How does an ignition timing light work?
  • caphair
    • Nov 2011
    • 1249
    I'm not familiar with flash/strobe light operations and curious if someone can give a detail explanation of how it works if possible with a schematic to better understand it
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: How does an ignition timing light work?
    The car aspect or the light aspect? Overview of both:
    The timing light is just an inductive pickup from the spark plug wire. If you have two wires next to each other, due to induction from electrical to magnetic back to electrical, it induces a small current on the inductive pickup. This is then amplified and used to trigger a fast acting, fast charging bright light/strobe (a bright LED will do these days, in olden times a fast acting flash tube is necessary).
    The car aspect is a bit more involved. There's markings on the harmonic balancer or crankshaft pulley that indicates exactly where the crankshaft for cylinder #1 is at the top of travel, as there's always a best time to set off the spark to extract the most amount of power during the power stroke. Since the crankshaft and harmonic balancer is rigidly connected, the relationship is always the same. The bright light from the timing light will ideally only be on for a short while and only light up the markings at a specific point of time, and due to persistence of bright light vision, it will look like it freezes vision much like old movies' wagon wheel stoppage.
    Oh, and because of sensors and computer control, timing lights have more or less become obsolete these days in newer cars.
    • jazzie366
      • May 2016
      • 304
      Accurate. If the car has a distributor or a coil pack that has wires coming off of it that is NOT directly attached to the spark plug, you can still use this.
      However, if you're trying to find a problem, there are cheap scan tools that can show you live OBDII data, so if a cylinder misses, you can see that happen live. If you're trying to tune the ECU to get more performance, I recommend Superchips, I have used one on my father's Durango, it made such a difference.
      Popcorn.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        To be funny, it's still possible to inductively detect when the Coil on Plug fires the exact same way though the sense circuitry is a bit different (have to sense high current instead of high voltage).
        But it still holds that doing this is unnecessary these days due to the sensors and computer control.
        • caphair
          • Nov 2011
          • 1249
          Thanks I was more interested in the light aspect. How does the magnetic pickup cause 12v to pulse a strobe light so quickly? I'm picturing something similar to camera flash where there's a brief period for the capacitor to charge
          • diif
            • Feb 2014
            • 6978
            • England
            The timing lights I've used have 12v battery clips.
            • R_J
              • 9579
              http://tradeofic.com/Circuit/4558-IG...ING_LIGHT.html
              basic circuit and operation is very similar to a photo flash, just fire the strobe at a lower power so it does'nt take a long time to recharge
                Lithonia Lighting versus Light of America Compact Fluorescent product quality
                by sam_sam_sam
                I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
                I also have back when Light of America had these light bulbs available for yard lights
                The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
                While the Lithonia lighting fixture has all most certain bulb failure
                So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
                I have only had this light fixture for not more than a year if it...
                07-02-2023, 03:45 PM
                LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
                This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                09-07-2024, 03:40 AM
                LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
                This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                09-06-2024, 09:10 PM
                09-06-2024, 08:40 PM
              • serious_electron
                Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                by serious_electron
                Hello Everyone!
                I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                06-28-2025, 02:57 PM
