Faro 3D Laser Scanner
  • capwizard
    • Jun 2016
    • 1991
    Faro 3D Laser Scanner - Jay Leno's Garage
    https://www.youtube.com/watch?v=q3SVTBrKyZk
  • capwizard
    • Jun 2016
    • 1991
    Re: Faro 3D Laser Scanner
    Yes, Made in USA................... .......... PS: How come, there is no flag for my brother UK? :UK: not work!
    NextEngine's 3D Scanner - Jay Leno's Garage
    3D Metal Printing | 3D Printing Technologies
    https://www.youtube.com/watch?v=i6Px6RSL9Ac
    Additive Manufacturing - Direct Metal Laser Sintering DMLS Technology
    https://www.youtube.com/watch?v=rEfdO4p4SFc
    Additive Manufacturing - Laser Deposition Technology LDT:
    https://www.youtube.com/watch?v=dRMF9lC0tXs
    PS: I try to use Plasma cutter to print A plasma copper deposited PCB? Metal powder or wire is welded together using an electron beam or plasma as the heat source...similar to pic1............When we're welding will produce a lot of spatters these spatters can be used as a material to build PCB? ( in an argon room) ...similar to this video..... ..
    Laser Freeform Manufacturing Technology (LFMT) pic1
    Electron Beam Freeform Fabrication (EBF3) pic2
    Electron beam additive manufacturing pic3
    • capwizard
      • Jun 2016
      • 1991
      Hybrid machine (3D printer and 5 axis milling-machine)
      https://www.youtube.com/watch?v=oaIOrQi2HLM
      DMG Mori Aktiengesellschaft
      one of Germany's largest manufacturers of cutting machine tools and a leading global manufacturer of CNC-controlled Lathes and Milling machines.
      On 1 October 1870, locksmith Friedrich Gildemeister founded the ‘Werkzeugmaschinenfabrik (Machine Tool Plant) Gildemeister & Comp' back in the ‘pioneer days' in Germany.
      In March 2009, the company signed a cooperation agreement with the Japanese company, Mori Seiki. This agreement allowed the company to further consolidate its sales and service network in global key markets.
      DMG Mori Seiki Co. DMG森精機株式会社
      Since its establishment in 1948, it has grown into one of the largest machine tool builders in the world. In 2015 it was reported that the company will carry out a takeover bid to acquire its German partner.
      Additive Manufacturing - LASERTEC 65 3D
      https://www.youtube.com/watch?v=L3CkzQQFZXs
      LASERTEC Shape series
      https://www.youtube.com/watch?v=kcIi6GYRvyo
      ULTRASONIC 2nd Generation: ULTRASONIC grinding, milling and drilling
      https://www.youtube.com/watch?v=fEvo5jarIW4
      The background musics are GOOD! I'd listened 10 times just for this music!
      Don't be a poor TV repair man, Be innovative..............................
      • capwizard
        • Jun 2016
        • 1991
        Super Fast 3D Printer
        What if 3D printing was 100x faster? | Joseph DeSimone
        https://www.youtube.com/watch?v=ihR9SX7dgRo
        Carbon M1 Super Fast 3D Printer Demo!
        https://www.youtube.com/watch?v=O2th...M#t=594.119416
        Carbon3D's Super Fast 3D Printer Printing an Eiffel Tower
        https://www.youtube.com/watch?v=VTJq9Z5g4Jk
        Carbon3D Unveils Breakthrough CLIP 3D Printing Technology, 25-100X Faster
        https://3dprint.com/51566/carbon3d-clip-3d-printing/
        • waigy
          What are these components that detect paper in a fax scanner
          by waigy
          PROBLEM SOLVED
          I DIDN'T REALISE MY SMALLEST SOLDERING TIP COULD JUST FIT BETWEEN THESE COMPONENTS.
          I MANAGED TO REMOVE THEM WITH NO DAMAGE TO THE BOARD AND I HAVE MY INTENDED END RESULT.
          On a Possio PM70 portable fax machine which has a scanner that detects when you push a piece of paper into the scanner slot.
          It is these two small (3mm long) components that detect the paper and start the scanner feed motor which pulls the paper into the scanner.
          (These are on the circuit board for the keypad and not the main board)
          I want to disable these as...
          05-21-2023, 12:50 AM
        • Dannyx
          Hilti PD30 Laser Range meter Error 276
          by Dannyx
          Good day folks.....wow, seems like forever since I posted anything here Still alive and well, thank you I guess you could say I've become more independent and able to work stuff out on my own. This one though goes way over my head and I doubt is fixable, but maybe some bright spark out there has an equally bright idea.
          So: my Hilti PD30 laser meter quit on me just the other day. It was working fine, I set it down for a while and when I tried using it again it gave me an E276 and wouldn't do anything else. I tried taking out the batteries, all that standard stuff but nothing...
          07-30-2023, 05:05 AM
        • dansity
          Power DeWalt 12V laser measure from power supply
          by dansity
          i got a Dewalt laser measure which uses the 12V batteries to operate. The laser measure is faulty and I want to attempt a repair, never fixed such thing before. You might see a different topic if I fail with the repair
          However I do not have dewalt batteries nor want to buy one for 140EUR as the laser tool might have some chance that it is very hard to repair or unrepairable.
          I want to power it from my PSU.
          The tool has 3 input pins, on the battery it is marked with B-, B+ and ID/TH.
          i want to know what is the third pin exactly and what do I need...
          10-29-2023, 03:04 AM
        • CapLeaker
          Bearcat 300 scanner no display, has audio and squelch repair
          by CapLeaker
          I found an old Bearcat 300 scanner that had no display, but the audio and squelch worked, over at my workplace. This unit has a lot of hours on it. It had some capacitor replacements and other mods done to it too before I found it. To troubleshoot this problem, the usual is to check the +25v and -30V and replace C98 on the main board. That should fix it. There is also a case of a shorted button board (just unplug that ribbon cable and the display should work again). Spoiler alert! Was not the case on this one.
          My display didn't work, because I had a missing -10V on the display...
          09-09-2024, 10:24 AM
          I would like an explanation of how a laser can measure a product on a conveyor belt
          I saw this on
          “How do they do it “
          The laser was measuring the diameter and the height of the product and the weight of the product and it was a straight line laser light across the the conveyor belt ( this is all that was shown in the video clip of the laser that was used )
          What type of product is this that can do this
          I want to thank anyone that knows what of laser this is
          04-24-2022, 07:55 AM
