ST NUCLEO boards.
    • 31278
    ST NUCLEO boards.
    anybody got the 64pin one?
    i need to know the component size used for the crystal caps,
    are they 0603, or 0402?
  • ugamazing
    Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
    by ugamazing
    I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
    We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
    12-17-2024, 07:05 PM
  • ugamazing
    Apple M1 Boards & Exclamatory Error?
    by ugamazing
    We've now created a stack of 10 boards that have the same issue, which we suspect to be CPU-related. The issue is very simple--the board will not boot to anything, only showing the exclamatory sign inside a circle. No amount of DFU/restore, wipe/erase, etc, will resolve the issue. No boards have physical damage. We went ahead and replaced the SSD nands on two boards (one 02020, one 02016) and the issue remained exactly the same. We are considering replacing the CPU on one of the boards using a locked CPU, just so we can see if it resolves the issue.
    Has anyone else run into this...
    02-20-2025, 09:24 AM
  • ugamazing
    Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
    by ugamazing
    I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
    08-31-2022, 07:34 AM
  • hopkok
    Legion 5 PRO, 3 boards, same problem, NM-D562 Rev. 3.0 motherboard
    by hopkok
    Hi friends, last week I got 3 same boards for repair (NM-D562 Rev. 3.0), same problem, power button light up, but motherboard wont start.
    3,3V_alw and 5V_alw, 1,8V_alw and 0,75V_alw presented on all 3 boards, no other voltages. 1,2V missing and if I checked schematic right, I need 1,2V and than can be +3VS and +5VS generated after getting SUSP_N signal from KBC? or vise versa?
    I checked for low resistance on coils, no low resistance.
    Anyone with same issue like me?
    Thanks for any help.
    05-24-2025, 04:21 AM
  • midnightg35x
    Panasonic TC-P65S2 SU or SD Boards Bad?
    by midnightg35x
    I have a TC-P65S2 that blew an SC board (I had a previous post about some cross references). When I put the repaired SC board in, it worked with the SD and SU boards isolated and SC50 jumped. I reinstalled the SD and SU boards. I did forget to remove the SC50 jumper, but from what I understand about how that jumper works, that should not cause SC board destruction with properly working SC/SD/SU boards. When I turned the TV back on, the SC board blew again. Based on the fact the SC board was working without the SU and SD boards, it at least makes sense that one or both of them is bad.
    04-22-2019, 05:29 PM
