Hand Made Vacuum Tubes
  • capwizard
    • Jun 2016
    • 1991
    Hand Made Vacuum Tubes by Claude Paillard
    https://www.youtube.com/watch?v=EzyXMEpq4qw
    How It's Made Audio Vacuum Tubes SD 360p =KCK= x264
    https://www.youtube.com/watch?v=PFQSdX1B-ic
  • madan1
    • Nov 2016
    • 726
    Re: Hand Made Vacuum Tubes
    Check this guy .. making tubes without even putting down his smoke https://www.youtube.com/watch?v=Imsc_J25QmE
    • flat-earther
      Hoover FM216LI cordless vacuum refuses to charge
      by flat-earther
      I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
      I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
      5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
      So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
      06-06-2025, 03:14 AM
    • AlexVG
      Replacing the WiFi module on a vacuum cleaner iROBOT i7
      by AlexVG
      I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
      I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
      (This board does not respond, only the LEDs light up in a circle.
      The liquid damage is catastrophic and restoration is impractical).
      (I bought this board to get the WiFi module and camera).
      The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
      If...
      10-22-2024, 07:20 AM
    • ex250
      SDJ01RM vacuum robot not powers on, all dead
      by ex250
      Hi friends, I have this vacuum robot at home that is not starting any more, no leds working, power button doing nothing, battery reading seems ok arround 14.4v, I suspect that mainboard is faulty, seems that there is not any clear brand model on it, and of course could not find any schematic. The trand of the vacuum is the Roidmi SDJ01RM, on some sites appears as vacuum mop Eve plus 60 or similar
      If any one could point for where to start... would appreciate, new board is quite expensive arround 100 USD or more
      Many thanks and Merry Christmas to all...
      12-24-2022, 05:12 AM
    • macbook1967
      Lefant M201 vacuum sensors alignment help
      by macbook1967
      I can't get my Lefant vacuum go straight after a battery replacement. It continues going in circles in open field or follows the wall constantly. What happened is I had to remove a circuit board to be able to replace a battery. After putting the circuit board back in place the sensor alignment went off, and I can't find the right position for sensors 1 and 2. Sensors 3 are not adjustable. Your help would be very appreciated....
      10-03-2025, 08:53 AM
    • elmontador
      LG RL4 (i made a mess)
      by elmontador
      Hello i hope someone can help me i made a mess, i forgot that the board still hot and i knock some resistors out of place , i can't find any schematics or any info, i am uploading a picture with the components i need to put in place i don't need the full manual just the list for the resistors and their value(8 in total), if someone can help i'll be thankful...
      09-02-2025, 03:31 AM
