DeWalt's Grinder
  • capwizard
    • Jun 2016
    • 1991
    DeWalt's Grinder
    From AvE
    Bored of lame tool reviews? Meet DeWalt's 12 Amp Grinder part A
    https://www.youtube.com/watch?v=LWH5bfpivSU
    Bored of lame tool reviews? Meet DeWalt's grinder guts Part B
    https://www.youtube.com/watch?v=Zw5RPBVOR0g&t=487s
  • Agent24
    Dick Smith Q-1760 linear power supply filter capacitor question
    by Agent24
    I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
    It has at least one problem.
    The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
    I have already ordered a replacement potentiometer, so that's not an issue.
    Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
    All are CapXon...
    10-21-2025, 05:39 PM
  • imtmiissa
    Ask about IO KB9012QF
    by imtmiissa
    Hi, I want to change KB9012QF A4 on bored model LA9981P for KB9012QF A3 on bored model LA-9104P can i do it without programming because it in old bored and already programmed
    02-17-2023, 08:50 AM
  • TheBugger70
    Backlight 50HYT62U
    by TheBugger70
    hi trying fix cousins tv with no backlight tv is hitachi 50hyt62u i beleve the power suply is vistel 17ips20. i checked power coming out the boared to leds and was getting meter jumping from around 2v to 9v so i disconected leds from bored and was still getting the same. i tryed testing the leds wen unpluged from bored but wasnt able to get any reading. im wondering if the power detects that the led's have failed it wont put the rite power out or if it is a fault with power bored is it posable to test the leds with multimeter the way i tryed by disconecting from power supply and testing from the...
    05-30-2022, 10:21 AM
  • NanoTesting
    Chinese hot air and soldering stations
    by NanoTesting
    What is the consensus? are they useful or trash even in a short term scenario?
    Going to buy a hot air station and Yihua and Baku ones look popular in the "budget" range.
    I will eventually upgrade to an Atten or Quick.
    For example: and
    Are some of the models im going to buy, the Yihua one has some reviews that make it sound decent in EEVBlog and other sites also repair guides so i guess i will opt for that.
    But they all use the same heat gun that looks like it will melt eventually, and that has often reviews of having "dust" inside them on...
    09-27-2023, 06:05 PM
  • koostronics
    HP Probook 450g6 no battery charge
    by koostronics
    Hier nieuwe en eerste vraag
    Heb een Hp probook 450 g6 en deze werkt volledig maar laad de Batterij niet op,
    Het oranje ledje brand, de oplaadstatus beweegt, maar op 0 procent en als ik Batterij zelf op spanning meet is die nul
    Op het moederbord op + en - staat geen spanning, iemand enig idee waar ik moet gaan zoeken of wat er defect zou kunnen zijn de coil vlakbij de laadpoort is er er ook geen spanning, dank bij voorbaat
    09-18-2025, 02:07 AM
