Maximum voltage through zener diode
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    Good day folks. This might be a silly question, but how much voltage can I pump through a zener diode ? I know the CURRENT should stay below a safe margin to avoid blowing the diode, but what about the voltage ? In the traditional regulator setup where I have a resistor in series with the load and the zener, provided the resistor is large enough to avoid excessive current, is there a maximum "input" voltage to such a circuit ? Again, please excuse me if this is a basic building-block question which I should be familiar with, but hey....the more you learn......
    Wattevah...
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Maximum voltage through zener diode
    The power through anything is P=V*I.
    Say you have a 10w 1.8v zener diode broken down. To dissipate 10w you would be sinking 2 amps at 5v. Sinking 2v would be 5 amps. sinking 10v would be 1amp. sinking .2amps would be 50v. at 110v you would sink .09 amps for 10w.
    Its linear.
    Expanding into the equation:
    P=V*I, so we have 10=5*I. we need to solve for I. Through some simple high school math: P/V=I, so 10/5=2
    So its P/V=I for current, V*I=P for watts, and P/I=V For volts.
    For a functional example:
    Say we need the amperage of a conventional 150w light bulb. 120v, at 150w gives us 150/120=1.25. 1.25 amps for said bulb. We can now plug said numbers into the other functions to check our work.
    150/120=1.25 (Amps)
    120*1.25=150 (Watts)
    150/1.25=120 (Volts)
    Larger numbers are the same as well. Say, 2Kv at 1.5Kw.
    1500/2000=0.75 (A)
    2000*0.75=1500(W)
    1500/0.75=2000(V)
    This is basic stuff, yes. Another rule to live by is the 90% rule. When rating non-precision components like resistors and the like, add an extra 10% to the expected max rating, and size accordingly. Say you have a resistor that you want to sink 3/4Watt into. Rate it for 1w. If you have a 10v circuit you plan to add a capacitor to, use a 16v capacitor. If you are making a 9 amp switching circuit use a 10 amp FET. Etc...
    This knowledge is holdover from the days of gone with tube radios and whatnot, so that 90% rule may be outdated.
    Follow the white rabbit.
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      Thanks for the detailed explanation. I was familiar with everything you wrote, but the math usually kills me so I'm glad you added some examples.
      Wattevah...
      • Dannyx
        CertifiedAxhole
        • Aug 2016
        • 3912
        To take it one step further and put it into practice (not literally please because someone will get hurt ): if I have 230v from the wall socket, turn that to DC and stuff it into a 5w zener, I'd only be able to draw a maximum of 0.02a from said circuit, correct ? Don't know of what use that would be.....lighting an LED perhaps ?
        Wattevah...
          You do pump the Voltage, you forcing the current through the Zener, the Zener will try to maitain the rated Zener Voltage.
          You also need to realize how to use the Zener.
          What is the Voltage rating of the 5W ZENER? 5V? 10V, 100V. You know the Wattage, you know the Zener Voltage then you can find what the current rating is.
          You also do not want to put the Zener across the power source that has high Voltage than the Zener. I.E. put 6V Zener across 12V power source. Try it an see what happen for yourself.
          https://www.digikey.com/en/maker/blo...e17bc61e2640f3
            Show us the diagram and show us how you come up with 0.02A. As I said before many times, do not skip the basic, look up how Zener works and how it is used.
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              That's what it can dissipate before blowing up. Zeners can't limit current. That's a resistors task.
              The most common use for Zeners, at least in my field, is voltage limiting. Say you have an expensive 5v powered device, and you have a crappy chinese 5v wall wart that you don't trust to power it. You could use a 5.8v zener in inverse parallel across the incoming from the PSU to clamp any voltage above 5.8v to ground. This is actually done in cheap capacitive dropper PSUs commonly.
                That is one of the clamping method, when power supply is operating normally and putting out 5V that 5.8V will not be conducting, but if the the Voltage try to go up beyond 5.8V the zener will conduct, and trying to maintain 5.8V but it can only maintain that 5.8V for so long if the current flowing though it not exceed the rating which depend on the Wattage rating of the Zener, most of the time the Zener will just short out (power supply may be putting out more than 10V, so putting 5.8V Zener on that is not going to last long) and crowbar the power supply so the power supply goes into ticking mode (cycle ON and OFF). Fixed many of those power supplies.
                • goontron
                  5000!
                  • Dec 2011
                  • 4108
                  • US
                  ^ yeah, the lone zener is for low power systems (100s of mA).
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    Sounds like the setup to a joke, so definitely not doing it now
                    To be fair, I was thinking of a 12v zener on a 230v supply straight off the mains....stupid, I know, but I wasn't actually going to try it - it's just to learn something about zeners in general and WOULD happen.
                    EDIT: the above setup would of course have the limiting resistor, otherwise it would go boom instantaneously, DUUH...I'm not that dumb
                    Wattevah...
                      Well you do not need 230V just to do the experiment, just use your DC variable bench power supply that can supply lots of current that has Volt and current meters then hook up may be 3V zener at the output of the power supply and then crank up the Voltage see what happen, easy enough.
