc ...
                    • redwire
                      • Dec 2010
                      • 3912
                      I found fluorescent lamps do not last long in on/off use, despite their 15,000 hr rating. It must be cathode-stripping or something that makes the mercury condense on the tube's inside glass.
                      Philips has a T8 LED tube lineup but it's terribly complicated, as with all their LED lighting products and the website is beyond confusing.
                      They only work with ballasts according to a chart, and about $17 each at the local hardware store. Some you can direct wire.
                      LED's use about 1/2 the electricity for the same light output, but LED tubes are all less light output, and shining up to reflect off the white paint reflector seems silly.
                      I need to change from T12 to T8 sockets, buy tubes and possibly ballasts. Pretty much an entire fixture.
                      Bet it's cheaper to put in a bunch of E27 lightbulbs as a fixture.
                        • 31131
                        pretty sure T8 & T12 have the same pin spacing, and most sockets have universal slots anyway.
                        • RukyCon
                          A Fake Rubycon
                          • Jan 2017
                          • 816
                          If the ballast really is magnetic, then you should swap it out before trying anything like LED tubes on the fixture as the ballast may not be able to run them and even if it did, it might burn out the ballast which (depending on how old the ballast is) may not be very fun (as some (mainly older ballasts) are capable of going out violently).
                          I'm not a expert, I'm just doing my best.
                            Lithonia Lighting versus Light of America Compact Fluorescent product quality
                            I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                            I also have back when Light of America had these light bulbs available for yard lights
                            The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                            While the Lithonia lighting fixture has all most certain bulb failure
                            So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                            I have only had this light fixture for not more than a year if it...
                            07-02-2023, 03:45 PM
                            LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                            This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-07-2024, 03:40 AM
                            LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                            This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-06-2024, 09:10 PM
                            09-06-2024, 08:40 PM
                          • serious_electron
                            Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                            by serious_electron
                            Hello Everyone!
                            I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                            06-28-2025, 02:57 PM
