Help with LED brake lights
  • Dannyx
    replied
    Re: Help need Panasonic bios
    Wrong thread I'm afraid
  • sanjurahul
    replied
    guys please Panasonic CF-53 schematics and bios
  • WildPuppy
    replied
    Re: Help with LED brake lights
    Originally posted by Dannyx
    ... (may have to use google translate or ask me personally if you really want to dig into it)....
    Hehehe you're funny, you're not very keen on details, are you? I'm from the same shithole known as RO.
    Ok, joke aside, I know you said that for all the other members.
    I have to agree with petehall347 here and think you need a special relay for LEDs since in the schematic it is not very clear how the relay or the brake pedal contact works internally. Let's say it is more like a block diagram (quite usual in auto industry) than a true schematic.
    Did you try the specialized local forums like DaciaClub and Duster? They are quite large forums with a lot of helpful members.
  • Dannyx
    replied
    yes i just read your post . lamps need to be drawing current or it throws faults .
    You sure about this ? How can you tell ? I know for sure this is valid for the turn signals - if a bulb burns out or is removed, the ECU beeps/blinks faster and I tried it myself - but not sure it applies to the brake lights too...
  • petehall347
    replied
    you may need a relay for led lights . if it uses relays that is
  • Dannyx
    replied
    Here's the wiring diagram for this particular car (may have to use google translate or ask me personally if you really want to dig into it).
    Have a look on page 65 which shows the braking circuit, with box 160 on the left side being the pedal switch...there doesn't seem to be any additional circuitry there - just toggles between GND and VCC, HOWEVER notice box 118 below it, which according to the legend is the ABS control unit, that is, when you press the pedal, VCC also goes to it, which makes sense: the ABS unit needs to know when the bloody pedal is pushed in...don't know how or IF it affects our issue with the LED lights...
  • Dannyx
    replied
    No it's definitely not "old" - got it new in 2007...some may even be familiar with the model: it's the world famous Dacia Logan Anyway. I'll have a scrub though the wiring diagram - you may be right. There may indeed be some electronics involved and the two rear lights are not paralleled after all, so the functionality of one doesn't guarantee the other one works as well...
    I have seen others do this sort of mod and it worked without any issues, though the bulbs weren't identical - I reckon they had two individual separate "stings" of LEDs for high and low brightness...
  • WildPuppy
    replied
    It may be that your car is not as old as you let us believe and it has light bulb checks integrated in the logic. In this case, when it "senses" that the filament is not there, it may cut the power going to that bulb (or line of bulbs) or at least show an alarm light on the dash board.
    In this case, an filament equivalent resistor should be added in parallel to each LED branch to tell the on-board computer that the light bulbs are OK.
    Just my two cents... I am by no means a specialist, more like an heavy car user.
    PS: maybe this may help ? I admit I didn't read it all...
  • Dannyx
    replied
    Ok guys, back on this project, since I didn't have much time. I set up the...setup on the bench trying to replicate the one in the car as closely as possible: regular dual filament bulb in parallel with LED lamp with diode. I connected both filaments in the dual filament bulb to + straight off the adapter to simulate both the parker and the brake being pressed (no diode in between) then connected the parker terminal of the LED bulb to the adapter directly (no diode here either) then the brake terminal through the diode as well and it works: the LED lamp becomes brighter when I touch the cathode of the diode to the brake terminal...great....so why the hell isn't it working in the car ? It's extremely annoying...
  • Dannyx
    replied
    I was planning on doing just that.
  • petehall347
    replied
    wire a standard bulb in parallel next to each led . i know it sort of defeats the object but will get the job done . its that or large resistors in parallel . had to wire in bulbs on a motorbike indicators . also had to fit diodes in the speedo head .
    does the car have bulb out warning light on dash ?
  • Dannyx
    replied
    I shall. I'm also thinking the LED bulb doesn't like being in parallel with a regular filament one...I shall experiment on the bench first though - much easier, though it could yield inconclusive results as we just saw: I wasn't thorough enough in my original diode test, I saw it working on the bench and thought there's be no way it wouldn't work on the real thing, so I just rolled with it only to run into the aforementioned issue....
  • WildPuppy
    replied
    Try one diode per each circuit. Other than that, get some more expensive but properly built LED replacements
  • Dannyx
    replied
    Originally posted by WildPuppy
    Wouldn't this work if your schematic were correct?
    I am sure you have some relays there in the car, nothing is wired directly to the consumer...
    Depending on the power those LED's and whatever else is inside that bulb draw, it may have to be a strong diode...
    That is what I tried and it only solves half the issue: the LED lamp no longer turns off when the brake is up (grounded), but it doesn't change intensities either when the brake IS depressed.
  • WildPuppy
    replied
  • WildPuppy
    replied
    Not exactly identical to your problem, but still similar...
    https://www.youtube.com/watch?v=tci97uxfptA
    OffTopic: Happy Easter
  • Dannyx
    replied
    Nope - it's around 12.5v at the socket no problem. Didn't have the time to tinker with this project anymore, with Easter being right around the corner you know, but I shall return to it somewhere next week I expect if all goes well...
  • gabik111
    replied
    Anyone mentioned about voltage? Running car on idle supply about 12.8V-13.2V, above 1k-1.5k rpm 14.4V but with engine shut off 11.8-12.1V . If battery is bad it can be much less.
    I would focus on this and measure voltages in the car just at the lamp connector.
    replied
    btw, another option is to mod or replace the brake switch - i'v never seen one do that.
    is it 3 wires, or grounding through the casing? obvious answer is cut the ground.
    replied
    the diodes should work,
    can you post a photo of the led lamp?
    i'v seen some with a semiconductor based dropper,
    and some that use 2 groups of leds, one for low brightness and both for high.
    did you check resistance between the contacts in all combinations?
  • SluggerB
    Garage light only lights up when you hit it. Make your guess as to the cause!
    by SluggerB
    The flood light over my garage was hanging out of the house due to the previous moron not knowing how to anchor it correctly. So I fixed that today
    I then go to turn the light on tonight, and it doesn't stay on. If I tap it with a piece of wood, the lights come on for a sec them dim. Repeated tapping will cause it to eventually start working, until the switch is flipped, then it's a 50/50 shot it will work again or need to be tapped to start
    So tomm begins the diagnosis. What do you think it is? Vote now!
    A: A loose connection in a wire nut. I tugged...
    10-15-2022, 10:53 PM
    LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
    This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
    09-07-2024, 03:40 AM
    LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
    This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
    09-06-2024, 09:10 PM
    09-06-2024, 08:40 PM
  • serious_electron
    Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
    by serious_electron
    Hello Everyone!
    I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
    06-28-2025, 02:57 PM
