Thank you.
  • russellhearn69
    • Mar 2016
    • 16
    • Northern Ireland
    Thank you.
    I would just like to say thank you to all the members who helped me save my Tv from the scrap heap over the last day or so, you were all a massive help.
    Thank you
    Russell
  • Pawel Borowski
    Solving Razer Blade 14 (2022) RZ09-0427 from scrap.
    by Pawel Borowski
    Hi folks,
    I want to solve a Razer Blade 14 (2022) RZ09-0427 with Ryzen 9 6900HX and RTX 3070Ti from scrap, and I need your help with the diagnosis.
    I have checked (I hope) all the voltage rails and found no shorts to GND and B+ except for the CPU VDDCR_SR rail (see the photo), which is near zero ohms to GND.
    When plugged to PS, the laptop charges the battery, and after pressing start, it supplies voltage to all voltage rails except for CPU VDDCR_SR one and, of course, the dGPU, nothing more.
    I have no experience in this type of repair, so please let me know if the low resistance...
    05-05-2025, 07:37 AM
  • jimmy2022
    Russell Hobbs food mixer
    by jimmy2022
    hello.
    the chip has completely blown and i am unable to see the number on the chip. any idea what chip this is?...
    04-20-2025, 06:48 AM
  • Uranium-235
    Money for scrap computers and copper heatsinks
    by Uranium-235
    Has anyone ever gone down this road? I have a number of copper (and copper plated :/ ) and aluminum heatsinks. As well as full computers. Ever heard of any companies that will buy them off me (for not that much probably). I've been sending them to e-recycling
    I kept a beige taaaaall antec case, going to try TC's yellowing remover and try to create an old system. Probably multiboot with DOS and 98 and 2k to cover all my bases
    Maybe even use a certain Voodoo5 card in it
    10-09-2022, 01:44 AM
  • sigmeyer
    LG TV Need help replacing a Bipolar Small signal Transistor
    by sigmeyer
    Ok , so i got this TV from a friend of mine.So to start it off Its a plasma TV.When turned on it the red light comes on , then after a couple seconds the light goes off, and it repeats like that. You can hear the Relay click on for a few seconds then off ... So it wasnt an obvious short on the mains input thats for sure. I opened it up , and mind you, i have never seen an inside of a plasma TV so it suprised me to say the least. There are 3 massive power boards. The main one , then we have the board that is connected to another board which then goes to the TV (i assume those are some kind of drivers...
    10-16-2020, 03:28 PM
  • kotel studios
    Asrock 970 PRO3 - missing 1.1V on NorthBridge
    by kotel studios
    Recently I got this Asrock 970 PRO3 board from scrap. It had a few missing caps under the NB which I've replaced. Sadly, one of them went short (NC597 from boardview file). I did replace it and there doesn't seem to be any shorts left, but the board is not executing POST nor beep codes. I once got it to POST after I was slightly bending it, but that was only once. I tried to redo the same steps but to no avail. All caps on the backside of NB have 22-ish ohms.
    I have traced the problem to an dead Northbridge VRM. There's no voltage on Phase (pin 8), FB (pin 6), UGATE...
    08-02-2025, 02:34 AM
