Re: How Many Screens Have You "Accidentally Cracked" ?
I've never cracked or broken a screen of any type.
This reminds me of the very soul jarring moment I was sitting on my bed doing school work, way back in the day, and got up, leaving my laptop on my bed, but then tripped over the chord. The laptop crashed to the floor and I fell right on it, stepping directly on the screen in the process, shattering the crystals. I cried so much when the dazed and confused moment faded and I realized what a really really crappy thing had happened. Even thinking of it now brings back such painful memories. Had to buy a new screen and replace it. Thankfully it worked with no other damage on the new screen install.
Originally posted by ReeceyBurger123 View PostJust wandering people how many Crt, Lcd, Pdp or Oled screens have you cracked accidentally ? This could be when repairing the display or just pure harsh luck.
I can proudly say in all 322 Tvs I have repaired (so far) I have never accidentally cracked a single displayOf course some that haven't been economically repairable have met the sole of my foot lol
Interesting, I didn't even notice the stamping on the tops IRL but they're clear in the macro photograph. Probably the thing I like most of my Canon P&S still camera, no other cameras can come "close" in macro mode.
Actually this camcorder also can focus pretty darn close but does not have the resolution. And has 8x zoom, handily beating the 3x in the Canon.
Originally posted by momaka View Post^ Awwww. That is so cute!
I see some older caps too (looks like a '95 vintage, with those small caps with date code stamps on their tops).
Originally posted by eccerr0r View PostIn case anyone is interested in seeing a tiny CRT but not visit the video subforum (I don't really "monitor" that forum often myself, actually)
https://www.badcaps.net/forum/attach...1&d=1451870492
I see some older caps too (looks like a '95 vintage, with those small caps with date code stamps on their tops).Last edited by momaka; 01-06-2016, 04:43 PM.
No I haven't cracked this one yet fortunately... that may actually make me sad...Last edited by eccerr0r; 01-04-2016, 04:52 PM.
9v dc to the pcb.
JVC videostar ones are anyway.
find a service manual for the unit.
Yeah I see the tiny "flyback" (but I'm not sure if it's "really" a flyback vs a discrete switching PSU)... The voltage in probably is working as the CRT is lighting up just fine (screen starts up with random lines as if the cathode control is messed up along with the sweep circuitry, and then after warming up a bit the screen is all white.)
This circuit was made in 1995 or so. Sounds like it very well could be in the danger zone...
Alas still trying to figure out how to get the PCB out of the case. The CRT is loose when the case is open but the PCB is either glued or I can't find where it's being attached...
if you play with one, the power to the HV circuit is usually 9v
Yes, the viewfinder is a half or 3/4" CRT in there... Not so funny after you find out they're real... The "eyepiece" has a lens on it to magnify the screen too
It unfortunately is a black and white tube, but what can you ask for when the the screen is that small.
The aspect ratio (screen size vs length) you can guess is pretty bad, just to make sure linearity is good with simple electronics... The tube is about 3 inches long with the about half inch face.
Another thing I was wondering, what voltage is needed for these tiny CRTs? I'd guess that maybe 3KV is enough to get the cathode ray going for a tube this small. With the voltage this low I'd imagine that generating x rays is kind of hard...
Indeed quite possibly it was the gun drivers pcb attached to the end, then again, there are the people who had it survive drops. The yoke probably would be OK as it's getting to the bell which is quite a bit stronger - in my case the yoke was intact.
It was a 17" shadowmask monitor. I guess I wasn't too upset about it though I had bought it new. It was starting to have vertical amp noise introduced...alas you all can guess why...
BAD CAPS...
I still have a 19" (shadowmask) and 21" (Trinitron) CRT monitors, a 19" CRT TV, a 5" CRT TV, and a 3" oscope left with CRTs. That's not including the 0.5" CRT in this borked Hi-8 video camera I have (I acquired it broken...)
Originally posted by eccerr0r View PostEh no, not face down or up, the monitor is in the "normal" position how one would normally use a CRT.
Originally posted by stjmore likely the weight of the neck-pcb did it.
Either that or the yoke/focus/deflection coils assembly. Lots of copper in those, so they do weight a lot. It's one of the things the copper scrappers around here always take.
Originally posted by momaka View PostInteresting.
The front of the screen is usually the toughest part of the CRT.
https://www.youtube.com/watch?v=4el9omevmIs&t=2m51s
Usually the tablets / cell phones we get are already cracked. We have an Asus Memo Pad 8 (or maybe 7?) and we need to remove the digitizer and screen to clean it. There's water inside. My wife is a lot better at removing screens than I am. It's been awhile since she removed a good screen so she practiced on an old broken tablet we had. She didn't realize the screen adhesive was really strong and cracked the screen on the old broken one! Thankfully it wasn't the production one. Anyway, what she does now, she uses my Weller WHA900 Hot Air Rework Station to melt the adhesive a bit and uses these little suction cups to lift up the screen without bending the plastic.
Originally posted by eccerr0r View PostI just dropped it from 3-4 ft when it slipped from my fingers, it fell straight down to the floor oriented the way you'd view it.
i have seen small crt's dropped so hard that the scan-coils have ripped the neck off the back of the tube!
usually on portable test gear that came down a ladder faster than the engineer!
