Tricking circuit that detects li-ion battery temp/gauge?
  • caphair
    • Nov 2011
    • 1249
    Sometimes when I'm using a bench supply connected to the battery terminals of an iPhone (or any device that normally measures battery temp/gauge) the phone will display a message saying it's too hot and needs to cool before using.
    If I remove bench supply and plug in a known good battery the message goes away. So I'm guessing sometimes the internal circuitry of the device looks for a temp/gauge reading and if it's missing throws that message.
    Could I add a resistor to the pins on the device terminals to trick the circuit into seeing an acceptable value for a battery fully charged at room temperature or it wouldn't work? If so how do I determine the resistor value to use?
    • Jul 2011
    • 6070
    Re: Tricking circuit that detects li-ion battery temp/gauge?
    First off you can not fool it that way ----> if you take the protection board off the battery and hook up power supply to the protection board
    Be very careful removing the protection board from the battery you can start fire doing this
    HOWEVER you need be real careful when doing you can fry the phone and protection board if you are not real careful with the voltage that you put to it
    • RJARRRPCGP
      • Jul 2004
      • 6304
      Most thermal probes=If shorted, you get a false high reading.
      Open=Will think it's cold! 0C and the like...
      Thus, if you get an overheat complaint, it almost always means a temp probe short.
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • caphair
        • Nov 2011
        • 1249
        I don't mean fooling the protection board of the battery itself.
        I'm referring to the circuitry on the device AFTER the battery and it's protection circuit.
        Connecting a bench supply directly to the logic board minus anything to do with the battery/protection circuit in the battery
          • Jul 2011
          • 6070
          The way this person is making it sound there talking out the battery out of the phone and trying to run on a power supply and if that is the case then what I said would be true
          Now if the battery that is supposed to in phone is in there then what you have here would be true
            • Jul 2011
            • 6070
            You can not do it that way the the phone's power management will not work with out the protection board in place power management is looking for the signal
            from the protection board with out this signal the phone will either not come or keep rebooting or give some kind of error
            I know I have done this before and like I said if you are not careful you can burn up phone and or the protection board
            • Astonished
              Fixing the Charge Circuit of the Batteries of the DC Motor
              by Astonished
              Hi friends of electronics
              What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
              The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
              Please help me fix this circuit.
              (the datasheet of the IC: https://pdf.datasheet.live/28...
              01-28-2025, 06:24 AM
            • Tarot Superstars
              Short Circuit tester
              by Tarot Superstars
              Hello.
              I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
              The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
              Link
              The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
              https://www.youtube.com/watch?v=0eixDdCpiO4
              My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
              09-25-2023, 09:11 AM
            • Alimash
              op amp circuit function?
              by Alimash
              I am repairing a ups which doesn't turn on ,it has the following ICs:
              SG3525 used to drive inverter mosfets.
              couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
              A LM358 and TL074 for control mechanism and of course the uController.
              The SG3525 is shutting down every time the ups is turned on.
              I want your help to know the function of LM358 and TL074 in the system.
              I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
              07-31-2025, 07:45 AM
            • M1NEBLANK SHOW
              MSI B250 Gaming M3 Short circuit in CPU power supply circuit
              by M1NEBLANK SHOW
              Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
              (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
              Schematic and Boardview here
              04-04-2025, 03:57 PM
            • прямо
              Viper22A 5VSB circuit
              by прямо
              So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
              In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
              01-13-2024, 07:05 PM
