Re: What is telephony? where does the VCC come from?
So this is the problem 2 volts at pin8 when you need a minimum 4.75 VDC to operate that chip. I am not sure but I would say the 5 volts is being generated on this remote board and is being fed by another connector. If you unplug this R11 connectors and leave the other connectors connected then measure the same two points again pin 8 and pin 5 what do you get?
