Busted Power Supply
  • jdimpas
    • May 2008
    • 39
    Busted Power Supply
    Hello Guys, my compaq PC was accidentally plug to 220V outlet with PSU setting 110V. Eventually, the PSU got busted and smells burnt. When I checked the PSU inside the fuse was broken. What are the possible componets that are affected on this? need your advice. THanks
  • ant3202
    • Jun 2006
    • 275
    • Singapore
    Re: Busted Power Supply
    try changing the fuse 1st and see how...
    for my case ... my power supply went back kicking , once i replace the fuse
    • jdimpas
      • May 2008
      • 39
      okay thanks. I'll try to change it and keep you posted.
      • jdimpas
        • May 2008
        • 39
        I just changed fuse and plug to the outlet, and also i made a short connection between black and green in the PSU DC output. But it was not working.
        • Krankshaft
          • Jan 2007
          • 2328
          You probably shorted out the line bridge rectifier check it with the diode checker on your DMM for shorts.
          • stevo1210
            • Oct 2006
            • 4156
            I agree with Krankshaft as well, you should check the bridge rectifier and possibly the primary switching transistor for shorts as well. If there are MOVs (metal oxide varistors) in that PSU, I would check and see if they are blown or burnt.
            • Buchu
              • Jul 2008
              Look for fried MOV's inside the power supply. Plugging 220 into 110 setting causes the 220 to double which will take out the MOV's and the fuse. You will keep blowing the fuse if you don't replace the MOV's.
              • Krankshaft
                • Jan 2007
                • 2328
                I forgot to mention that when the PSU is on the 110 volt setting it connects the line voltage to a voltage doubler when set to the 220 volt setting it bypasses this doubler.
                When you connected the supply in the 110 volt setting the voltage doubler actually quadrupled the voltage (before it fried) which definitely took out some components along the way.
                • severach
                  • Aug 2007
                  • 1055
                  I plugged in some 110v AT power supplies into a circuit miswired for 208v because the electrician accidentally wired the single phase circuit in the 3 phase box incorrectly. In my case the caps blew. Other stuff might have blown since I didn't try to fix them.
                  sig files are for morons
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                    03-31-2024, 02:12 PM
                    07-01-2024, 06:34 AM
                  • JimBanville
                    Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                    by JimBanville
                    The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                    I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                    09-13-2023, 07:21 AM
                  • Babbar
                    by Babbar
                    04-12-2024, 01:12 AM
