Controller component identifying
+ More Options
Posts
  • DjKrish
    • Oct 2012
    • 354
    • SG
    Hi all, i have a numark mixtrack platinum main board which is damaged a bit on corrosion. I have fixed most of the issue but im failing to get some info on certain components. Theres a few smd resistors and capacitors that needs replacing but i couldn't find the service manual anywhere
    The main reason i need a service manual is i can identify the value of those components and buy them from local store. Can anyone help me identifying those components or at least share the main board service manual? Id be very grateful.
    PS : Mixtrack platinum and mixtrack pro 3 uses the same main board.
  • cheeky2
    by cheeky2
    05-25-2024, 03:27 AM
  • Dani_2024
    by Dani_2024
    10-28-2024, 05:06 PM
  • ccbargains
    Pioneer SX-S30 need help identifying SMD semiconductors Also need service manual and/or schematic
    by ccbargains
    I have not been able to locate a service manual for this Pioneer SX-S30 receiver. The unit will not turn on. I am troubleshooting the switch mode power supply. I found three smd semiconductors that test open while in circuit. The first (Q904) is a transistor marked AZ43W. The second is a diode D905 marked L68 and the last is a diode D906 marked 66 CU1M. I have attached photos.
    Any help would be appreciated. Thank you....
    06-30-2024, 11:55 AM
  • lbs86
    ASP1500U main controller chip HELP for Asus strix-gtx980ti-dc3oc
    by lbs86
    anyone got datasheet or any schematic using this main controller chip ASP1500U on the graphics card can share pls?
    or anyone want to diagnose this graphics card Asus strix-gtx980ti-dc3oc , we may share the measurement, currently this card have no NVVDD,FBVDD and PEXVDD.
    12-29-2022, 12:03 PM
  • Asraf Atb
    Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
    by Asraf Atb
    Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
    Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
    I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
    01-27-2025, 05:02 PM
