They are shorted and will need replacing. As bud said you have other problems which will need repairing as well. Bud is a master, do what he tells you and you will be fine.
Thanks mmartell. I am trying to follow his instructions closely. I think we're doing OK!? ..... Hope I didnt damage anything putting a 5amp back in after the 2a blew. But those grey things don't look good!!
Sure we will get round to those.
Will it be possible to get good clear pictures of the bottom side of the board? The board is pretty crowded and hard to see all the transistors in the power amp sections.
No, it's not the mira 3. It says on the board rega mira version 2. 11/97. The 3 is more recent.
Ive taken more pictures. I've put them here to see if they are better. If not, tell me and I'll take more specific ones
There is a post at this link. The guy says the output stage is the same in the mira,mira 2000 and mira 3 but means nothing to me..
Don't know if that means much to you. http://www.diyaudio.com/forums/solid...-required.html
Oh men..
If you have a blow after put the mains the brige rectifier is the suspect.
Then you put again new bigger fuse and you blow all the system out.
It will be anything now.
