Importance of electrical silicone sealant replacement?
  • Andyy
    • Aug 2016
    • 28
    I've just repaired a Samsung BN44-0514A power supply (No Vs or Va, "exploded" QS802, shorted QS804, open RS819 & RS833). Replacing these parts restored Vs and Va and the board is working, at least on the bench with a 100W light globe as the load on Vs.
    Removing the MOSFETs was a pain though, each had their legs encased in a large amount of soft white silicone that was cut up and scraped away.
    Question: How critical is it to re-encase the legs of the new MOSFETs in silicone?
    I'm assuming the silicone is to prevent flashover between legs (the legs are already spread apart on the PCB, including an air-gap slot cut into the PCB between the legs). But given how close the "thick" parts of the legs are immediately underneath the TO-220 case, I find it hard to imagine squirting a bunch of silicone in there would help.
    Also, I don't have any silicone
  • dmill89
    • Dec 2011
    • 2534
    Re: Importance of electrical silicone sealant replacement?
    The silicone is usually just there to hold the parts to the board before they are soldered at the factory. It certainly wouldn't hurt to put it back, but likely isn't necessary.
    • NCSailor
      • Mar 2016
      • 9
      But if you do put it back, it is important that you select the type carefully. Most silicone sealers are acetic acid based (smell of vinegar) and these do have some electrical conductivity when partially cured and can cause shorts. Also the acetic acid formulations are very corrosive and may cause problems down the road.
      Best to try to find an alcohol based version. Silicone itself is non conductive and safe to use as long as it is fully cured.
      Last edited by NCSailor; 08-13-2016, 07:42 AM. Reason: Clarified effect of acetic acid
      • keeney123
        Lauren
        • Sep 2014
        • 2536
        I would say contact Samsung Engineer department and ask them what was the purpose of encapsulating the legs of this Mosfet. They could of wanted to make sure it's heat was restricted to a certain area. Also the dielectric constant may also be important in the selection of the compound. They may not know, but they may be able to give you the name and part number of the compound. With this you can look up it's specs and find a duplicate replacement.
        • diif
          • Feb 2014
          • 6978
          • England
          I've never replaced the silicone or other type glues after repair and never had any issue.
          With the randomness it is applied I doubt it's for insulation or heat purposes and solely for securing components to the board pre soldering.
          • keeney123
            Lauren
            • Sep 2014
            • 2536
            So I do not understand why they would use it for that reason? Are these not thru-holes where the lead can be bent slightly? Even if they wave soldered them a slight bend would keep them in place. Also, a slight bend would create physical contact with the thru-hole eyelet which would create a better solder joint. The leads could then easily be cut by a machine afterwards. It would seem an added expense for nothing.
            • diif
              • Feb 2014
              • 6978
              • England
              Squirting some goo is quick and easy and cheap. Not all legs can be bent easily, some components have thick rectangular legs not thin little ones like caps/resistors.
              The goo isn't very accurate so I doubt very much it's used as insulation.
              • NCSailor
                • Mar 2016
                • 9
                The sealant actually serves a real purpose,although at somewhat higher cost, the same could be achieved other ways.
                In the OP's power supply, just imagine if those Mosfets were not secured. They are mounted to two large heatsinks that would be floating. Every Time that power supply is moved or especially if dropped, the heatsinks will stress the Mosfet leads and solder joints.
                Sealant is often used on the large electrolytics in power supplies for the same reason. Due to their height, they are usually mounted horizontal and have almost no lateral support. Even mounted vertically, their mass and height will stress the leads and/or case in vibration or shock situations.
                Do I always replace the sealant? No, but I also accept that the unit will be prone to damage from dropping or vibration. If this is not acceptable in my application, I do use a sealant.
                • keeney123
                  Lauren
                  • Sep 2014
                  • 2536
                  Usually heat-sinks are soldered to the board and the components are mounted to the heat-sinks with screws. In the ops case the legs of the fet were in silicon. I would think if one wanted to secure the fet one would secure the body not the legs. The legs are already secure with the solder.
                  • keeney123
                    Lauren
                    • Sep 2014
                    • 2536
                    So in this case we are talking about a fet. Also, are these being bent by hand or machine? If this is being done by hand one could put all the flat small components on than put a flat piece on anti-static foam which is mount to a hard flat surface on top of the components and flip the entire board over and solder all components. The larger components one can put in the board have a cover that fits on the components and then flip the board over and solder. If this is done my machine it becomes even easier. With a machine this would be done in a process. Actually one could create an mold using an injection molding machine for the top cover of the boards components. With machine solder and component fill the mold could be press down on the components as they are being soldered which would secure their position without glue.
                      • 31277
                      it could be to keep dust from building up between the legs.
                      it could also be hiding ferite beads.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        +1 dust in plasmas can cause some analog noise issues especially on the buffers guessing the same for the switchers but who knows
                        • keeney123
                          Lauren
                          • Sep 2014
                          • 2536
                          This is why I find it best to ask the person who decided to squirt the goo. Many techs I have know will not track down a answer. They usually figure it is OK because someone else made a decision. That is seldom a good choice as in the end the outcome effects everyone and it will not improve production.
                          • sew333
                            Apartment to buy with coal heating. Any sense to buy electrical heater and new pc?
                            by sew333
                            Hi guys. I have an question. Overall i am currently selling my house ( apartment with 1 room ) to buy some cheaper with 1 room too, and save cash for new pc in autumn 2024.
                            So i choosed some cheaper apartment in smaller city,but there is coal heating. I dont wanna heat for coal.
                            So i m thinking to buy electrical heater. And my question . Is this any sense to buy electrical heater when i will be using new pc with rtx 5090 and new intel ( when will be released ) ultra + Psu Seasonic 1600W?
                            I expect that i will pay more for bills. But i wanna know this. Will using electrical...
                            06-14-2024, 07:30 AM
                          • Asxetos21
                            Dell Latitude 5511 audible electrical noise
                            by Asxetos21
                            I have a Dell Latitude 5511 laptop, and lately, a faint but clearly audible electrical (crackling) noise comes from the motherboard, similar to the random clicking coming from a mechanical hdd's heads moving inside it.
                            The laptop shows no signs of malfunction, and clearly this is electrical not mechanical, so my suspicion goes to a dodgy component in the power rails (a capacitor or a coil?). I fear this could develop into a serious damage.
                            Any advise on how to narrow it down?
                            The schematic is available here:
                            Dell Latitude 5510 5511 - Precision 3551 FDV50 FDV51 LA-J282P...
                            03-03-2025, 09:53 AM
                          • Microeletronica
                            HP foxconn 115xdbp 86dr motherboard bios and electrical diagram
                            by Microeletronica
                            I need the electrical diagram and bios for the HP foxconn 115xdbp 86dr board, does anyone have it?
                            09-10-2025, 07:57 AM
                          • Califauna
                            Short cirucit across UART chip legs.
                            by Califauna
                            Hi all. First post here.
                            I have an EKS XP10 midi controller with a Burr Brown DAC. When plugging in the controller it isn't being recognised by Windows. I have two more of the same controllers. Only this one has this problem.
                            I have looked and found that two of the legs on the UART chip, at the bottom of the picture, are shorted. These are not shorted on the good boards I have. It's possible to see a little metal exposed under there between the legs. Not sure why as I didn't think there should be track there.
                            What's the recommended fix for this? Snipping...
                            07-22-2020, 08:58 AM
                          • stonehenge7x
                            I need the electrical diagram ASUS p8h61-m lx3 Rev 2.01
                            by stonehenge7x
                            I already found the boardview, but I need the electrical diagram
                            02-26-2024, 08:32 AM