                      • Dannyx
                        CertifiedAxhole
                        • Aug 2016
                        • 3912
                        STILL sounds like a joke, so not gonna do it Ok, jokes aside, I see where you're going, as we've discussed this in another thread of mine where I was struggling to power those routers at 9v off a 12v adapter If the series resistor is high enough, nothing bad would happen - the diode would regulate, but would have very little current left, since the resistor would have to be so high to prevent the diode from blowing that there'd be no current available for the load, unless it's extremely small. Pretty sure this is the result of such an experiment.
                        Wattevah...
                          What a wasted thread.
                          • Dannyx
                            CertifiedAxhole
                            • Aug 2016
                            • 3912
                            Ok, for some reason I haven't seen some of your replies (notifications were a bit late), so that's why my replies probably didn't make sense...
                            Now then, let's clear the mess up:
                            Schematic
                            Math: supposing the zener is rated for 5w. At 230v, 5w would mean 0.02A (5/230v=0.02, unless I'm somehow wrong). Now if the zener is a 10v one and I just had a piece of wire in place of the resistor, it would begin conducting immediately (since 230 is higher than Vz) and would draw immense current from the supply, since there's nothing stopping it from doing that - POP ! To prevent that, you'd size up the value of the resistor accordingly to keep the maximum current through the diode below 0.02a which would correspond to 5w....I may be wrong of course, so feel free to correct me again, that's the whole idea. It's all in my head, but I'm not good at explaining it back to others
                            Wattevah...
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8703
                              Yeah, a lot of facepalm and head throbbing conclusions here... head is spinning...
                              Key points:
                              1. 5W means 5W max is dissipated by the diode. This indicates max current that can pass through the diode when coupled with the zener voltage. A 10V zener means P=VI=5W=10V*I meaning I=500mA through the zener.
                              2. Connecting a resistor and zener in series is kind of useless. We need to know the load in parallel with the zener being regulated to really know what we're talking about. The variability of the load will dictate whether or not a zener regulator can be used.
                              3. If you compute back with that useless example above with 10V zener and 230VDC supply and no load in parallel with the zener, 220V would need to be dropped across the resistor. 220V*0.5 = 110W dissipated in the resistor by itself regardless of its value . THIS is the problem of these zener supplies.
                              • Dannyx
                                CertifiedAxhole
                                • Aug 2016
                                • 3912
                                Went over the theory once again on my own HERE...read that article many times before in fact, but those formulas don't sink in I kinda got it now and know how to calculate sh!t
                                Wattevah...
                                • fester
                                  • May 2017
                                  • 158
                                  • Slovakia
                                  you can use something like this
                                  https://electronics.stackexchange.co...erter-lossless
                                  (the first example) The capacitor is here used for AC as serial resistor but without dispating to much heat because of its capacital reactancy(current is shifted against voltage)
                                  • Dannyx
                                    CertifiedAxhole
                                    • Aug 2016
                                    • 3912
                                    Yeah, I knew about those capacitive droppers, but the point of this discussion wasn't to actually build anything in the end (I'd just use a bloody adapter ). It was just a generic "what if..." question...thanks for your input anyhow
                                    Wattevah...
                                    • unimatrix93
                                      TV backlight zener diode
                                      by unimatrix93
                                      Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                                      So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                                      Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                                      The led strips has 9 6V leds.
                                      02-10-2025, 12:13 PM
                                      NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                                      I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                                      I bought this from an eBay seller but unfortunately they only had one
                                      I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                                      I bought three of from them to also make battery packs with this output power limit in mind
                                      I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                                      04-23-2025, 05:50 AM
                                    • hobostove
                                      Corsair RM1000e - Help identify 5VSB Zener diode
                                      by hobostove
                                      Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                                      Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                                      There's a 22ohm resistor that's melted and open, but it still has the bands.
                                      The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                                      It looks like the diode connects the source and drain of a TNY284...
                                      03-27-2025, 02:25 PM
                                    • debidoobs
                                      Yamaha delay D1500, zener diode broken with no marking
                                      by debidoobs
                                      im actually trying to save a d1500 delay from yamaha. I found the service manual but schematic is missing and BOM list is a bit unclear as components listed have no reference linked to the pcbs... In my case, one zener diode was broken (114 code on the pcb in attached file) and couldn't be repaired : it was a zener type package. In the BOM list i found 3 reference on this board : 1S555 (can be replaced by 1N4148), RD4.7EB2 (approx 5v rectifier), RD7.5EB3 (approx 7v rectifier)...
                                      Actually the cathode goes to VCC of sram M5M5118P, without this diode missing, i have...
                                      04-24-2024, 09:01 AM
                                    • caspian
                                      What Zener Diodes on a Linear Power Supply
                                      by caspian
                                      Dear members,
                                      I have a linear variable power supply with unknown brand name that I used for voltage injection.
                                      Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                                      In addition, I discovered that its zener diodes are defective.
                                      I can replace the burned transistors.
                                      But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                                      Therefore, I cannot replace the zener diodes.
                                      I do not want to test the zener diodes in a test circuit to discover their model or value.
                                      no schematics are available...
                                      05-26-2025, 12:38 PM
