Where do I find a electrical disconnect switch like the one in this you tube video
    • Jul 2011
    • 6033
    You will see the disconnect switch that I am talking about 4 minutes into the video can you put a web link to where I can buy one
    If any one can help
    https://m.youtube.com/watch?v=xy2r2C-WtzQ
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Where do I find a electrical disconnect switch like the one in this you tube vide
    Christ, the guy has linked to about 50 of them. https://nodedist.com/store/cliff-qui...canada-version
    http://www.alliedelec.com/rs-pro-8112274/70615170/
    http://www.americaii.com/en/home/Par...rchtext=CL1857
    https://www.cedist.com/search/node/cliff
    Follow the white rabbit.
    • redwire
      • 3904
      It is a fuse and disconnect, European. Different mains colour-codes.
      I had one for years and never used it, tossed it out. It was for Manufacturing personnel to connect things and not die.
      Instead I use a contactor/relay, fuse, GFCI in a box, red light.
        • Jul 2011
        • 6033
        In case someone would like by one you get one here
        http://www.newark.com/cliff-electron...ter/dp/68C8457
          Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
          This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
          09-06-2024, 05:30 AM
        • SluggerB
          Help making a switch work the opposite way with a relay
          by SluggerB
          I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
          I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
          It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
          02-07-2025, 07:57 PM
          Modifying a 4 Position Universal Rotary Cam Changeover Switch LW26-20 for more cams
          by sam_sam_sam
          Panel Mount 4 Position 8 terminals Universal Rotary Cam Changeover Switch LW26-20 20A
          ( needs more cam circuits for the machine to work correctly again )
          https://www.ebay.com/itm/275321870186
          To
          3 Position 16 Terminals Universal Rotary Cam Changeover Switch LW28-20 20A
          ( not 4 positions but the right amount of cams circuits )
          https://www.ebay.com/itm/274660439950
          I going to take the 4 position cams selector switch and remove the cams that are on it and remove the cams off of the 3 position selector switch and swap them around...
          03-18-2023, 05:12 PM
        • Natob82
          Micro Momentary Push Switch?
          by Natob82
          Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
          12-21-2022, 05:22 AM
        • Vesko356
          by Vesko356
          08-11-2023, 03:27 AM
