Carbon film vs metal film resistors
  • Viperel
    • May 2016
    • 34
    • Romania
    I had a few 5% 1/4W carbon film resistors blow up on me during my lifetime and i have always replaced them with the same type. Now i am wondering if metal film resistors could be used to replace them in sensitive circuits like switched-mode power supplies.
    I understand that metal film has better reliability with age and less noise and 1% tolerance, are any of these elements going to introduce any issues though?
    To sum it up, is there any advantage to using metal film resistors over a carbon film in PSU's?
    • 31019
    Re: Carbon film vs metal film resistors
    metal film is a better replacement, but they cost a little more.
    that's why they arent used originally.
    • Viperel
      • May 2016
      • 34
      • Romania
      Thank you, time to stock up on some resistor packs off ebay then
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        Are metal film resistors more inductive than carbon composition? Probably not an issue with SMPS but might be for radio apps.
          • 31019
          neither should be inductive, both are simply a film coating on a ceramic rod.
          • Longbow
            • Jun 2011
            • 623
            The difference is almost non-existant except for the cost. 99.9% of the time, there is no good-better-best. You might also think twice about whether you are getting good quality metal film from overseas. The main improvement in resistors is really that the carbon composition style is no longer used.
            Is it plugged in?
              • 31019
              actually, metal film handles more current for it's size.
              a 7mm carbon film will do about .1/3w, a 7mm metal film will do .6w
              • mariushm
                • May 2011
                • 3799
                Forget about ebay, go to a site like http://www.TME.eu or http://ro.farnell.com and order everything you want .. you'll pay around 20 lei for shipping but you'll get everything in a few days and they're sometimes of better quality than what you get on eBay.
                You can order 25-50-100pcs of what you want for lower prices and you pay shipping costs only once for the whole package so if you buy a bunch of parts the shipping cost is not that big of a deal.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  resistors are slightly inductive, they have a slight spiral in them...
                  I'd imagine carbon composition resistors to be slightly less inductive as they need less "windings" to get the right resistance.
                  • montemcguire
                    • Mar 2015
                    • 15
                    The degree of spiraling depends only upon the resistivity of the deposited film, not whether the film is carbon or NiCr. An untrimmed 'slug' that's closer to its final value requires a shorter spiral, and vice versa.
                    In general, the spiraling of a through-hole resistor will add a pretty negligible amount of inductance. These days, if that was actually something that affected the circuit, an SMD resistor would be used instead of a through-hole part. An SMD resistor chip has less inductance simply because its terminals are closer together, so it's electrically shorter and thus less inductive. Remember, a straight piece of wire has inductance too - it's not just the spiral that contributes to inductance.
                    • linuxguru
                      • Apr 2005
                      • 1564
                      Originally posted by montemcguire
                      ... a straight piece of wire has inductance too - it's not just the spiral that contributes to inductance.
                      Correct - the greatest contribution to resistor inductance probably comes from the leads and end-caps. If they contain any ferromagnetic material (iron, steel, nickel, cobalt, etc.), their relative permittivity will typically be ~100x to 1000x that of non-ferrous leads (Silver, Copper, Palladium, etc.) and their inductance will also be higher by the same proportion.
                      It's usually not important in most applications, but steel and nickel-leaded resistors sound terrible in audio applications. For that matter, most Ni-Cr metal film resistors also sound too harsh, even if they have non-ferrous leads. The best-sounding resistors that I've heard are usually non-inductive wirewounds, closely followed by Palladium-Silver thin-film chip resistors (available packaged with Cu leads) from Japanese vendors like Susumu and Nikkohm. They're expensive (say 100x to 500x that of stock Chinese MFRs), but indispensable for certain locations in the audio signal path (including feedback networks).
                        Lenovo ThinkPad X1 Carbon Notebook X Specification for Upgrade or Repair
                        This specification for the Lenovo ThinkPad X1 Carbon Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon boardview and X1 Carbon schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                        09-07-2024, 07:20 AM
                        Lenovo ThinkPad X1 Carbon Notebook T Specification for Upgrade or Repair
                        09-07-2024, 07:19 AM
