ASP1500U main controller chip HELP for Asus strix-gtx980ti-dc3oc
  • lbs86
    • Jul 2022
    • 9
    • Malaysia
    anyone got datasheet or any schematic using this main controller chip ASP1500U on the graphics card can share pls?
    or anyone want to diagnose this graphics card Asus strix-gtx980ti-dc3oc , we may share the measurement, currently this card have no NVVDD,FBVDD and PEXVDD.
  • BMCappelletti
    Asus Chromebox CN62 - wrong chip put on BIOS reader
    by BMCappelletti
    Long story short:
    - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
    - gave the computer to his son a couple years later
    - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
    - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
    (seems like the story was not that short)
    He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
    01-08-2025, 07:27 PM
  • DynaxSC
    ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
    by DynaxSC
    Hi
    I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
    08-04-2025, 12:20 PM
  • ebugs
    Asus laptop EC/SIO chip replacement
    by ebugs
    Asus Vivobook 15 (board X513ea R2.0) gone dead when user plugged an iPhone cable into the USB-C port during boot. Now there's no LED light, no power at all. I checked all MOSFETs and capacitors, no shorts found. The board only has 3.3V and 5V present, no other voltages.
    I injected 3.3V into the EC chip power rail (ITE IT5125VG 128), and it draws 80mA, while the 3.3V LDO chip RT8249C has a max output of 100mA. I checked the boardview and found there are only two chips on this 3.3V rail, EC and Realtek audio chip. So I think EC could be the problem.
    I found the EC chip...
    09-14-2024, 02:09 AM
  • pengamat_hebat
    Problem Flashing Macronix MX25L6445E BIOS Chip with CH341A and EZP2019+ on ASUS X455LD
    by pengamat_hebat
    I'm trying to flash the BIOS chip Macronix MX25L6445E from my ASUS X455LD laptop using both a CH341A and an EZP2019+ programmer, but I keep encountering issues.
    Reading the chip works perfectly, and I can extract the BIOS dump without any problems.
    However, erasing and writing fail every time, regardless of the software I use. (Neo, asprog, ch341, etc)
    I also tried applying 3.3V to pin 3, but it still didn't work.
    I attempted to unprotect the chip, but when I read it back, the registers remained unchanged.
    03-25-2025, 04:13 AM
  • Jeroentje
    Asus X571GT repair chip replace and tips wanted
    by Jeroentje
    Hi
    I try to repair a asus Asus X571GT (DA0XKTMB8C0) no power no lights.
    I saw a burned (small hole in it) chip (JW10F) proberly a TPS22976DPUR, I removed it, now with power connected the laptop turns on and direct off again, power led and fn will light up.
    I found on a donor lenovo board a G2898KD1U (wa9y), looks the same ..
    Result is still the same, turns on and direct off again, first attempt is with backlight on all other direct attempts are only the power and fn led.
    Could it be the chip is to diffrent to make the laptop work again ?
    04-28-2024, 10:59 AM
