I fried my Arduino Mini...
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8703
    Re: I fried my Arduino Mini...
    No short circuit protection? craaap!
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      #42
      The ones I got look like this.
      Wattevah...
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        #43
        Btw, idiot question: is uf5408 the same as 1n5408 ? The datasheets are identical outside the "reverse recovery time" entry which doesn't exist for the 1n...I reckon UF means ultra-fast, while 1n is a general purpose rectifier....which is it ?
        Wattevah...
          • 31256
          good spot, the UF series is indeed an Ultra-Fast version of the 1N series.
          infact it is very handy to keep a few UF4007 in your spares box.
          • tamerelapute
            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
            by tamerelapute
            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
            Except the cpu, I cant feel anything getting warmer.
            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
            I believe that if the cpu was fried,...
            07-08-2024, 03:28 PM
          • caspian
            What Zener Diodes on a Linear Power Supply
            by caspian
            Dear members,
            I have a linear variable power supply with unknown brand name that I used for voltage injection.
            Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
            In addition, I discovered that its zener diodes are defective.
            I can replace the burned transistors.
            But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
            Therefore, I cannot replace the zener diodes.
            I do not want to test the zener diodes in a test circuit to discover their model or value.
            no schematics are available...
            05-26-2025, 12:38 PM
          • Nagy Daniel
            Lowest possible resistance on laptop motherboard rail - Guide Table request
            by Nagy Daniel
            Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
            I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
            I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
            So, I generated a table with AI so I can...
            03-04-2025, 08:24 AM
          • Dvsr
            On M-Audio AV40 active studio speaker's two zener diodes get really hot.
            by Dvsr
            Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
            I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
            After replacing the caps I started testing out the speaker. It seemed...
            09-10-2025, 10:20 AM
            HP 260 G2 Desktop Mini PC i3-6100U Specification for Upgrade or Repair
            This specification for the HP 260 G2 Desktop Mini PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 260 G2 Desktop Mini PC boardview and 260 G2 Desktop Mini PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-12-2024, 03:36 PM
