Relay Cross Reference or other option
  • Brucetafer
    • Jun 2018
    • 133
    I had a couple custom made boards for a 350V DC power supply and discharge for high power battery backup packs, I blew the damn relays acting like a moron. Trying to find the same size relay, preferably a better heavier duty relay.
    TRGB-L-SS-112DM
    https://en.maritex.com.pl/relays/ele...-ss-112dm.html
    is the relay, i tried finding them locally, and had no luck.
    I need 3 of them, also if anybody knows where to get the same one in the US id be stoked too.. need these asap..
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8065
    Re: Relay Cross Reference or other option
    Have you checked Digi-Key?
    • PeteS in CA
      • Aug 2005
      • 3578
      • USA, Unsure of Planet
      Looks to be a pretty common form factor. Just find a relay with the same footprint, height, pin-out, and current rating (8A would be OK, too).
      PeteS in CA
      • Brucetafer
        • Jun 2018
        • 133
        that's what im trying to do, unfortunately with no luck, seems like the only form factor is one other Chinese brand and its not available anylonger.
        • Brucetafer
          • Jun 2018
          • 133
          yes, tried them but only option is a bigger unit and this power supply is tighter than a knats a$!
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Just ghetto mod it
            https://www.eevblog.com/forum/repair...246/#msg972246
            • petehall347
              • Jan 2015
              • 4426
              http://uk.farnell.com/oeg-te-connect...10a/dp/1892012
              • petehall347
                • Jan 2015
                • 4426
                https://eu.mouser.com/ProductDetail/...OsncNpKHv6UA==
                • redwire
                  • Dec 2010
                  • 3902
                  Switching 350VDC with that relay, you're gonna have a bad time.
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8065
                    I second redwire and i am all for what Per said too... Relays are easy. Can we see some pics?
                    • PeteS in CA
                      • Aug 2005
                      • 3578
                      Good point. That 28V DC rating means that above 28V arcing between contacts can happen, which will weld the contacts.
                      PeteS in CA
                      • Brucetafer
                        • Jun 2018
                        • 133
                        well not going to lie, I might end up using this and changing the casing.
                        yeah thats why there is 5 of them, and unfortunately the software written is on an unwritable eprom.. all 5 engage at 310v and then they also are used for discharge.. its a weird build..
                        Yeah PeteS In CA, all of them welded together when I made a booboo, used the wrong discharge resistance and cooked them past the melting point..
                        • Brucetafer
                          • Jun 2018
                          • 133
                          As soon as I come home, im stuck in aruba at the moment.
                          • Brucetafer
                            • Jun 2018
                            • 133
                            ok, back in the states, came home to half my house electronics destroyed after a nasty power outage from a car accident outside my house.. oye... anyhow, Im going to order a couple different size relays and hope i can stuff them in..
                            just found out my brand new sunsui led tv won't turn on now.. literally just got it 3 months ago..
                              Acer TravelMate P2510-G2-M-54Q3 + Option Pack Notebook P2 Specification for Upgrade or Repair
                              This specification for the Acer TravelMate P2510-G2-M-54Q3 + Option Pack Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P2510-G2-M-54Q3 + Option Pack boardview and P2510-G2-M-54Q3 + Option Pack schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                              09-06-2024, 08:00 AM
                            • connorcc2005
                              Thermistor specs and cross reference
                              by connorcc2005
                              I'm getting some conflicting information and thought I'd toss it out to all of you for input.
                              What I have is a TTC-104 thermistor. This is part of a temp sense circuit that will drive a small 12v fan to cool components mounted to SMPS heat sink.
                              The physical diameter of the piece is 5.1mm measured with a caliper.
                              Other than what you see in the pic, there is no other writing on the part.
                              My research of the TTC-104 says it should read 100 ohms at 25C. Out of circuit measurements have it at approximately 100k. It does change as the temp changes....
                              06-16-2022, 04:16 PM
                            • jm1234
                              9V relay temperature 40C
                              by jm1234
                              Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
                              I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
                              05-09-2024, 03:03 AM
                            • edugimeno
                              Biomass Boiler not driving cleaner motor relay. ENERTRES BIOMASA BI-650
                              by edugimeno
                              Hi everyone!
                              I have this board that suddenly stopped supplying power to an output that drives an interchanger cleaner motor.
                              I checked while the board was in place with all wires attached and there's no AC voltage on the corresponding plug X5
                              This X5 is driven by fuse F8 (tested OK) which comes from the second orange relay
                              To make sure there are no charcoaled contacts inside the relay, I got a 24VDC power supply and got it ready to manually power up the coil side of these relays.
                              I respected the polarity, positive to cathode of protecting diode
                              So provided all...
                              04-18-2024, 01:15 PM
                              Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                              I was working on this CNC machine today found no keyboard functioning no control relay powering on
                              The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                              Found shorted diodes on main controller relays there are 3 of them that...
                              01-07-2023, 05:43 PM
