Free DLP or rear projection TV !
  • capwizard
    • Jun 2016
    • 1991
    Someone offers me free DLP or rear projection TV !
    If on the phone, I told them will charge $50 to haul away for you!
    If they bought TV to my store, I told them my commercial dumpster is free for you to use.
    they said GoodWill no more accept no working TV.
    PS: "We'll remove your old refrigerator and freezer and pay you $50" and old TV worth nothing!
  • waigy
    Nikkai EAPA 450 car amplifier rear speaker output is a low level and distorts easily
    by waigy
    As the title.
    I think these used to be sold in maplins a lot of years ago, it is an antique, but it's just fine for my needs.
    It looks basic enough inside with large components so I could do a full recap pretty easily.
    Any suggestions on what component would cause the symptoms of low volume output on both left and right rear speaker outputs?
    If I turn up the rear gain level in the amp until the speakers start to distort it starts to distort quickly even though the speakers are still pretty quiet.
    I thought I had dodgy speakers as I just fitted new old stock 6x9s in...
    11-08-2024, 03:53 AM
  • howardc64
    Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
    by howardc64
    TV was fixed just after removing Samsung's rear snap cover.
    This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
    Maybe PSU->backlight connector didn't have a good contact?...
    07-23-2025, 12:34 AM
    20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
    I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
    At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
    Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
    04-09-2023, 08:04 PM
  • Steven Pieter
    Ipad 9th Both Rear And Front Camera Problem
    by Steven Pieter
    Hello everyone, may I ask a question? I have an iPad 9th generation A1202 with the problem that both the front and rear cameras are not working. However, when checked using 3utools software, the serial number is N/A but the score is 100. I am having a bit of trouble fixing my iPad due to the limited schematic and boardview files. Could someone please help me fix this problem?
    09-23-2025, 09:07 AM
  • echow2001
    Mac Mini M1 A2348 820-02091 rear IO port replacement p/n
    by echow2001
    need every single rear IO port socket replacement. some dumb kid destroyed every all of the sockets. before remove the socket from the board it would not boot but after remove it i see normal boot current consumption and chime. need to source the sockets for replacement. the HDMI, rj45, usbA audio combo appear to shared with macmini 2018 but the usb c is a different part
    part numbers in 2018 schematic not helpful on where to source, looks like its a custom part might just need to get a donor.
    RJ45-RCPT-X1037
    514-00083
    HDMI-RCPT-X1037...
    03-21-2024, 02:28 PM
